Carbon wheels on a gravel bike worth it?
Old 01-25-21, 07:05 PM
SwampGrinder
Opinions sought: Are carbon wheelsets worth the expense in terms of ride comfort and quality when rolling over bumpy gravel roads? I am not asking in terms of any weight savings or speed or hill climbing advantages.
My specifics: I own a 2021 Giant Revolt Advanced 1. Love it and really enjoying this new (to me) gravel riding experience. I bought the Advanced 1 specifically because I wanted 1X. I see the Advanced 0 and Advanced Pro have carbon wheelsets. This has me wondering if the compliance of carbon provides a distinct advantage over my current aluminum wheelsets in terms of ride quality (which I recognize is somewhat subjective). Or is it just a weight and speed thing? I ride exclusively in a national forest on primary and secondary forest service roads. It is almost entirely flat (SE US coastal plain). I do not ride single track or any technical trails (I have another bike for that). Also do not ride pavement, ever. So the idea of upgrading and then having a second wheelset for different rides does not seem particularly relevant. Given the upgrade will not be inexpensive, I am only interested if I will be able to actually feel the difference (I have other hobbies that I could spend the $ on). But if the difference is real, I'm all in.
Thanks for any insight or advice.
SwampGrinder is offline
Old 01-25-21, 07:06 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 985 Post(s)
Liked 879 Times in 526 Posts
Save your money.
Moe Zhoost is offline
Likes For Moe Zhoost:
Old 01-25-21, 07:16 PM
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times in 163 Posts
No.
Moisture is offline
Moisture
Drip, Drip.
Moisture's Avatar
Try different stems and saddle positions instead
Moisture is offline
Old 01-25-21, 07:53 PM
DeadGrandpa
DeadGrandpa's Avatar
Bikes: Too many, yet not enough.
Quoted: 491 Post(s)
Liked 308 Times in 199 Posts
When I had more money than good sense, I bought a 29+ bike, aluminum frame and rims, and kinda heavy-ish (like a Jones SWB bike, but aluminum). The "reviews" I read recommended upgrading to carbon rims, so I did, even before I had ridden the stock rims. I absolutely didn't know what I was doing, but the lbs guy said that the advantage of carbon rims is more than however many grams is saved. I can't explain it, but I will tell you that this bike is my favorite bike. And I'm thinking about getting a set of carbon rims for my carbon "paved road/occasional gravel road" bike, on which I run a 700/35 and 700/40 Clement/Schwalbe combo of tires. I've never been sorry that I bought carbon anything. Pound for pound, it's 20x stronger than steel (although only in the direction in which it was designed to be strong). Lots of folks hereabouts will disagree.
DeadGrandpa is offline
Old 01-25-21, 08:00 PM
grolby
grolby's Avatar
Quoted: 288 Post(s)
Liked 86 Times in 60 Posts
Carbon wheels will be lighter and they typically feel a bit zippier and faster and, depending on how deep they are, make a cool sound. And they look cool, too. They won't ride more comfortably than aluminum, though.
grolby is offline
Old 01-25-21, 09:44 PM
Toadmeister
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times in 170 Posts
Carbon fiber can help reduce road chatter, the high frequency vibrations which often cause discomfort over time. That said, your tires and pressure will have a larger impact in this aspect.
Toadmeister is offline
Likes For Toadmeister:
Old 01-25-21, 09:47 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
The better aluminum wheels at $800-ish are about the same weight as the $1200 carbons (maybe 1600 - 1650 grams) so I'd save my money and go aluminum in this price range if they are significantly lighter than what you have. Otherwise I'd stay with your current wheels. For gravel you need something wider and stronger than road wheels so the super light carbon does not make as much sense as it does in road wheels. Light weight you will notice immediately but road feel you will have a tough time telling the difference in this price range. Easton, DTSwiss, are great aluminum wheels in this price range and Shimano GRX are hard to beat for $418 in the lower-price bracket.
dwmckee is offline
Likes For dwmckee:
Old 01-25-21, 09:48 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
Tires >> wheels
Cyclist0108 is offline
Likes For Cyclist0108:
Old 01-25-21, 11:04 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
I have both and whatever subtle differences there are between high end alu and high end carbon disappear 5 min into the ride. The weight difference is like 300g - I couldn't tell by feel alone but objectively there are probably seconds worth of savings when I compare rides.
Elvo is offline
Old 01-26-21, 09:06 AM
rosefarts
With a mighty wind
Quoted: 1084 Post(s)
Liked 854 Times in 483 Posts
Stan's Crest ZTR are 23mm internal width, weigh 365g, are tubeless ideally, and cost $100 per rim. My gravel bike has a 1500g set of wheels I built with them for under $500.
Stan's rear hub, Novatec 791, and I was the builder.
rosefarts is offline
Likes For rosefarts:
Old 01-26-21, 10:28 AM
msu2001la
msu2001la's Avatar
Quoted: 1455 Post(s)
Liked 1,477 Times in 867 Posts
I have never noticed any difference in ride quality between my carbon and aluminum wheels. I'm not even sure how someone would notice "compliance" in a wheelset that is running wider/lower PSI gravel tires. Is that really a thing? If anything, my carbon wheels feel a bit stiffer and harsher than my aluminum wheels.
For gravel use, carbon wheels are way into marginal gains territory. In most cases, a gravel tire ruins or at least massively diminishes whatever aero gains you're getting from a deep section wheel (typically optimized around road tire sizes), so the main benefit of carbon is gone. There are of course some lightewight carbon wheels out there, but for the most part they are narrow and low spoke count wheels designed for climbing on road bikes. I do see a lot of Zipp 303 Firecrest at CX races, and this wheelset looks awesome but is very expensive. Outside of that and a few similarly expensive carbon options from Enve, etc I think you'll be hard pressed to find a carbon wheelset that works on gravel and is noticeably lighter than a descent aluminum wheelset.
At the top of my current gravel wheelset is the HED Chris King option. For $1215 you get a 1650g wheelset that is wide, robust and rolling on Chris King R45 hubs that have instant engagement and super smooth bearings. On the cost-competitive end, the Shimano GRX wheelset also looks like a solid buy at $419, but is a bit narrow (21.6mm internal, 26mm external) for gravel tire sizes. There are many good options in-between, and I really like the DT Swiss 350 hubs as a choice for something in the $700-$900 range.
msu2001la is offline
Old 01-26-21, 10:34 AM
msu2001la
msu2001la's Avatar
I have read the Crest rim can be a bit flexy. Any truth to that? I have played around with builds on PWB using these and you can definitely make a very light/cheap wheelset with them.
I mostly see the Grail being used for CX and gravel, but it is 100g heavier and narrower.
Old 01-26-21, 12:25 PM
rosefarts
With a mighty wind
I built byhe wheels last spring and rode them on my mountain bike. A hardtail. I didn't ride a ton but I got some great rides with some very rocky descents on them. I put new end caps on for my new bike, a Ritchey Swiss Cross. When I pulled the mountain bike tires off to make the switch, I put them on my truing stand. Not perfect but nearly.
I don't expect them to give me any trouble.
The big disclaimer is that I'm 140lbs, actually, a touch under. I can't make any promises for a bigger rider. At my size, I've never crunked a wheel without a wreck.
A pair of Light Bicycle carbon rims on the same build would weigh the same and likely be stronger. I think they're actually not too much more.
Old 01-26-21, 02:05 PM
tdilf
tdilf's Avatar
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times in 70 Posts
This is like asking if it is worth it to eat a cupcake - you don't care what it tastes like or how many calories it has… but is it worth it
tdilf is offline
Likes For tdilf:
Old 01-26-21, 03:48 PM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
How much do you weigh? At ~185lbs I haven't had an alloy rim survive yet. So I bought carbon Bontragers with a lifetime warranty. Two or three broken alloy wheels and I'm money ahead with the carbon wheels.
2019 Salsa Warbird
shoota is offline
Old 01-27-21, 01:12 AM
pipeliner
Quoted: 43 Post(s)
Liked 72 Times in 40 Posts
Weight savings is negligible, ride quality probably favors aluminum but if you are running 40mm or larger TL tires you can't tell. I ride carbon for the durability. Don't need to be trued nearly as often, can take a beating.
pipeliner is offline
Likes For pipeliner:
Old 01-27-21, 07:11 AM
Koyote
Quoted: 6926 Post(s)
Liked 10,926 Times in 4,667 Posts
No. Just no.
Assuming your bike fit is dialed in, leave your stem and saddle alone. Regardless, there is nothing about these variables that would affect ride smoothness to any noticeable degree.
OP: for the riding you described, you will get much wider variation in ride smoothness with different tires. If you are currently running a stiffer, less compliant tire, you could try something like this and get a significant improvement in ride quality.
Koyote is offline
Likes For Koyote:
Old 01-27-21, 08:11 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Define worth.
I wanted a set of Onyx Racing Products sprag-clutch hubs laced up...I could either have had say ColoradoCyclist or someone similar lace up alloy rims, or for the same money had Light Bicycles lace up 45mm carbon rims. Both would weight about the same--but ofc the Onyx are not built to be lightweight--but durable, silent, and proper instant engagement. I did the LBs.
Marcus_Ti is offline
Old 01-28-21, 09:59 AM
shoota
shoota's Avatar
I am only interested if I will be able to actually feel the difference.
To this point right here, no, it won't be that noticeable. Go for the alloy wheels and see if they last you more than two seasons. You can always buy aftermarket carbon at any point.
2019 Salsa Warbird
shoota is offline
Old 01-28-21, 10:11 AM
Hypno Toad
meh
Hypno Toad's Avatar
Quoted: 1110 Post(s)
Liked 1,012 Times in 518 Posts
Great Toads think alike!
IMHO, comfort on rough surfaces starts at tires. Look for wider tires, with higher tpi (making softer sidewalls), and play with pressures. I ride 700x45 WTB Riddlers and like to keep pressures around 25/28 (f/r) psi for gravel (for reference, this Toad is ~165 lbs).
Great discussion about tire choice and pressures - jump to 5:55 to talk pressures.
EDIT (afterthought): comfort starts at the tire, but never forget if bike geometry and fit are off, no tire will fix that.
Hypno Toad is offline
Likes For Hypno Toad:
Old 01-28-21, 01:35 PM
Moisture
Drip, Drip.
Moisture's Avatar
Lol
This.
Moisture is offline
Old 01-28-21, 01:37 PM
Moisture
Drip, Drip.
Moisture's Avatar
why do you expect such a short life span? The Araya rims laced to suzue hubs on my 1980 Norco were original and still rolling perfect fine after 40 years of use.
The rear wheel has been bent before, so two of the spokes on the non drive size needed to be almost fully loosened to maintain rim true, but the wheel didn't bend at all even when I weighed 220lb.
if you want to tinker with your bike, start with different stem lengths, saddles and tires to find better comfort.
Moisture is offline
Old 01-28-21, 01:42 PM
shoota
shoota's Avatar
Because I haven't had a MODERN alloy gravel rim last more than two seasons yet. Same for a lot of my buddies that ride a lot. However, carbon rims have proven time and again to last longer, at least around here.
2019 Salsa Warbird
shoota is offline
Old 01-28-21, 03:26 PM
Hypno Toad
meh
Hypno Toad's Avatar
Vera Terra were stock on my 2017 Breezer Radar Pro, I've got 3+ years and 4,400 miles on these rims without an issue. To be clear, I don't baby this bike ... including ultra-endurance gravel events and single-track MTB trails.
