Spinergy GX series Wheels?
Anyone have an opinion or actual experience with the new lineup of Spinergy Gravel wheels? They spec out really good with 24mm inside widths and sub 1,500 gram weights. They are also one of the best values out there @ $599 for the aluminum and $999 for the carbon wheelsets. There's also a 10% coupon I found that helps too. Besides the obvious proprietary pbo spokes, I really don't see a downside. Only other wheelset that appears to be almost as good of a value is the Hunts but they are sold out at the moment. Thoughts???
https://www.spinergy.com/products/gxx
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
The website says the wheelset is 1590 grams. I have a LB wheelset that is under 1500 grams but is not as wide as the Spinergy wheels.
I don't have experience with Spinergy but they seem to have some good options.
Thread Killer
Quoted: 3132 Post(s)
Liked 1,700 Times
The carbon rimmed GXX is the 1590g one.
Quoted: 108 Post(s)
Liked 117 Times
[QUOTE=chaadster;21915010]The nomenclature is very similar for various models, but the aluminum rimmed GX is listed on the site at 1475g: https://www.spinergy.com/products/gx
Oh yeah, that looks like a great option at a great price.
Thread Killer
Liked 1,700 Times
Speaking of the GX width, I have a pair mounted with 35c Herse Bon Jon Pass Extralights which measure out to 37.85mm. The tire sidewall flares out from the rim ever so slightly, and really seems pretty close to an ideal width for a performance-centric tire on that i24 rim.
Of course it’ll carry a much wider tire no-problem, and I think Jan Heine says a more bulbous tire profile is not an issue when coupled with width, which my limited experience running i23s x 47c substantiates, but I’m hedging my bets with i24 x 35c for when the speeds ramp up and lateral forces increase. I’ve not ridden the Spinergy yet, though, so we’ll see if that proves to be true.
35c Bon Jon Pass on i24 Spinergy GX wheel
Thread Killer
Liked 1,700 Times
As another aside, just because I’m sitting here with all the stuff, the weights of the wheels (with factory tape) mounted with AC valves, tires and sealant is 1080g for the front, and 1300g for the rear (w/Shimano freehub body).
Using manufacturer claimed weights of 1475g for wheels and 303g for tires, that leaves a not insubstantial 299g accounted for (in part at least) by sealant, rim tape and valves. These tires did have sidewall pinholes and were warranty replaced by Herse, but I’ve not mounted the replacements yet, and these did take a lot of sealant to set up, maybe close to 100ml per tire as I recall. Probably 200ml of Panaracer Smart Seal weighs around 225g, and the American Classic valves 10g for the pair. Rim tape is the factory fitted stuff; could it weigh 60gm on both wheels?
Anyway, it all serves to remind us that listed weights aren’t everything. Heck...weight isn‘t everything.
I just built a bike with GX's, but haven't got to ride them much since it conveniently dumped endless snow as soon as said bike was finished. IIRC they were right at the advertised weight out of the box, I was able to mount Pirelli Gravel H tires easily, and they even inflated first try with a regular floor pump and no sealant. I think they look cool with the spoke color options, and Spinergy has at least some history in cycling.
As for how to decide on a budget gravel wheelset (let's say up to $700), you're looking at stuff like the Hunt's, DT Swiss GR 1600 / 1800, HED Emporia, Spinergy GX, and Chinese carbon /w Novatec hubs. Without getting into the alloy vs. carbon debate, I chose the Spinergy wheels because of the cost to weight, they are supposed to be very strong, and they are a US based company. Needing to remove the rim tape to true doesn't concern me too much if it's once a year at most thing, and neither does the low rim profile because aero wheels on a gravel bike are laughable unless you're in it to win it racing with everything else aero optimized, and genuinely need the marginal gain.
Thread Killer
Liked 1,700 Times
Perhaps minor but probably worth noting, the HED are USA made, whereas Spinergy are made in Mexico.
Regarding aero, had I not been pinching pennies with this build, I’d have spec’d Spinergy’s aero PBO spokes for these wheels; it probably wouldn’t have been more than $150 upcharge— I got my GX Black on sale for $499– but I really needed to control costs. Most of my gravel rides are group rides on fast hardpack roads, and I’m always the fattest guy in the bunch, so I’ll take marginal gains when I can get ‘em. I’m usually gone OTB on the climbs, when I’m maxed-out dumping L5 power and grinding along at 6mph while everyone else is doing 10mph at Tempo. So yeah, getting aero bennies at 6mph prolly ain’t happenin’, but if I can buy (or bank) a few watts when cruising, I’m happy to do it.
Likes For chaadster:
Well I just ordered a set of their GX wheels in the Spinergy Edition Colorway which is all black with one red spoke. I called to check on availability and they were in limited stock with the xdr hub so I placed my order. I mentioned a 10% off coupon I had at home and they honored it no question without the code.
I just bought my Salsa Warbird last week and the WTB wheelset that came on it is extremely heavy. I weighed the wheels, 42mm Trevail tires, 160mm trp rotors, and tubes all together and it came out to 4,500 grams which is almost ridiculous.
Thread Killer
Liked 1,700 Times
I have some WTB i23 650b factory wheels on my Breezer Doppler, and though I’ve not weighed them, they feel quite heavy. I’ve got my mind set on Spinergy replacements for those as well. If I can get that bike sub-30lbs, I’ll be stoked!
Oh, I should call them and check on my XDR driver order. After I bought mine with a Shimano freehub, I decided to run a Force 12spd drivetrain, so I called to order the XDR driver, but they sent me old XD bit. I sent it back last week, but have had no news on the proper part.
The actual weight for everything was 4,400 grams the stock WTB st i23 wheels, 42mm Teravail Cannonball (durable) tires, 160mm trp rotors, tubes, and Sram PG1130 11-42 cassette.
On a diet with the Spinergy GX wheels, larger 45mm tires, 160mm Dura Ace Rotors, valves, sealant, and a Sram X011 speed mtb cassette, I have the weight at 3,200 grams which is a 1,200g savings or 2.6lbs. My Warbird as it sits is 21.5 lbs (61cm) so I should be right at a respectable 19lbs without even touching the cockpit or replacing the 807g Sram Apex crank with something lighter. I know weight isn't everything but I just love it when you can shave 3+ pounds off a bike!
Likes For zen_:
Thread Killer
Liked 1,700 Times
Yeah man, call them right away because she said they only had a few xdr hubs available to build up some wheels.
Spinergy just emailed to say the XDR was on the way! Phew!
