Easy (Physically) Bike Pump ...
GadgetJim57
I have high blood pressure and it's getting to be too difficult for me to use my old Topeak Road Morph pump.
Can anyone recommend a pump that is much easier to use … ? Size is not even an issue. I just need a bicycle pump that is easy enough to use, so I don't pass out !!!
For the ultimate in home use, a small air compressor works. It needs to be the kind used for tools though, so it can get to the ~100psi for road tires.
For mobile use, just use CO2. The cartridges are ~$1 ea, and they take zero effort. Carry 2-3 cartridges. Seriously, don't overthink this. You'll use maybe 2-3 per year.
instead using a small pump you should be using a floor pump . almost any brand will work better for you . no matter which one you get it will give you a workout and maybe in time it will help bring down your blood pressure .
GadgetJim57
I like the idea of CO2 cartridges …. Any recommendations which CO2 pump … ?
GadgetJim57
I'm looking at the Lezyne Floor Pump ….. Does anyone have that pump ?
Non omnino gravis
So you want a pump to use at home, or for mounting on the bike? Because if it's for filling up tires at home,
...or any power inflator that uses batteries you already have. If you don't have any cordless tools, the Ryobi route is the cheapest. The inflator is $20, you can get a battery for $25, and a charger for $25. Comes with an excuse to buy any number of other 18V cordless tools.
But does the OP have a need for high pressure ..? cars need large volume but not high pressure...
If not, tank and compressor sets from Sears, may be ok, too , then..
GadgetJim57
I will be carrying the bicycle pump on eBike tours ….. I have the huge Surly Big Dummy panniers in the rear, and large Ortlieb Panniers in the front. So, weight and size is not an issue.
Mechanic/Tourist
Get a CO2 head and a box of generic CO2 cartridges, way lighter and easier than a floor pump.
Or get the Ryobi pump head shown above and tap into your E-bike battery for power
Quoted: 4209 Post(s)
Liked 3,875 Times
AndrewRStewart
AndrewRStewart
Liked 3,875 Times
Spoken like a yet to really tour rider I second the on ride use of CO2 cartridges. I suggest to visit your LBS or friend and try out more then one design. Some are easier for some to use then others are. Remember to pay for, replace, the trial cartridges. Andy
AndrewRStewart
AndrewRStewart
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I like the way you think! More tools, Hmph (I'm sitting here making Tim the Toolman noises-use your imagination)
Non omnino gravis
Something like this should work well. Honestly, your local bike shop or REI will have a good selection of options.
CO2 is ideal for emergency use, quick, compact and lightweight. Generally, most tires only need to be topped off every couple of days, so you can probably find a shop pump or compressor for top ups while touring.
Seen in the past, Pro teams modified battery hand held inflator , added an accurate gage & PV head.
but they are professionals , have 20 + wheels to top up.
dollar-store reject
Buddy of mine put it this way.. "..you're already mad as hell you had a flat tire, now you're going to sit alongside the trail for another 15 minutes stroking that mini-pump 300 times? Put a cartridge in, PSSST. Change the cartridge.. PSSST. Reinstall the wheel on the bike & go.."
There's also compact Li-Ion battery based pumps.
Typical example: https://www.amazon.com/CYCPLUS-Porta...dp/B07B65GN6W/
I have no idea how high pressure it can actually get to. I suspect no where near the 150psi rating, but some of the reviews claimed it got to 65psi with no trouble. This could be a good solution for touring where you have access to charging overnight.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I just bought one a couple of days ago. It doesn't take much effort to use. I just don't know how to compare it to the one you have. Does it really mess with your BP?
https://amazon.com/gp/product/B071WM...?ie=UTF8&psc=1
CO[sub]2[/sub] quickly leaks out of butyl tubes, so it isn't a good solution.
GadgetJim57
GadgetJim57
Occam's Rotor
Liked 2,331 Times
Since I don't have the Topeak pump, I have no way to compare them. Fundamentally, you will have to do the same amount of work to deliver the same amount of air (and the same PSI) to the tire, regardless of what hand pump you use. If this is a major problem, then some sort of powered compressor is probably your best option.
Any real floor pump will be far easier than even a Topeak Road Morph (maybe 3-5X less effort?) which I also used BITD and it was awesome for emergency inflation, but I would never use it as my only pump. I have a Lezyne CNC floor drive pump and have a few gripes about it, namely the slow-to-use screw-on chuck and the gauge which broke after a short while but has since been replaced. It does hit high pressures very easily, appears well-made (noting that appearance isn't everything), and looks nice.
Quoted: 6196 Post(s)
Liked 4,810 Times
The bigger the piston diameter is on any pump, the harder it will be to pump air to a specific pressure. However give the same length of stroke, they'll pump more air volume. So if you are looking for a manual pump of any sort, then that will help you make a judgement.
But what exactly get you tired on your current one? Pumping forever to get it up to pressure or the strokes get too hard trying to get to pressure?
I prefer fewer strokes no matter how hard it is to push that last stroke to get the pressure up there. So I like the floor pumps with larger pistons and long strokes.
For home use though, a powered compressor of any sort. For taking with you, CO2's good, but practice a few times before you have to depend on it. Some don't quite work so well or quite as you expect them. They are not intended for just topping off your tire pressure.
