25mm Tubeless Tire Recommendations
Old 04-01-14, 07:57 AM
soma5
Hanging On
I have managed to come into possession of a tubeless-compatible set of wheels, 23mm wide rims. I'm thinking to use them for bad weather so the idea of wider tires at lower pressures appeals to me. I'd like to hear some specific recommendations for tubeless tires, 25mm wide. Wider than 25mm doesn't appeal to me due to my (lack of) weight. I prefer tires that give me some decent performance rather than ultimate flat protection. Thanks in advance.
soma5 is offline
Old 04-01-14, 08:53 AM
Nagrom_
Fixie Infamous
Nagrom_'s Avatar
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Liked 4 Times in 4 Posts
I'm on 23mm rims, tubeless. I know you asked for 25mm tires, but my 23mm Schwalbe Ultremo ZXs measure wider than 27mm consistently, and they're amazing. I'll never ride GP4ks again.
Nagrom_ is offline
Old 04-01-14, 06:51 PM
robbyville
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times in 156 Posts
I ran Bontrager r3 tubeless in 25mm great tire good weight for a tubeless. Got about 1500 miles before swapping, would have gotten more but I did a ton of dirt roads and gravel so sealant was starting to seep from some cuts. Still never a flat. I weigh about 158-160 ran 85 rear and 80 frt. very cushy. I'm trying Hutchison Fusion 3's in 23mm right now and don't like them as much as the Bontragers which I think are constantly overlooked products
robbyville is offline
Old 04-01-14, 07:50 PM
fa63
fa63's Avatar
Bikes: A couple
Quoted: 38 Post(s)
Another vote for Bontrager R3; I have been using them for over a year and have nothing but good things to say about them. They can be expensive at list price though, unless you have a connection with your local Trek dealer.
fa63 is offline
Old 04-03-14, 10:06 AM
McFlurrey06
Bontrager R3 again. I ride them in 700x23 at 90psi (165lb rider) and I love them. Granted I am new to tubeless. They are a slick, so they might not be what you want in the rain.
McFlurrey06 is offline
Old 04-04-14, 03:23 AM
elcruxio
elcruxio's Avatar
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Quoted: 862 Post(s)
Liked 336 Times in 223 Posts
There's also the new schwalbe one which comes in 23, 25 and 28mm models. No experience yet but they are in the way
elcruxio is offline
Old 04-04-14, 07:40 AM
robbyville
robbyville's Avatar
Quoted: 429 Post(s)
Let us know how they are. They have some good reviews and I tried to get them before doing the Hutchison's but no 25mm available at the time. I also hear that they are MUCH easier to put on. The Bontrager's were tough but doable, I've never had such a hard time with a tire as I did with the Hutchison!
@soma5, have you made a decision yet?
Old 04-04-14, 08:12 AM
soma5
Hanging On
Not yet, really. I've been trying to do some reading on the various recommendations that have been made. It appears that the Bontragers are only available at Trek dealers, mostly at list price. That makes them a bit costly.
soma5 is offline
Old 04-04-14, 09:00 AM
robbyville
robbyville's Avatar
Quoted: 429 Post(s)
yeah, that's probably true. Most of the others I've looked at online are rarely discounted though. Here's a listing on ebay for 23c, maybe the seller has the ability to get you the 25's. Bontrager R3 Tubeless Road Tire 23mm 700c Tires 2 | eBay
Where are you located? I may be able to help
Old 04-04-14, 12:48 PM
soma5
Hanging On
I will look on ebay. I'm in Texas, so not very close to you, but thanks!
soma5 is offline
Old 04-04-14, 05:12 PM
robbyville
robbyville's Avatar
Quoted: 429 Post(s)
FWIW, Bontrager R2's are also really nice and a fair bit cheaper.
Old 06-11-15, 03:10 PM
Bikegeek1968
Quoted: 14 Post(s)
Sorry to revive an old thread. I have been using 25mm Bontrager R3's on RXL wheels since January. While I have not had any outright punctures, the tires themselves are porous. I am loosing upwards of 25 pounds overnight. By putting the tires in water, I can see tiny bubbles forming all over the casing. I am using the Bontrager sealant, and I can find no leaks at the valve, bead or through the rim strip. The one actual thorn puncture sealed up instantly. Are the tires not lined, or did I get a bad pair?
Bikegeek1968 is offline
Old 06-11-15, 03:56 PM
beatlebee
Bikes: i may have bike(s)
Quoted: 46 Post(s)
IRC roadlites > Fusion or Ones
beatlebee is offline
Old 06-11-15, 05:38 PM
GuyDebord
GuyDebord's Avatar
Bikes: No.22 Great Divide Disc Custom Ti
Most certainly its the tape, not the tire. You will have to re-tape the rims, put a new valve and fresh sealant. I prefer Orange Seal over Stans products.
If you want to change tires look at the Hutchinson Sector 28's. Best tire I have ever ridden on, made exclusively for the Paris Rubaix
GuyDebord is offline
popeye
Road Cycling
159
04-10-19 11:05 AM
rosefarts
Road Cycling
24
12-19-17 11:20 AM
wthensler
General Cycling Discussion
4
08-06-17 01:42 PM
bikebreak
4
12-16-15 11:11 AM
bikebreak
5
09-04-15 07:06 AM
