Front wheel vs rear - spoke count
Hi Guys,
I'm 75kgs, and live in India. Roads I ride on are largely good, but there are the occasional potholes, and a number of 'speed breakers', which I dont slow down much for. Even my carbon 56mm wheels have 24/24.
Just saw that all our wheels have 24/24. Just ordering a new LB carbon wheelset, and the default for the build I want is 20/24. Depth 46mm. I think with deeper rims, the stress on the spokes is less?
I get that the rear carries more of the weight, but doesn't the front take the majority of the assault when you hit a pot hole or the like?
What would you guys suggest?
Expired Member
Quoted: 3752 Post(s)
Liked 5,675 Times
Fewer spokes=less import duty
Quoted: 20810 Post(s)
Liked 9,456 Times
If the rear is carrying more weight, why would the front take more abuse?
Likes For deepakvrao:
Should Be More Popular
Quoted: 22689 Post(s)
Liked 9,032 Times
Likes For datlas:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Then again, most of my wheels now are 18/24, and they’ve been fine.
Quoted: 2953 Post(s)
Liked 3,106 Times
I'm about the same weight and my Williams 58s are 20/24. Rock solid and true as the day I bought them.
Quoted: 4560 Post(s)
Liked 2,804 Times
My weight varies from 66-70 kg and last year I rode 16-spoke wheels all year on some pretty bad roads, no problem. Aluminum rims, not carbon fiber. It's a 10-15 year old set of Bontrager Race Lite Aero wheels that had a so-so reputation but I've had good luck with 'em. Just now needing to replace the rear bearings but the rims and spokes are fine. Haven't even needed to true them.
I was kinda surprised. I really thought wheels needed at least 32 spokes to hold up on our roads. But well designed and built wheels seem pretty tough.
Likes For canklecat:
Quoted: 741 Post(s)
Liked 412 Times
One reason some ride higher spoke count wheels is if there is a spoke breakage during the ride, the wheel has less deflection. This seems more important for bicycle tourists and riders who get out into rural areas then the average cyclist.
Likes For colnago62:
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
With no scientific evidence to back it up, I'd say the same. Even riding on 37s @ 50psi today, hitting a couple of road imperfections jarred the front wheel quite hard. Was worried I might have broken a spoke, actually (no damage, though).
Likes For guadzilla:
Non omnino gravis
Likes For DrIsotope:
Shop owner
Bikes: alot
Lower spoke count works on the front as there is less weight over the front wheel.
For disc brake same drilling front and rear is common because disc brske load the spokes more than rim bakes. Simple maths demonstrates this.
i bet someone now posts i don't think that true- they obviously don't get the physics of wheels.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
But i could be wrong.
Quoted: 42 Post(s)
Liked 26 Times
I dont know the answer to that. If I had to guess, I would say no - seems to me that braking force is transferred more to the bike fork/stays (where the calipers are mounted) rather than to the spokes (I would expect that the hub body absorbs a lot of the braking stress, as far as the wheel is concerned) - whereas, with a rim brake, the increased friction force on the rim definitely puts more stress on the spokes.
This is old but still applicable.
Likes For November Dave:
Good thought, but it's kind of opposite to that actually. Think of how your rear hub works when you're pedaling - it transfers "go" from the hub to the rim through the spokes. This is torque. When you stop a disc brake bike, it transfers "stop" from the hub to the rim through the spokes. Also torque. That's why you don't see all radial laced disc wheels, but it works just fine in rim brake front wheels - radial is terrible at transferring torque. In a front rim brake wheel, you don't transfer the "stop" from rim to hub, you just stop the rim and that's that.
Yup. Makes sense. Thanks. Nice read.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Rim brakes exert radial forces, so add to normal riding load, and radial lacing works well. DBs are effectively hub brakes, so exert torsional forces, but the force is the same since the brakes need to scrub the same amount of energy in both cases. Although DBs can do it quicker, so can exert higher forces, and I suspect this is why a few spokes are added. From my sample of 3 front DB wheels, all three use 2-cross lacing, which makes intuitive sense.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Not 'road' bikes .
Touring 1, 36_40. & I built my own, 40_48..
Brompton Mk2 20_28 My Bike Friday uses a 24 spoke rim , and a 36 hole hub .. build skips every 3rd hole in hub..
