Spokes keep on breaking
Quoted: 18 Post(s)
I've done research on the forums other people have it. But basically I'm wondering WHY does it happen. I weigh 300 pounds. The bike Igot was a trek 3700 disc..and I replaced the back tire. I told the LBS to gimme a bette tire because I kept on brak spokes. So he came me
But every two weeks it keep on poppig
Need stronger wheels. With that weight go 36 spokes
Redheaded Stepchild
Bikes: A fat tire & a skinny tire & two others I loaned out
Yep, the wheels that come on that bike are made to handle minimal abuse. You're gonna need some stronger double wall rims.
Quoted: 3376 Post(s)
Liked 5,526 Times
Breaking spokes indicates that as the wheel rotates, the spoke at the bottom is completely losing tension, causing flex that eventually causes fatigue failure.
Solutions:
a) Higher spoke tension. If the spokes are already ~110Kgf, going higher may result in rims cracking around the spoke holes.
b) More spokes.
Solutions:
b) More spokes.
Fourth Degree Legend
Bikes: 2005 Kona Cinder Cone & 2010 Cannondale SuperSix
I'll suggest you lose some weight.
Quoted: 18 Post(s)
I am losing weight. But constantly every 2 weeks my spokes keep on breaking. I lost 30LBS this summer. What should I tell the LBS.
Double Rainbow....
Bikes: 2012 Trek/Gary Fisher Wahoo 29r Hardtail
gonna have ta chunck some money into a better doublewall rim...
Bikes: Hecklah
bicyclewheelwarehouse has some good deals on XT / MTX wheelset right now.
https://www.bicyclewheelwarehouse.com...de/cat_40.html
You could go XT / Rhynolite for about $60 cheaper
https://www.bicyclewheelwarehouse.com...-/prod_53.html
Is it just the rear wheel, or both?
200 lbs is considered heavy in cycing terms, let alone 300lbs. You may just have to get a tough wheelset built up. If your LBS can't do it try another.
Also - I had a similar problem once, the rear wheels kept breaking spokes, even though I wasn't doing anything rough. Turns out the back derailleur was bent inwards, and would smash into spokes when I was on the lowest gear of my cassette. Make sure it's not that before you sink money into better wheels that you'll just break again.
