Surly Corner Bar
Fxxxxr
Quoted: 2672 Post(s)
Liked 1,154 Times
Surly Corner Bar
thinking about this for my fixed steamroller any thoughts
Quoted: 586 Post(s)
Liked 612 Times
I found this written review to be very helpful. Pretty much all of the details are covered, including how to wrap them, etc. Pay particular attention to the "why" part of it. If you don't know why you might want to make the change, maybe it isn't for you? Only you can decide that.
https://bikepacking.com/gear/surly-corner-bar-review/
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
It's nice that you don't have to get new shifter/brake levers to see if you like drop bars, but I personally wouldn't want a bar that has a "drop" position but no "hoods" position. Even the "tops" position seems compromised by the way the bars curve downward before they hit the grip section. I like the idea, but it seems like an expensive experiment that you'll only use until you decide to get a dedicated drop bar or go back to a flat one. Nothing wrong with that, of course; re-selling should be easy.
Likes For Rolla:
Fxxxxr
Liked 1,154 Times
Quoted: 263 Post(s)
Liked 346 Times
That is a strange design. I see it's appeal as you can run your MTB brake levers and shift levers, but it looks like it is not as comfortable as normal drop bars. Also, you could stab yourself during a crash over the bars?
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Likes For SkinGriz:
Quoted: 2432 Post(s)
Liked 641 Times
I have a 26" Cannondale with some road tires and I've thought about getting these bars. I just wish they weren't steel and the tips need to be a little narrower. Even the smallest size is too wide for my taste.
Likes For Lazyass:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,045 Times
Interesting. I’ve had the RockHopper for five years and it had drop bars most of that time. Ultimately, I decided they weren’t wide enough and the cantilever and U-brake really weren’t ideal for drop bar levers.
For over a year, the MTB has been sporting touring bars, instead. The trade off is that touring bars give wide grips that reach back to the steering axis and go all the way to as far forward as hoods. They work great all along that range both seated and standing, which is important for me when riding SS. The downside is that there is no bar tops position for seated climbing, but the standing positions outweigh that for me.
If one wanted that same situation but lower, the touring bars can be flipped over. So, I’m glad to know about these but at this point I will likely carry on with the touring bars.
Otto
Otto
Quoted: 586 Post(s)
Liked 612 Times
As an aside, threads like this are very interesting to me. There seems to be a restlessness among people, always convinced there must be a better way. They search high and low to create something "perfect" whether it exists or not. And when they think they've found it, something "new" comes along that rocks their world and they begin to question whether that new "something" might make things even more perfect.
I'm not judging anyone here, I'm as guilty as any. But I'm coming to appreciate what I call "perfect enough". I try to not be lured into trying things in an attempt to create a perfect scenario. I try to resist the recommendations of reviewers who laud all of the new gimmicks. Just buy these bars and your hand pain vanishes! Use this stem and vibration is a thing of the past. And on and on it goes.
Marketers are expert at separating us from our money. Of that I am sure.
Likes For TugaDude:
Guest
Liked 3,270 Times
This is great for someone who doesn't want to overhaul their braking system while allowing more hand positions. It's nice to have the option of swapping out flats to 'drops' with minimal effort. Like most of Surly's products, this addresses a niche market.
Likes For acoustophile:
Quoted: 399 Post(s)
Liked 274 Times
Having said that...Bring Back the Fixxer!!!
Quoted: 1332 Post(s)
Liked 398 Times
I guess my hot take is that when you have a good handlebar that you like, you don't buy a handlebar that's designed around the function of switching handlebars.
As OP stated he was considering this handlebar for a fixed Steamroller - I'd say that swapping brake levers among bars on phiksies can generally be a pretty easy job, and that it is switching around shifters on gearies which is the hard part, so the Corner Bar loses most of its raison d'etre on one-gear bikes
Bikes: CCM, Kona, Rocky Mountain, Trek, Limongi, Solorock, GT
Quoted: 10 Post(s)
Has anyone here actually bought one and spend anytime riding with it yet?
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I'm intrigued about these for my flat bar ss Cross Check. Would be extra appealing to me if these also had rise like the Truck Stop Bar. Now that would be even weirder looking....
Likes For pbass:
Bikes: 1995 Specialized Hardrock / Cross Check
I'm in the process of rebuilding my Cross-Check from a riser bar with sweep to some Surly Corner Bars. They are intriguing, I've set them up with bar end shifters on the horns.
I will post a photo as soon as I can. I'm still a newbie and need to make 10 posts before I'm able to submit images here.
I've had a few short rides in between a lot of fettling while setting these bars up. Currently the bars are set at a similar height to my saddle, which isn't as comfortable in the hood position as I'd hoped and are just a little low to feel comfortable in the drop position. Since then I have moved the brakes up the horns, adjusted the saddle position, adjusted the bar angle and added a small amount of padding underneath the bar tape. This has achieved a little more comfort but the verdict is still out until i get the chance to test them on a long ride. I will keep riding and adjusting them with the current stem (a BMX stem) to see if I can find the sweet spot, but can see myself in the future swapping out the BMX stem for a goose neck stem to raise them up higher.
FYI - I'm using the 54cm version of the Corner Bar, possibly a bit wide on a Cross Check, although so far have worked out well with regards to the gear cable routing which is running along the flat bar. I also ride with front panniers so I feel the width of the bars helps the stability.
Guest
Liked 3,270 Times
Likes For Rolla:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
I ordered the corner bars in size 54cm. They were more than 700mm from bar end to bar end. Way too wide for me.
The 10cm drop is pretty substantial for a flat bar bike, when paired with the extra wide width.
The drops had too much flare for me.
If they were a reasonable width, with maybe less flare, I would have stuck with them.
Guest
Liked 3,270 Times
Bumped my head.
Im using the Surly Moloko bars. They have a cross bar, but, similar.
