Is a derailleur made for friction shifters compatible with indexed shifters too?
Quoted: 10 Post(s)
I mean the Shimano Tourney FD-TZ510-DS6 model exactly.
Thanks
Thanks
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
That one will probably work. However you might be better off getting something a bit better. An Alivio or Acera front will work better and isn’t that much more expensive.
Stuart Black
Stuart Black
Likes For cyccommute:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...the ones that work best for indexed use are the ones with some "float" on the guide (top) pulley.
Sometimes, you can make the ones without float work, but they rarely work very well. Float is side to side movement, within the pulley cage, on the bushing.
IME, the more rear cogs you have in your system, the less well they tend to work without some float.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
He’ll be fine.
Jeff Wills
Jeff Wills
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...oops.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 3,999 Times
I mean it is designed to look like a front derailleur so you could use it but I generally wouldn't spend any money on tourney and wouldn't put money towards a bike equipped with it unless in quite a dire position. For a front derailleur there are so many better options that aren't ridiculously expensive and if the bike is in such a bad state and comes with tourney save the money and put it towards the bike that will suit your needs better.
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
Maybe.
I've tried a few different friction FDs with indexed shifters and my experiments didn't work, but that doesn't mean yours won't. The older FDs I tried needed more cable pull than the index shifters delivered.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12781 Post(s)
Liked 7,696 Times
Quoted: 10 Post(s)
The bicycle is a 26" fully mountain bike
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 922 Times
It will work if the ratio of cable movement to cage movement is the same as what the index shifter expects. If you already have the FD, you can just try it.
Likes For Fredo76:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Shimano has left/front shifters in the TZ500 family that are indexed, which I think further suggests that it should work.
Likes For oldbobcat:
Quoted: 10 Post(s)
I have the derailleur. Top pull, down swing. The problem with it is that it is too hard to shift, it pulls back very hard on the cable and throws the gear back from three to two by itself. Is there any way to set it?
Quoted: 968 Post(s)
Liked 1,631 Times
I get ya...
Especially when rebuilding a bike outta the parts bin. Simplex Rear Derailleur, Shimano Freewheel, Sunrace Indexed Down Tube Shifters, Suntour Front Derailleur, Mavic Crank... Ha... Index shifting?
No Way! But at least I tried...
Quoted: 10 Post(s)
All parts of the shifting mechanism are Shimano.
Liked 762 Times
I'm not sure what you mean when you ask, "is there any way to set it?" Are you asking if there's a way to force the derailer to hold a certain position, and not allow it to pull the shifter low? In this case, your only option that doesn't involve some hacking or bodging is turning the low limit screw all the way in. This will force the derailer out to some degree. It may not get it out as far as you'd like it. Another method would involve using a piece of cable and physically securing the cable somehow (tieing it, binding it, etc.) so that it keeps the derailer in the position you want it.
