Snowfall
Not safe for work
Snowfall
It finally snowed here and I decided to try riding in the snow with my mountain bike. It didn't work out. But it was fun.
Or at least that's what I'm telling my sore bits and pieces The snow did break my falls
I hope you enjoy my lack of a snow riding skill set and general klutziness. It's a good thing the GoPro Hero 2 is quite a sturdy thing. Pretty much has to be considering my lack of snow elegance.
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
you know you can get studded tires...
Not safe for work
We haven't lived down the last time the army had to dig Toronto out of snow. In our defence, our mayor back then was a wingnut. Wait a sec, we have another wingnut mayor.
I don't think studded tires would help with thick powdery snow. I think someone needs to invent tank treads for a bike.
Still, it was fun.
Still, it was fun.
Quoted: 9 Post(s)
pretty sure this would work: https://surlybikes.com/bikes/pugsley
Quoted: 32 Post(s)
Interesting thing about fats is that they have a hard time cutting through the snow. They work great if you can ride on top of the snow.
With studs, they give you the protection from whats under the snow....aka ICE!
A tires ability to clear the snow is also important. I picked up some Nokian WXC 300's this summer(cheap) and they really do a great job. Snow is fun, you just have to figure out how to make corrections when your bike starts to wash out. Thanks for sharing.
Bikes: Scott CR1 Elite
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
Second, you need to have a firmer hand on the tiller. Watch your video carefully and you'll see that you allow the bars to wobble back and forth too much. You don't want a death grip on the bars but you want to make the bike go where you want it to. In your video, you are allowing the terrain to dictate where you are going. Be more assertive in how you steer and where the bike goes. If you shock isn't active, make it so. Don't try to ride this kind of stuff with a locked out fork.
That brings us to the next bit...momentum. Momentum is your friend. You need a little speed to get the bike to go in straight line and not follow every nook and cranny of the ruts on the road. It doesn't have to really fast but your speed can't be really slow either. There a balance that you need to find. Getting used to riding in untracked snow will help you find that balance before you go out and tackle the more technical rutted road surface.
You also seem to be riding 'front heavy', meaning that you have all of your weight over the front wheel. When riding on soft surfaces like snow or sand, a heavily weighted front wheel makes the wheel dig into that surface. That bogs the bike down and makes steering more difficult and maintaining momentum more difficult. You need to shift weight rearward to increase traction where you need it and to 'float' the front wheel over the soft surface. To do this, you need to move your weight rearward a little on the saddle and pull back on the bars. You are going to pull a small wheelie...we're talking fractions of an inch... to lift the front wheel up to the top of the snow. Learning to ride in sand helps. You have to do this wheelie action almost constantly when riding in snow or sand.
You don't need studs for this kind of riding. Studs are good for icy surfaces but for snow they really aren't required.
Finally...and I can hear the howls of protest now...attach your feet to the pedals. Sand and soft surfaces are all about traction and smooth power. When you can only push the pedals down, you aren't getting smooth power out of your pedal stroke. Pulling up on the pedals can help smooth out the stroke and also provide a way to finesse the rear wheel. Toe clips or clipless pedals don't really matter but having some way of keeping your feet going around works wonders. I also find that when my feet are attached to the pedals...I prefer clipless because they are easier to get into...I try to ride through stuff where I might dab (put my foot down) on a platform.
Finally, your bike looks very new. I assume that you are new to mountain biking. Mountain biking is a much more dynamic style of riding than road biking. You, as the rider, have to move your body more than on a road bike. Try countering the bikes movements by you, the rider, as needed. I'd suggest taking the bike to a park where you can find some untracked snow and learning how to ride there. Then try tackling the streets.
Stuart Black
Stuart Black
Nokian 160 stud Mt & Ground W, a 1.9 wide 26" work well on mixed ice and bare pavement..
bought mine in '92.
bought mine in '92.
Quoted: 5224 Post(s)
Liked 3,585 Times
cyclokitty ~ so that GoPro HERO2 makes MPEGs? That's good for Windows or MAC, right?
Not safe for work
MPEG4 files and it's compatible with both Windows & Mac. I upload and edit with iMovie. The Gopro site also has an upload and editing program for free. I haven't tried it but it is available for Window & Mac systems. The camera is silly easy to use.
Not safe for work
My attempt at snow cycling was a lot of fun. The snow was still quite soft and fluffy (and I only have a few bruises) and it was just a fun try at riding thru fairly fresh snow with my still pretty new bike (name TBD - I'm leaning towards "Raw Steak" because what the pedals have done to my shins ).
I'm planning on buying a pair of studded tires and I'm thinking of the Marathon Winter studded tires. Hopefully the next snowy ride will stay upright.
