Lubing shift levers (Simplex 543 content)
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 643 Times
Well, Cleaning up and reassembling this lever for the Simplex 543; wow, actuation seems really gritty and difficult to imagine getting clean, smooth shifts.Hmm, it is indeed very old, and no lube at all in here. So, where on this chart would one grease it? Part 651 is a fiber material, by the way, somehow don't get great on that (thoughts?) So, perhaps great between 494 and 129, and between 472 and 137 (why there are two 137's, I do not understand, but there they are!) I guess this is also a general question on lever assemblies, what do you lube and what to leave alone as "friction shifting" implies, well, friction.
And lucky me, down in the bottom of a box I found item 920, I thought it was gone forever and I planned on fabricating a "splitter pinch bolt" out of a derailleur or brake pinch bolt. Whew!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
I would not lubricate anything in the shifter assembly - just ensure everything is really clean. I would look further down the line - I’d lube the shift cable where it’s inside the cable housing for sure. Also lube any pivot points in the rear derailleur itself. Make sure your cable routing is meticulous to reduce any friction points.
Quoted: 1143 Post(s)
Liked 1,758 Times
I agree with the above, I would clean and possibly polish for smoother surface. I do try to stay away from lube in cables housing, but when I do I try to clear the line afterwards. Reason being the lube will thicken after time, glob and dry up making the shifting stiff.
Quoted: 987 Post(s)
Liked 643 Times
The lever assembly is not even on the bike yet. Alas, there's a beautiful black/silver/gold badge on the end of the thumbscrew knob, but the orientation is upside down and I do not see a way of "indexing" that... yet. But the ivory-color knob itself responded well to Nexus plastic polish, so it's pretty. Just not as smooth as I'd like. Rear derailleur is lubed, no real pivot points as it's a pushrod unit.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
I always apply a very thin application of grease to shifter parts ... except for the bolt threading.
Quoted: 4806 Post(s)
Liked 3,933 Times
I do the same - except the two matching friction "washers". Metal to metal contact on moving parts wear out. Granted, not fast on a "wheel" that will turn, what 100 revolutions in the next several years but still ...
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I've re-hab'd over 100 vintage bikes for sporting use here in the ever-rolling foothills, lots of shifting required.
I always lube all of the moving parts inside of a shift lever, it makes a huge difference in some cases.
Oil or grease is fine, though I avoid "super" greases that tout Teflon or lowest friction.
For the Huret tubular macaroni-tube cable guide, grease is good, but getting a piece of appropriately-sized plastic noodle to line the tube definitely makes it work even better.
I've said it before, using modern techniques/materials to improve the run of cable between shifter and derailer is the best thing that ever happened to friction shifting.
So I'm fussy about my friction-shifted bike's cabling, like I said, here in the foothills one has to shift very often, and keeping up with the modern-bike crowd means exploiting modern technology, cable housings, chains and freewheels (UG for me) and careful setup (fully-lined cable path, shortened housings, and any needed modifications to reduce chain gap).
Likes For dddd:
Quoted: 987 Post(s)
Liked 643 Times
EDIT: what about this stuff? LINER I measured, inside diameter of Huret tube is 2.7mm, this stuff is 2.6mm. So far so good, no idea if I can insert it... and would it slide back out? Or glue it, I presume. And four meter of the stuff and I need perhaps two inches.
Quoted: 987 Post(s)
Liked 643 Times
Seems smooth enough, and have the Simplex 543 catching 5 of the 6 cogs even without the second shift cable hooked up.
Quoted: 987 Post(s)
Liked 643 Times
I've re-hab'd over 100 vintage bikes for sporting use here in the ever-rolling foothills, lots of shifting required. (SNIP) For the Huret tubular macaroni-tube cable guide, grease is good, but getting a piece of appropriately-sized plastic noodle to line the tube definitely makes it work even better. I've said it before, using modern techniques/materials to improve the run of cable between shifter and derailer is the best thing that ever happened to friction shifting. So I'm fussy about my friction-shifted bike's cabling, like I said, here in the foothills one has to shift very often, and keeping up with the modern-bike crowd means exploiting modern technology, cable housings, chains and freewheels (UG for me) and careful setup (fully-lined cable path, shortened housings, and any needed modifications to reduce chain gap).
Quoted: 1609 Post(s)
Liked 2,216 Times
@tiger1964 I have not had any movement on mine. Some have suggested hot glue, good enough without being iffy!
Quoted: 987 Post(s)
Liked 643 Times
Worth a try, and I have a hot glue gun - just need to get the bike stand to hold the bike inverted but lower than the ceiling. Hot glue ain't willing to run uphill.
Hello,
Did you finish setting up the 543? After looking for one for a few years for my 1955? Peugeot
1955 Peugeot PHX PLX (fattiretrading.com)
I finally found one. So, I am now very close to getting it on the road. I think that I have the right shifter. I think that I need part number 920. Do you have a picture of it?
Thanks!
Chris
Thanks!
Chris
Quoted: 987 Post(s)
Liked 643 Times
Hello, Did you finish setting up the 543? After looking for one for a few years for my 1955? Peugeot 1955 Peugeot PHX PLX (fattiretrading.com) I finally found one. So, I am now very close to getting it on the road. I think that I have the right shifter. I think that I need part number 920. Do you have a picture of it? Thanks! Chris
I do not have a photo of the lever I am using right now, I'll see if I can take one soon.
Other non-bike priorities has left the bike on the stand after 1-2 rides. Pretty nice ride but (a) still not getting all 6 gears and if I cannot find a narrow enough freewheel, I might give up and get a 5 speed, and (b) still an issue with getting the correct lever friction that allows shifting but does not slip (and, as you know, into a LOWER gear). Having two cables attached to two springs I presume puts more demand on the lever's friction assembly.
