Best Touring Multi Tool?
My friend recently managed to lose my 4 year old Topeak Alien II on a train ride in Vietnam. I ended up buying a cheap Vietnamese tool but its not great and I need something more substancial. Here are my criteria:
Reasonably light and compact- The Alien II was a tank and had lots of flex because the body was plastic....
Chain tool- I have broken a chain while on tour and this saved my bacon
Pedal wrench- This one is tough.... The pedal wrench on my Alien II was an absolute joke. Piece of crap! It worked but just barely. I would like something better but its hard to find a tool that has a usable wrench. I travel with the bike on airplanes, trains, and buses a LOT! Maybe I should just find a pedal that I like that have a hex key on the back? Any ideas?
Should have lots of tools!- I am not that mechanically inclined but I often tour in the developing world where bike specific tools are hard to come by so the one I carry should have 90% of what I need on it.
What do you all think? I imagine that the pedal wrench requirement is the hardest to fulfill. Should I search for new pedals that dont require a wrench, or maybe I could carry a separate, travel size pedal wrench?
I was looking at this new Knog 20 tool which seems to fit a lot of my requirements but the reviews are not so great. They say its hard to use because of its small size. What do you all think?
https://road.cc/content/review/15305-...ion-multi-tool
Bikes: Co-Motion Mocha, Fuji touring, Trex hybrid, Bike Friday Tandem Traveler
The Knog 20 looks terribly clumsy to use. Haven't used one, though.
Just found this one: https://www.parktool.com/product/rescue-tool-mtb-3
What tools do you take with you? Maybe I could find some kind of a small adjustable wrench, a separate set of allen keys, and a chain tool and call it good? I dont think I would need much else.
eternalvoyage
The allen keys can be light, and they come in different lengths. You can find very small wrenches that fit 8 and 10mm, or 6 and 8mm, etc. They are light and effective. I found them at a place that sells a mix of new and used tools. They had a bin of these wrenches, and they are by far the best I've found. They are tiny, yet some of them are very well made. They look like miniature versions of the Craftsman wrenches.
I just put all these small tools together in a small pouch -- it's light and small, and I like this arrangement better than the multi tools.
Some bike shop mechanics told me that the multi tools are not as good or as versatile as the separate tools. I tried both, and they were right.
Bikes: Cannondale F2000, Co-Motion Periscope Torpedo, and many more
I have a Crank Brothers tool which is decent: https://www.amazon.com/Crank-Brothers...cmu_pg__header
But I also carry individual tools for the most common size allen wrenches (4, 5, and 6) and a small adjustable wrench. You might consider an adjustable wrench large enough for pedals as an option to a traditional pedal wrench. The small adjustable wrench will work as a spoke wrench in a pinch as well.
I also carry an older leatherman (don't know which model) which gives me a knife blade, pliers, and most IMPORTANTLY a cork screw!
For long distance travel in remote areas I'd also suggest carrying spare spokes which will also probably require carrying a freewheel tool and some sort of wrench large enough to grab onto the freewheel tool. If you break a spoke it is inevitably on the rear drive side which is the side that requires pulling the freewheel to replace.
Every day a winding road
Also you'll probably need a flat or phillips screwdriver for derailleur adjustments
For tours in remote areas also consider replacement spokes which will require a spoke wrench or small adjustable wrench and a freewheel tool and wrench large enough to use it.
Around town, I carry a multi-tool (Crank Brothers Multi-17?) and a cell phone.
On tour, where I want to be as self-sufficient as possible, I carry real tools. The Park CT-5 chain tool works well and is relatively light-weight. Their SW-7 triple spoke wrench is also small and light. If I didn't care about being able to help other tourists, I'd carry one of their four-sided spoke wrenches in the size I need (SW-40). I carry full-sized metric Allen wrenches in the sizes I need: 4mm, 5mm, 6mm, and 8mm. I also have a magnetic bit screwdriver that stores a bunch of bits in the handle. My Leatherman tool serves as pliers and wire cutters. That plus a few spares (tubes, tire boot, patch kit, brake cable, derailleur cable, chain lube, FiberFix spoke repair kit, master link) should get you through most problems you're likely to encounter.
I'm in the separate tool camp, Bondhus (ball End) Allen wrenches, in plastic holder..
My 8 and 9 are Snap on, as is the 10, short version . combo open and box end .
& other stuff .. the Multi tools are too short for decent leverage.
I have Kept my old Park short 32 / 15mm wrench to remove and replace pedals , packing.
and have a threaded 1" headset so the big end has already come in handy, too.
Quoted: 599 Post(s)
Liked 284 Times
Which ever multi tool you might decide on, make sure that the allen wrenches separate from the tool individually because there are times when you might need to get into a small area and the multi tool won't allow you to get the wrench into tight spots. I was at a bikers camp one night when I overheard more than a few choice expletives. I asked the fellow if I could help and he showed me where he had broken a piece on his rear rack but he couldn't get at the bolt in order to get it out with his multi tool. That was one occasion when a traditional L shaped wrench came in handy.
Bikes: LHT
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I also have carried full size tools in the past, and on my Raleigh bikes carry a Leatherman and an adjustable wrench. The multi tool is supposed to be for emergency repairs to get you home. I do regular maintenance checks on my bikes and seldom have problems along the roads, most of the time the tool is used to bail someone else out. YMMV.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Quoted: 3462 Post(s)
Liked 1,469 Times
For touring I only use pedals that can be installed and removed with a separate long armed 6mm Allen wrench. Sometimes I put my foot on the wrench to remove pedals, I do not want to stress a multi-tool that way and a multi-tool that folds is harder to use for that purpose.
Thank you for reminding me that the Alien has a pedal wrench, I had forgotten why they included that wrench.
Several years ago I bought a Blackburn multi-tool that had almost exactly the same features of the Alien II, but no pedal wrench. I already had the Alien II, but the Blackburn had a clearance price that was screaming take-me-home so I got it as a spare. The Blackburn also has a tiny pliers and a little piece of wire that could be used to hold the ends of the chain together while you used the chain breaker or removed a master link. For the last couple tours I carried the Blackburn because of the pliers instead of the Alien II. I just looked at Blackburn website, no longer available, sorry.
Since the big multi-tool (Alien, Blackburn) is usually in the bottom of a pannier, I carry a small tool with 5 or 6 tools in a pocket for minor derailleur adjustments, brake adjustments, etc. Something like the Toppeak mini 6 can come in handy for those 15 second adjustments.
Also carry a few other tools, the list varies over time. And my two touring bikes have slightly different tool needs.
Many reasons. Such as to pack the bicycle for transport on an airplane, train, or bus. To assemble the bike once you reach your destination on an airplane, train, or bus. To put a pedal that has fallen off back on, which is admittedly rare but it happens.
Goes to 11.
Bikes: 2015 Soma Double Cross
In that case, I'd recommend a sacrificial 15mm cone wrench, such as Park's cheaper DCW-2. If you have a threaded headset, Park also sells a combination 32mm/15mm open-ended wrench in a compact size (though I can't find the model).
Many pedals also have a hex socket on the inboard end of the spindle, which negates the need for a pedal wrench altogether.
My multi tool of choice.
Aaron
Aaron
Or if the dang thing is just creaking and you don't want to listen to it click and creak for another 500 miles.
Yup, this happend to me in Tibet, of all places, where it was dead silent except for the sound of my damned pedal! I got it tightened down once I reach Kathmandu and 1,000 miles later >
https://bike.shimano.com/publish/cont..._mountain.html
Bikes: Surly Steamroller, Cannondale CAADX, Niner EMD, Cinelli SC (1965)
I personally don't like to carry more than my bike requires. Aside from large multi tools being lower quality overall, they carry a lot of excess bulk that you don't need. I tour on an 80s steel road bike, and carry a small Slime multi tool (park makes one nearly identical) that has 3.5, 4, 5, 6 hexes and a flat and Phillips screwdriver. I also pack a small chain tool (Park ct-5, far nicer than most multi tool chain tools), a spoke wrench, an adjustable wrench, a small vice grip, and 8 and 10mm box wrenches since my older bike has them everywhere. Add in tire tools, some spare parts, and a backpacking knife, and that's my set up. This set up might change depending on the bike and what specific tools it requires.
As far as pedals; find a pair with a 6mm socket on the back. Many clipless are like this, and flat pedals with them aren't too hard to find. This will greatly simplify your tools and save a good bit of weight. Trying to take off pedals with a small adjustable wrench or a cone wrench can be a nightmare if they're really locked down.
