Ultegra to GRX.. yeah, another thread
Quoted: 479 Post(s)
Liked 277 Times
I figured, why not a 64th thread on the topic (kidding, there are probably more). I even started a thread a while back asking for suggestions on how to upgrade to get more gear, and can't even find my own thread. But this question is more specific... I think.
I have an Ultegra 8000 2x - 50/34; 11-34 drivetrain. That's just not enough gear. Example: this weekend's ride - 50 miles, 6,000' of climbing had me in the 30-40 RPM cadence a few (okay, several) times.
I know I can push Shimano's conservative limit and run an 11-36 cassette.
What, if any, benefit will I gain just swapping the rear derailleur for a GRX? Will that allow me to run a 40t?
Thanks!
(and sorry for another version of a familiar thread)
Thanks!
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Have you considered going to a GRX 46-30 crank instead? Cost might be close to what you would pay for a new RD and cassette.
Likes For shelbyfv:
Quoted: 6972 Post(s)
Liked 10,968 Times
Yep. I believe there is a 46-30 and a 48-31. But they require the use of the GRX front derailleur which is designed to work with the cranks, which sit outboard a few millimeters further than other Shimano cranksets.
Likes For Koyote:
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
Thanks!
Thanks!
This has a total capacity of 40t, and your hypothetical setup of 50-34 and 11-40 has a total capacity of 45t, which is too much(even when considering Shimano's known conservative numbers).
The GRX RX812 rear derailleur is a 1x RD with a 42t max large sprocket.
It is 1x and not 2x. And it only have a total capacity of 31t, which helps confirm it is not designed to handle a 2x drivetrain like what you have.
Others have suggested using one of Shimano's GRX cranksets since they have smaller chainrings. This would help solve your issue(and you could pair it with an 11-36 cassette to help even more). As mentioned though, the GRX cranksets sit further out from the centerline of the bike frame and so you need a GRX FD too.
Alternative options to the GRX crank are offered by Easton, Paul, FSA, Praxis, and others.
I will suggest Praxis specifically since that is what I have on my main road bike, one of my secondary road bikes, and my gravel bike. I really like the look, easy setup, and performance of the Zayante and Alba cranks.
Praxis makes a 48/32 crankset option and it is designed with a traditional road Q-factor so it doesnt sit further out from the centerline. This means you would keep your current front derailleur and you would not have a wider crankset.
Rolling on 40mm tires...
Your current setup of a 50/34 crank with 11/34 cassette gives you a gear inch high of 125.75GI and a gear inch low of 27.64GI
Your suggested 50/34 crank with 11-40 cassette(which wouldnt work due to the 1x RD) would give you a gear inch high of 125.75GI and a gear inch low of 23.49GI.
A 48/32 Praxis crank with 11-36 cassette would give you a gear inch high of 120.50GI and a gear inch low of 24.60GI.
So looking at those numbers...
- A 125 GI on the high end is really quite large(what you currently have). For context, a road bike with 28mm tires and a 50-11 combo is only 121.45GI. So you are currently rocking a setup that has a high end ratio that is larger(tougher relative to cadence) than a commonly set up paved road bike. You could easily drop down to a 48t large ring and not give up anything at the high end since it gives you basically the same high end as a typically geared road bike rolling on 28mm tires.
- A 32/36 low is quite low. Is it low enough for you and where/how you ride? No idea. But it is over 4 gear inches smaller than your current set up, and that is significant at the low end.
For what its worth, my gravel bike has a 48/32 crank with 11-36 cassette. The Ultegra RX RD and 105 FD shift it all just fine.
Quoted: 479 Post(s)
Liked 277 Times
damn guys (mstateglfr!) this is awesome!
On the big end, I totally agree - I don't need more. The only time I'm in the 50/11 is on noticeable downhills - and a tuck is imminent. I like the idea of the Praxis (or other) crank - 48/32 - to start and probably an 11-36 when the current cassette is toast... or if the 32t small ring still doesn't feel like enough.
Time to start shopping for parts!
Related question: any idea why Praxis (are they alone?) doesn't go longer than 172.5mm on the gravel cranks?
Expired Member
Liked 5,437 Times
A couple of additional points as you begin shopping. A GRX crank can use your existing bottom bracket but you'll likely need a different one with another brand. Also, check the chainline. Some may be extended like the GRX (47mm) some may be more standard like your Ultegra (44.5mm.) If extended you'll probably want the GRX FD, regardless of crank brand. Folks have reported using standard FDs with GRX cranks but there are bike specific variables so trial and error. FWIW, my new Cannondale was spec'd with a GRX crank but showed up with an FSA. Has a GRX FD. I Googled the crank and found it has the same chainline as the GRX. Works fine, just a little disappointing. I guess C'dale saved a buck or two.
Absolute Black makes 48/32 and 46/30 oval chainrings that fit standard shimano road cranks like yours and you don't need a GRX FD. They aren't cheap though. I'm running the 46/30 on my 5800 cranks on my road/gravel bike because I wanted to keep the tighter 11-32 cassette for road but needed the 30 up front for the super steep gravel/mtn bike climbs around here. The GRX setup wasn't around when I did it, today I'd go 48/31 GRX crank for a better mix of both high and low gearing.
Sunshine
Liked 7,491 Times
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I use a GRX 46/30T crankset on my otherwise Ultegra (Di2) drivetrain (including front derailleur). It works (at least in my case, might be worth a try in yours).
I also have a GRX mechanical front derailleur on an otherwise non-GRX drivetrain on my touring bike. Nothing exploded.
Liked 3,443 Times
https://praxiscycles.com/product/alba/
This lists 175mm 48/32 as an option.
Quoted: 479 Post(s)
Liked 277 Times
I run a GRX 812 rear derailleur with 46/30 crank and 11-42t cassette. I swapped out the GRX derailleur cage for a XT SGS (long cage). The low end gives me 19GI on 650b x 40 tires . . .
Likes For sdimattia:
I think the Ultegra RD-R8000 will actually work with an 11-40 cassette in most cases (though adding a RoadLink may sometimes be necessary). Swapping to a 46/30 crank is also appealing, but the adjustment range of braze-on FD's on many road bikes isn't enough enough to work with chain rings this small.
Quoted: 1248 Post(s)
Liked 1,323 Times
Swapping cages within Shimano is a game changer and reasonably cheap. I also put a Ultegra cage on my Di2 R9150 rear derailleur and run 11-36 perfectly.
Quoted: 479 Post(s)
Liked 277 Times
I landed on a blend of the suggestions:
- GRX Crank - 48/31
- GRX FD
- 11-36 cassette
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
- GRX Crank - 48/31
- GRX FD
- 11-36 cassette
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
I don’t think you’re too far off. You might not want to get extreme.
I began “gravel” with 28mm road tires and 50/34x12-29. I definitely bogged down a bit but not as often as you’d guess.
Over the years I’ve experimented with some other ratios on purpose built bikes, always right around 40mm tires.
40x11-36 seemed nice but flat out kicked my ass on the White Rim. Probably added a literal hour or more to my day.
40x11-42 seemed okay (roughly equivalent on the low side of you getting an 11-36) but I did spin out with a tailwind, a problem your setup won’t have.
On my new bike I went to 40x10-44 with a contraption from Wolftooth. I’ve literally never wanted more. I’m not bike packing but I’m not avoiding anything steep, between Colorado, Utah, and Central Oregon. 2 more teeth and the suddenly I’m in a sweet spot.
Realize that this bike purchase was pretty close to when I got my mountain bike, so I stopped riding hard single track on the gravel bike at around the same time.
Then, just as an experiment, I swapped to an oval chainring, 42t. Due to all the purported benefits, I actually haven’t noticed any difference between it and the round 40. Two free teeth, science!!
All that said. Given your current drivetrain, I’d get the Absolute Black 46/30 rings and ride them for a couple rides. If you’re still lacking, an 11-36 is very easy to add.
Likes For rosefarts:
Quoted: 479 Post(s)
Liked 277 Times
Parts arrived and swapped over. I did go with the GRX 48/31 and 11-36 cassette. I haven't hit the trail yet, but did spin around my neighborhood - very hilly neighborhood. On the steepest hill, I was pleasantly surprised that the 31/36 was definitely low but not that chain's-off spinning kinda low. It felt like a great bailout option for those rides where you bit off more than anticipated and you just need to get over that last peak to get to the car.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Near where I live there is one steep paved MUP with an adjacent gravel track, so they have essentially the same slope. On my (105) road bike I can make it up on its lowest 34:28 ratio but on my (GRX) gravel bike I need its 31:30 and sometimes even 31:34. My conclusion is that I am weak as heck and I definitely need lower gearing for gravel than for road.
When I installed my 46/30 chainrings I figured I wouldn't use my lowest gears on the road anymore, I was wrong lol. I use my 30f/32r pretty much every ride. Just allows me to get up the hills at the same speeds as my 34 chain ring but now I can do it at a higher cadence and my legs aren't dead at the top.
Likes For Canker:
Quoted: 427 Post(s)
Liked 339 Times
We have one customer running a GRX rear derailleur with a double crank and Ultegra front derailleur and a 40-tooth cassette with a Wolftooth link to lower the derailleur to accommodate the bigger sprocket. This is on an older Warbird and may not work on every bike, but it works perfectly on his bike. This is one of those things you have to try to see if it will work or not on your own bike.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I like to post a link to this video on GRX threads. I used the advice given on my own bike and had very good results. I'm currently running GRX Di2 with a 48/31 crankset and 11-40 XTR cassette and using the wolftooth10 link. Check it out...
https://bikepacking.com/gear/wide-range-grx-2x11/
Likes For Bryan C.:
I purposely went with GRX 48/31 crank an 11-34 cassette on my road bike since I am a senior citizen. I do not regret it one bit. I may not use the lowest gear all the time but its there when I need it. Glad I did...
Liked 1,471 Times
When I become a senior citizen, I think I will go for a 14-28 junior cassette and if necessary, the cheaper GRX 46/30 chain rings.
- GRX Crank - 48/31
- GRX FD
- 11-36 cassette
