Worth replacing cones?
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times
Hi,
I can't get the Deore front hub on my commuter adjusted to run free without excessive slop and I assume it is trashed. The best I can do is intermittent binding and an annoying click. I have no desire to replace it and I haven't cleaned it out for a real inspection. However, the cones are cheap and my question is would it be worth ordering and replacing them on the theory that the races aren't completely buggered?
Thanks.
Thanks.
It takes 5 minutes to pull a front Shimano hub apart for a peek. The total operation of replacing the cones and balls, relubing and reassembly takes about 15.
it takes an extraordinary amount of abuse and neglect to kill the cups pressed into Shimano hubs. The cones and balls go well before this.
Bikes: Shmikes
Liked 5,843 Times
Really Old Senior Member
Maybe you have a bent axle?
Bikes: Shmikes
Liked 5,843 Times
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Hi,
Thanks.
Thanks.
Open it up and clean it and inspect it. If the cups are pitted the hub is shot. The cones and bass can be replaced. If you do regular maintenance the hub will outlast the rim.
I overhaul mine every 2500 miles.
Also check the dustcaps. They can lead to similar symptoms if distorted or not seated properly. Specially if they are metal.
Quoted: 86 Post(s)
Hi,
Thanks.
Thanks.
my advice is to service the hub and replace the ball bearings and see how it goes. while at it, inspect the cones and races.
Of course you also can buy cones for $20 a piece and then what, you still don't clean the and inspect and install them in old and dirty grease?
Quoted: 2026 Post(s)
Liked 1,095 Times
Any chance the number of bearing balls in one or both races is incorrect? Too few or too many?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Should I buy replacement parts for a hub I haven't inspected?
Should I adjust the cones on a hub without opening it up, inspecting, replacing bearings and grease?
NO to both.
NO to both.
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
Personal experience with Shimano hubs... worth every penny to pull it apart and replace the cones and balls. Both are cheap and I've had Shimano hubs last decades without damage to the cup race. The only time I've given up on replacing cones was when I ran into availability issues with pre-built Ultegra wheels. Even then, I started looking for similar part numbers from the EV sheets to try to find replacements.
Quoted: 101 Post(s)
Liked 49 Times
Cup and cone hubs are highly repairable and rebuild-able. Take a look, may just need balls and cleaning. If it needs cones, that's not a big deal either but should remind you to not let them go so long without service next time.
Still stupid and seriously neglected..
