American Classic seatpost -- red cap?
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 436 Post(s)
Liked 3,471 Times
Inspecting and cleaning a recently acquired, lightly used 1987 Cannondale Black Lightning.
Original seatpost is an American Classic 27.2
There is a soft plastic red cap inside the post just underneath the seat clamp (see photo).
The nipple will deform and return to original position with a light press.
And because I wasn't slapped or kicked after the first time I touched it, I figured it was OK to repeat that action about 10 more times.
I've found a few things crammed into seatposts (e.g. spokes, paper currency) but haven't seen one of these before.
I found an image of it online and in a separate old BF thread to believe it's original equipment, but haven't found an explanation as to its function.
So, is it protecting something? If so, what?
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Quoted: 436 Post(s)
Liked 3,471 Times
I thought the same as you initially, but I discounted that because most seat posts don't have any cap (or even had flutes), even those made during the years when steel frames ruled.
And also, why would a water protecting cap not cover the entrance at the top of the seat tube. Because it sits below the entrance, it creates a space that can only serve as an open reservoir for water.
I want to believe there's more to it than simply water protection.
Quoted: 1829 Post(s)
Liked 3,376 Times
I've got a few of the American Classic posts. There are at least two versions of this general arrangement. The first is machined out of a single piece of material, hence the hole bored all of the way through.
My examples of the first generation style have a black plastic(?) plug in the same location, although the plug is more flush with the top, and probably less prone to collect water. There seems to be some sort of sealant around the plug too....
Later versions had the head machined out of a separate piece and then glued to the top of the shaft. This version doesn't use any plug....
edit/addendum: I first got one of these 1st gen A.C. seatposts in 1989. It's very possible that the earlier 1987 design did use that red cap, and that the manufacturer later changed to the plug shown in my first photo to correct for leakage issues.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Quoted: 237 Post(s)
Liked 83 Times
Most seat posts, sans cheap seat pillars with a separate clamp, don't have an exposed hole like that. Most posts have flutes above the clamping area, or at least have an end point. I only recall seeing BMX posts with full length fluting.
Likes For Kuromori:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Looks like a repurposed protective cap a previous owner stuffed in there.
They are used in their first purpose for things like protecting threads in shipping. I keep a coffee can full of thes, both internal and external for plugging holes, protection, making grommets, or whatever use I might find for them.
Likes For dedhed:
Quoted: 436 Post(s)
Liked 3,471 Times
Steve in Peoria
Steve in Peoria
You all make good points. Thanks.
Part of me wants to see what's underneath the red plug/cap. The other part says leave it alone and don't pick at it.
Here's a link to an old BF thread in which the OP was concerned about the quality of the AC seat post: https://www.bikeforums.net/classic-v...-use-lose.html
You can see the red plug in a post 1 photo and a comment in post 17 from another BFer having the same part. I also saw another image of the red plug/cap somewhere online, but can't find it now.
This would be a huge coincidence for it not to be original to that post.
You're all probably right about the water prevention thing. I'll let it go.
I had a first generation (purchased new) that came with the red plastic plug. Word of warning: The lower part of the saddle clamp on the first generation ones are known to crack. These are the ones that look like they're stamped steel. I cracked mine (after about 30,000 miles). Thankfully not while riding, but while torquing it down to A.C.'s spec.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Or a button that has a sign that says "do not push the button."
Or a package of Charmin.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Quoted: 436 Post(s)
Liked 3,471 Times
By the way, did you ever remove the plug? If so, what's behind it?
Liked 1,703 Times
Never did, but you don't have to. I saved the shaft part of the post. I use it to test 27.2 frames before I put a new post in. Here's a picture of the plug from the top. I never messed with it. So, this is the original position.
It just covers a hollow shaft. Here's a shot from a proctologist's point of view.
One last recommendation. If you do use the post, they also tend to creak. If you wrap the threads on the set screw that adjusts tilt with Teflon tape it won't creak.
Likes For gearbasher:
Quoted: 436 Post(s)
Liked 3,471 Times
Well yeah, I could have removed the seat post too, but where's the challenge in that?
Seriously thanks!
I can't believe how many times I've felt foolish in this thread....sigh.
I'll blame it on the earthquakes. Yeaaahh....it was the earthquakes....that's the ticket.
Seriously thanks!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
