Soooo there is 20 minutes down the drain...
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
I was fooling around with my "Cherry Tomato" SBX framed Bianchi and I dropped a part of the Bell handle bar bottle cage mount. I'd swear I heard it jingle across the floor but didn't see where it as my attentions was focused elsewhere. So after looking around for it, moving some stuff, getting a flashlight and moving the stuff again I gave up. It wasn't too important I figured I'd eventually find it.
So when I went to move the bike back viola! there is was just hangin out
Sugar "Kane" Kowalczyk
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
Half hours on earth
What are they worth?
I don't know.
Dropping, searching and cursing
Happens to me all the time.
I don't know.
Likes For SurferRosa:
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
Best thing I did when fixing up my work bench to make it, well, work better was to install a kick plate to close off the space between the bottom shelf and the floor. Now things don't bounce/roll under the bench and get lost in the dark cobwebs and sow-bug carcasses against the wall. I save the 20 minutes it took to cut and fit it every time I set foot down there.
Few weeks ago I brought some tools and fasteners to my son's house to do some work on his bike. They have a deck that sits on the grass made up of boards separated by gaps of 8 mm or so (at grade, not up on posts.) Well, you know what happened despite my best efforts to hang onto things extra carefully. Fortunately every time I dropped an Allen key it fell across a gap and not through one.
One of those little magnets on a telescoping rod that looks like an old-fashioned car-radio aerial is really handy.
Likes For conspiratemus1:
Quoted: 5888 Post(s)
Liked 3,471 Times
I sometimes think the most important thing I learned working in a bike shop was to watch where stuff went when I dropped it. It's amazing how much time and frustration that can save you, .
Likes For bikemig:
Bianchi Goddess
Liked 2,927 Times
All too familiar for me too. I swear I'd put down a tool and it would just disappear somehow. Minutes later it shows up EXACTLY where I thought I originally put it. Must be elves in my workshop.
Likes For Sophylong:
Edumacator
Quoted: 2440 Post(s)
Liked 3,129 Times
Quoted: 796 Post(s)
Liked 522 Times
my non-telescoping magnet is and old bike computer wheel magnet which is awesome for removing hub bearings
Likes For ryansu:
Bianchi Goddess
Liked 2,927 Times
OH also at one point I reached into the 3mm allen wrench slot, with 4 or 5 wrenches in it, and what do I pull out? Yes the only 3.5mm I own
Same problem BG! I only hear out of my left ear so with my bad eyesight, everything sounds like it took off to my left! 50-50 chance there of success...
Glad you found the piece.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I used to work in a shop with a terrazzo floor. You learned after the first drop not to take your eyes off the errant piece if you ever wanted to find it.
Likes For thumpism:
20 minutes doesn't sound that bad .... Magnets save me so much time in the shop and I always sweep the floor before starting a new project , But still no solution for tools I have used and put down or in my pocket.
Quoted: 1372 Post(s)
Liked 1,752 Times
Wait until you are my age. I can be holding something in my hand and still wonder where the heck it is. And, I something does drop, I can't see where it went unless I had time to switch from close up to normal glasses. And, if I did see where it went, when I start looking, I will not remember what I am looking for.
As for the telescoping magnet. I cannot find mine and it was/is a beauty...
Likes For randyjawa:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
With floors that act as excellent camouflage, I sometimes have better luck finding small parts by putting my face right down next to the floor and looking sideways.
Invariably this is when my wife walks in behind me and remarks "that's not a good look for you."
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Now, as I grow older, my fingers get clumsier and less-able to hold onto things. I drop a lot of stuff, but I use my old techniques to find it.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I've temporarily lost parts to the spokes and even to the front derailer. Wasted at least ten minutes each time.
One thing that is my go-to for such searches is a good, bright bike headlight.
And I've learned to record in my head the exact sequence of sounds that goes with any parts-drop!
I once was working on a friend's 1980 PX10 and had the brown plastic adjuster knob on the brake lever launch as I pulled the cable out of the ferrule socket.
In sequence, it hit the ceiling of my apartment's outdoor upper level, then down to the cement second-floor surface, then up and over the wall, down onto a lower-level sidewalk, and bounced into "one of" the planters. I heard it all.
I searched for almost two hours for that rare part, but my friend later found it in just two minutes after I fully described what had happened, his eyes being about 25 years younger than mine.
What a memorable relief!
get some mechanics mats: then the parts get caught in the small holes when they fall.
Likes For jetboy:
Time to confess!!
How many people dropped a bearing and after a 20 minute search, purposely dropped another one just to see where it goes? Of course, that was done hoping it would end up near the first one.
Likes For gearbasher:
Passista
Quoted: 868 Post(s)
Liked 721 Times
Quoted: 4806 Post(s)
Liked 3,931 Times
Really good flashlights are a real plus. I now have one of those smallish super bright LED ones.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
uh..... yep.
