650b Commuter Bike ?
Quoted: 2604 Post(s)
Liked 1,933 Times
I'd say there'd be at least one disadvantage. 650b tires are generally more expensive than 700C, so you're spending more money for replacements.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The advantage of 650b over 700c is mainly one of comfort. It doesn't really have anything to do with hills or gearing. You can now get much fatter 700c tires than previously, and bikes that fit them, so that does away with much of the advantage of 700c.
Yesterday I started commuting on a newly built up bike, which is a 45 year old Bottecchia frame now with 650b wheels. This is a good way to make an old racing bike much more comfortable.
www.rhmsaddles.com.
www.rhmsaddles.com.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
I often consider putting 650b on my commuter just to reduce the step-over; but I already strike my pedals when I am being inattentive, 650b would just make that worse.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
I totally read that as "650 lb Commuter Bike".
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Sometimes you need that extra stuff in your panniers....
My Bikes
My Bikes
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
You could probably think up some advantages but they won't be as important as overall weight of you+bike, your fitness, and general local unavailability of 650b spares.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 408 Post(s)
Liked 184 Times
Quoted: 608 Post(s)
Liked 352 Times
There is no advantage it comes down to personal preference. I commuted on 650b for years. When using Grand Bois tires that ride was sublime but the amount of flats just wasn't worth it. With my Schwalbe Marathons less flats but the ride was forgettable.
Jet Jockey
Academically, I like the idea of 650b for commuting, gravel, etc.
It's still such a misfit size though that I'm not willing to make the jump.
It makes a lot of sense to design a frame around the size for shorter riders.
multimodal commuter
Liked 574 Times
But not necessarily. It depends on the tire size. The overall diameter of a 650 x 42b wheel is about the same as a 700 x 23c wheel.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 19 Post(s)
Liked 7 Times
650b is a nice size but so are 26" mtb and 700c. The problem is that bike shops dont have the capacity to stock a complete inventory of bike types, sizes and tyre size. With the popularity of 650b in the mtb world, 26" has been abandoned, yet you cannot buy a 650b commuter tyre off the shelf. 650c has been abandoned as a wheel for small riders in most lineups. It had made a recent comeback buy it is now back to small frames with big wheels.
Quoted: 147 Post(s)
Liked 8 Times
650b 38c tires deliver a ride experience akin to riding on clouds. Its like the rough imperfections of the road surface and potholes literally disappear when you float over them. With 650b, you can turn a skinny-tired road bike into a comfort cruiser.
Likes For m3rle:
The only advantages really come down to fit. You can run tires and still maintain a reasonable wheel diameter.
If you're 5'10" or taller then a 700c will always be just as good, and more readily available.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I really like how some modern steel frames will clear larger tires in 700c. My current ride has 700x35 and could go to 38 under the fenders. Its nice to have a little extra air.
Quoted: 1364 Post(s)
Liked 1,677 Times
GATC
Can't you do that w/ 700x35 though? I noticed immediately when I busted out the roadbike w/ 28mm tires at 80 psi vs the cross bike w 35mm tires at 65psi. Now 26" 50mm tires at 40psi, there is some cushioning!
Quoted: 5888 Post(s)
Liked 3,471 Times
Is this your new touring rig? Really good looking bike. I agree that fatter tires are an advantage of some modern steel bikes.
Liked 3,471 Times
Agree with the others that given the price of tires/tubes etc., there is a lot to be said for 700c or 26 inch for a commuter bike. If looking to save money, a vintage MTB is both inexpensive and a great platform for stout urban tires.
Insofar as a hilly commute is concerned (the OP's question), there's no appreciable advantage that 650b has over 700c. That is really a question of gearing.
ambulatory senior
Liked 3,661 Times
I know 1 bike sounds crazy.....
Liked 3,471 Times
1 bike is crazy plus the space horse will get lonely . . . .
ambulatory senior
Liked 3,661 Times
am sure I would eventually drag something home. There seems to be a pattern .
I want to get rid of 3 step thru frames, the masi frame and the miyata frame. If you know a good home.....
