Rigi
Rigi
Well it seemed like spring is around the corner today here in St Paul, MN. Dragged out a bike I haven't ridden in a long time. Took some picture in the snow today for some before shots. I'm going to go through it and clean it up for spring and hopefully remember to take some after cleaning pictures.
I'm thinking just some cleaning and lubing and rewrap the bar tape. The brake hoods are bad also.
Quoted: 3811 Post(s)
Liked 3,336 Times
nice to see. thanks for posting.
btw - take good care of that special gian robert front mech; tough to replace.
iirc there was an importer for these bikes in san diego.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Nice bike. Looks like a Nuovo Record triple arm, and Weyless pedals.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Wow, checking out the routing of the FD cable, the noodle and then the cable comes straight up on the right!
These bikes attack hills well, since the frame angle are both ~78 degrees.
Also these can ride in a most compact paceline for better aerodynamics of the rider and follower. The front and rear portions of the wheelbase are both very short.
I think these bikes are super-collectible, as the steepest-angled bikes ever produced.
The next-steepest bikes that anyone here is likely familiar with are the PX10's produced after 1973 or so, the Thevenet-era bikes including the LE model.
But those are more like 76 degrees, not nearly as steep as a Rigi.
Bikes: 1958 Schwinn Deluxe Spitfire, 2016 Surly Cross Check, 1971 BH Folder, 2016 Felt DD10
Yes, nice bike, please share more about it!
Bikes: A few
Quoted: 289 Post(s)
Liked 195 Times
Here's another post from a couple years ago. If that green one had been just a little shorter...man what a nice looking bike.
https://www.bikeforums.net/showthread...highlight=rigi
Old fart
Liked 3,400 Times
The only problem with those is that the BCD of the inner ring is non-standard at 100mm. It can be tough finding a ring to fit that BCD, and then the bolts and stand-offs to mount it properly. Campy only made one size to fit, 36T, but there were aftermarket 31T rings that Jim Merz made. All are rare, though. You might try selling it, since it is a factory-drilled triple, as evidenced by the fluting on the spider that stops short of the mounting holes, while cranks drilled on the aftermarket have the mounting holes within the flutes. That might make it worth more to a collector, and you could use the funds to buy a more versatile triple.
If I can find the chainring I should be able to make the standoffs on the lathe.
Thanks all for the comments.
I'll give alittle more infor on the bike.
I bought the frame set new in the 1980"s.
All the parts on the bike as you see it are the original as it was first put together when it was new.
TTT stem and handlebars
Zeus brakes
omas alloy headset
Omas titanium bottom bracket set
Campy Record crank arms
Weyless pedals
Campy super Record seatpost
Campy super Record rear derailleur
Campy Record high flange hubs
Zeus brakes
omas alloy headset
Weyless pedals
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Great looking RIGI, nice to see one with the decals intact. As noted in the link these came as a complete bike (or likely a frame and 'kit') and a frame/fork. I have only seen a few but none seem to have been built with the supplied kit. Other than the HF hubs this one seems to have been built maybe a little weight weenieish.
The do accelerate and climb well (unless you take a 42x19 to Putney VT as your low gear) and while I have ridden mine in groups it does take a very steady hand to do so.
Sugar "Kane" Kowalczyk
John, you are right about the Campy triple chainring. It is a 36 tooth.
I found it today and installed it.
I started another tread to not clutter this one up.
https://www.bikeforums.net/classic-vi...l#post16578640
