Freestanding or Bench Mounted: What is your vise bolted to?
Quoted: 176 Post(s)
Liked 245 Times
Woodworkers, car/motorcycle technicians, welders, machinists, bicycle mechanics. Each of these trades requires a vise but all of our crafts are different enough that placement of where it is mounted sometimes makes more sense for one group than another. With a new workbench freshly tucked into my workspace, I stepped back to consider what is the best need for my bicycle workshop: A vise mounted on a freestanding base or one bolted down to the corner of the work bench. I'd love to hear your thoughts and logic as to why you went the direction you did.
What size is your vise?
Where is it mounted?
How is it mounted?
Is the height accurate for the jobs it is performing?
Overall, does it work for your needs?
Care to share images?
How is it mounted?
The Simplicity of Vintage Cycles
Quoted: 4513 Post(s)
Liked 6,389 Times
Its big, oldschool, heavy, a bit the worse for wear after serving duty in heavy equipment repair for the first half of its life and is mounted to a big heavy wood bench.
Big vices do big heavy work and better be mounted to a suitable bench if you want to be able to lean on them and utilize its capability.
No pic as its buried in the pile, it doesn't get used often but when it does, its up to the task.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I rebuilt my Starrett this summer. In my humble opinion, having a heavy-duty vise married to a heavy-duty bench is the cornerstone of a good workshop. You may not need it every day, but when you do need it, there is no substitute. Got a stuck seatpost? Clamp it up and give it a twist using the frame as leverage. Shortening a steerer tube? Also I think that having it bolted to a bench is the only way to go because if its free-standing, well, you've got to walk around it. It also would have to be bolted to the floor for usability and safety.
Likes For J.Higgins:
Quoted: 638 Post(s)
Liked 1,297 Times
Old 6" Craftsman bolted to the end of two 6 foot steel work benches bolted end to end. I have a roll around work table I made from an old gas grill frame with a 4" Craftsman bolted to the end of it. I also have a little 2" clamp on vice, it's old, like 1940's or 50's old.
Quoted: 1609 Post(s)
Liked 2,216 Times
Looks like 4.5 inch.
Corner of the bench
Three Carriage bolts on a 3x8' bench (too big)
Bench is about 36" high so the vice is about another 4-5 inches. Good height for me at nearly 6"
Indispensable!
I took a copper pipe and cut it down the middle and formed it to the jaws to protect the good stuff.
Corner of the bench
Indispensable!
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I’ve got 2- one mounted to a big built in workbench, another smaller one mounted to a small portable Craftsman workbench.
Commence to jigglin’ huh?!?!
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I have a small one I clamp to the bench as needed, and a large one permanently bolted to a corner of the bench.
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
I don't have one but about twice a week I wish I did.
Likes For MrK.:
Quoted: 7351 Post(s)
Liked 2,479 Times
I bolted mine to the corner of my workbench. The bench is fairly heavy, and I put an extremely heavy cinder block on the bottom shelf of the bench to make it heavier.
Likes For noglider:
Quoted: 176 Post(s)
Liked 245 Times
Great stuff everyone. Clearly, the majority prefer (or out of convenience) have the vise mounted on a bench. I figured that to be the case.
Thanks for the useful suggestion on the copper pipe hack, SJX426
nomadmax, nice soft jaws for the really delicate stuff. Where'd you pick those up at?
Quoted: 1952 Post(s)
Liked 2,013 Times
I've got my grandpas small Wilton bolted to a heavy bench. But I want a large Wilton on a stand bolted to the floor.
Quoted: 3361 Post(s)
Liked 3,638 Times
I've got a cheap Harbor Freight 4" on the corner of my workbench. It's pretty wimpy, but as the saying (kind of goes) - a vice is kind of like pizza, even when it's bad it's still pretty good
If I had my way I'd have a smaller one bolted to a workbench and a larger free-standing one bolted to the floor. Big commitment to take up floor space with a permanent installation, so it makes a lot of sense in a lot of cases to put it on the bench.
Likes For abshipp:
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,382 Times
...when I had a working blacksmith shop, I had one of those post vises mounted to wooden post near the forge and anvil. the wooden post went through the floor, and down into the subsoil in the crawl space. That was kind of cool. I don't know how old that post vise was, but some prior owner had repaired one of the jaws by forge welding a strap of steel around it.
Quoted: 590 Post(s)
Liked 445 Times
How is it mounted?
How is it mounted?
In the past I've only ever worked on a bench mount, so could someone list the Pro's of a pedestal/floor mount over a bench mount, with regards to bike repair specifically. What kind of repairs are easier done on a pedestal mount over a bench mount, or vice versa? And are there other typical home projects where a pedestal mount is advantageous?
Quoted: 176 Post(s)
Liked 245 Times
The pedestal/floor mount option is great for having loads of space around it and so you can move around to any side. Plus, it can be portable (mounted on a semi-truck wheel base, etc.).
But, as abshipp pointed out, the space commitment is significant even if you can move it around. And through my research, I found a person who had a freestanding/pedestal mount and eventually sold it and went back to the bench mount. His reasons, which counter my points above, were as follows:
My setup was as follows. The base had an approximately 24" diameter tank end filled with concrete, three pad contact for stability, with two wheels that contacted the floor when tilted.
- I couldn't apply any real pressure to bend things and some other work overcame the weighted base.
- The wheels didn't work very well, on rocking the column back to cause the wheels to contact the floor, just a little more and the center of the base dragged (that was something I could have fixed, so, my fault) so it wasn't easy to move but most of all;
- I grew very weary of pressing my toes against the base then bending forward to work, or unnaturally spreading my legs to move in closer, which sorta' pins you to one spot, harder to dance around to optimize various positions on a fixed work piece.
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
5" Wilton "bullet" vise bolted to the corner of a 24" x 40" steel bench that rolls on casters. The ability to roll the bench into a more open area of my garage / workshop has been very useful. I've done a heap of repair and metal fabrication work with this set-up over the past 30 years.
These days, the jaws support my bike repair stand most of the time. The steel tractor seat was my Dad's and is a personal treasure.
Dean
438D6B4E-88D0-4589-9114-F032057B2057
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
If you’re going to be doing woodworking on that bench, don’t permanently mount the vice to the corner. There are a lot of woodworking tasks that involve having an uninterrupted top surface. Planing boards, cleaning doors, gluing up bookshelves, etc. I have mine clamped to the corner so I can take it off when I need to.
Quoted: 176 Post(s)
Liked 245 Times
Likes For The Thin Man:
Liked 2,479 Times
@3alarmer, I recently performed that task on my 1971 Raleigh Super Course. Afterwards, I couldn't screw one of the BB cups in. I was lucky that my LBS had the tools and know-how to chase the threads for me. I guess next time I'll screw cups in before I clamp it in the vise that way.
Quoted: 18 Post(s)
Liked 49 Times
If anyone wants a vice, this one is made in usa. it's not very much to my liking but it will do the job in a pinch. I can fit it in a USPS flat rate box and it's yours for $20 PP net to me or send me an Andrew Jackson in the mail.
Quoted: 176 Post(s)
Liked 245 Times
Quoted: 18 Post(s)
Liked 49 Times
Likes For banana jam:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Mine is bolted to the workbench, but if I had room for a pedestal, I'd do that.
