Odd 3 speed Hub
Bikes: 1992, Cannondale R900. 1991 Paramount pdg
Quoted: 62 Post(s)
Liked 174 Times
Odd 3 speed Hub
A Add on CL for Schwinn 3 speed showed this Rear wheel and hub. The shifting cable is on the break side. I have not seen this before Were they made that way or is this a mod.
Anyone have any idea;s on it
Ed
Ed
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Shimano put the shift mechanism on the non-drive side on some of their coaster hubs. Probably a 3CC.
Likes For Sluggo:
Quoted: 62 Post(s)
Liked 174 Times
Thanks for the info. Know I know what it is I looked it up and the general opinion is to stay away from them.
Thanks Ed
Thanks Ed
Quoted: 7350 Post(s)
Liked 2,475 Times
Yes, they were not durable, and there are no parts available. They might be the worst 3-speed hub ever made.
All Shimano 333 hubs were bad? I rode the heck out of my Sears three speed so equipped back in the early '70s. I preferred it to my dad's ~1960 Sears 'JC Higgins' three speed with the S-A hub. The Shimano was easier to adjust properly - and if the S-A was off a bit, it had the nasty tendency to slip into 'neutral' between 2nd and 3rd under load... and I broke lots of S-A adjusting chains when I'd drop the bike on the drive side...
Quoted: 90 Post(s)
Liked 137 Times
Glenn
Likes For Glennfordx4:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The Sturmey-Archer TCW series might be worse. They actuate the coaster brake through the internal gear mechanism, so when you're in high gear (and going fastest), you have the least mechanical advantage when braking.
Likes For JohnDThompson:
