Updating a Schwinn?
Updating a Schwinn?
In the time I've perused the ads looking for a nice vintage 10 speed, I've been attracted to the old Schwinns and in my research found that the Super Sport has that filleted frame look of the classic Schwinns but lighter than the flash-welded ones. About the only thing I hesitate about is the forged crankset. But I just read an old thread that mentioned an adapter kit that will convert the old forged cranksets to cotterless. Unfortunately, the company they referenced selling them is the now-defunct Harris Cycles.
Is there anyone else offering this conversion kit?
Quoted: 767 Post(s)
Liked 1,898 Times
Truvativ Adapter
Likes For BFisher:
Quoted: 5888 Post(s)
Liked 3,471 Times
Alternatively, get a Superior or a Sports Tourer as they came with a conventional BB.
This is a good discussion of the fillet brazed Schwinns:
https://www.sheldonbrown.com/schwinn-braze.html
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
"Sporty" no longer resides in NH and is currently enjoying the sunny south in its 51st year. The modification of a Super Sport or finding the Sports Tourer or a late '70s Superior, is very satisfying.
I do have a green Sports Tourer still in NH which needs a new home.
swampyankee2 in what part of New England do you reside?
Bob
Bob
Likes For pastorbobnlnh:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
I found a crank arm adapter that uses the Ashtabula crank and any 110 rings. The setup is one pound heavier than the 3 piece crank but is easier to service and probably more durable. I posted here on it. They may still be available on the web.
Likes For sd5782:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 3811 Post(s)
Liked 6,713 Times
I've used that Truvativ adapter on a Super Sport. One note is that you'll also need to use a cartridge BB rather than a cup-and-cone model.
Quoted: 566 Post(s)
Liked 1,052 Times
**Note - you will need to do some grinding inside the BB shell to make the Truvativ adaptor fit properly.
Its about my only hangup about those classic Scwinns. That clunky, heavy steel crankset. The adapter sounds like a great solution.
Quoted: 566 Post(s)
Liked 1,052 Times
I’m sure you could find a decent crankset from a forum member, if you don’t have one already, and the conversion+BB will cost less than $40.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Burgundy Super Sport | Flickr
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Death fork? Naaaah!!
Top
Liked 6,713 Times
Perhaps the tech has changed, but I remember that one or both sides of the Truvativ cups had lips of sorts, preventing me from getting a wrench on the fixed cup to tighten it down.
Or, if you have a lathe and/or a friend with machining skills, you can modify the adaptor like I did on my three-speed Super Sport:
But thanx for the clear-cut pics of the conversion process. It looks like you sourced a new crank spindle and bearing cartridge kit in addition to the adapters.
mycocyclist
Quoted: 910 Post(s)
Liked 820 Times
The Right Way And The High Way
from recently sold ebay listing.
And with cups and races:
from sold ebay listing.
And here's Schwinn's Tech Sheet on the Conversion and Item:
Alternatively, you can follow this BF member's lead?
Best of luck whichever path you take.
(I suggest you fab original spindles, and pass them on to BF SS owners on the cheap, but I may be somewhat self serving with that suggestion?)
I'd gladly pay for the commercially made product.
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Go for it! A Super Sport was my first serious ten-speed back in 72-73, by the time I sold it, it was sporting tubular wheels and had been pretty much stripped down. Thirty five years later I built an identical one, then converted it over to cotterless bottom bracket, and a Nervar crank, as detailed above. However, the one I used (got it on Amazon) didn't use the original bottom bracket cups. Rather, you knocked the cups out and replaced them with a Fenix aluminum bracket that was held together by three Alan bolts and was threaded to use a standard English bottom bracket. It worked really well, and looked a lot less kludgy.
As to the Fenix:
https://www.amazon.com/Fenix-Bracket...ps%2C57&sr=8-5
This is the initial build, before I did the bottom bracket conversion. Unfortunately, I don't seem to have any picture of 'after'.
As to the Fenix:
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Quoted: 809 Post(s)
Liked 712 Times
I do happen to have access to a full machine shop, although these days I just get one of the apprentice toolmakers to do the work for me. LOL
Truvativ adapter rings
Shimano bottom bracket
Nervar crank arms
TA crank bolts
Velo Orange chainring
MKS pedals
and
SRAM chain
It was fun for me... an old bike mechanic who's been working on bikes for more than 40 years. It shows how fungible bikes really are... and I like to use the word "fungible",
Jeff Wills
Jeff Wills
Quoted: 90 Post(s)
Liked 137 Times
Well then, have one of the lads fab one of these! (And two for me, if you please?) The advantage is that you will be able to use the extant cups, races and bearings, all of which are virtually indestructible.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 323 Times
My 1973 CCM with new SA XRD3 has a 168 mm 1Pc. It has pitting and something is not square, so I have to run it loose. I did 3 centuries on it last Sept., EASY. The crank with my new Nexus 7i is stiff as a board. WTF.
Far better than any cotter crank.
Freewheel Medic
Liked 2,196 Times
WilliamK1974 a work around can be finding a suitable 74BCD chainring (or even a 30T or 32T Suntour freewheel sprocket),and drilling the needed mount holes in the steel spider and taping them to accept bolts. This could even be accomplished with a hand drill.
Bob
Bob
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Likes For Hudson308:
Sprint triple
I'm pretty happy with my "upgrade" for my Sprint. I got the Truvative BSA conversion and mounted an old silver SRAM Truvative triple. Since GXP bottom brackets only use the non-drive side bearing for lateral positioning, the fact that the Schwinn's BB shell is only 55mm wide didn't make much difference. I used ~5mm of foam on the drive side instead of the wavy washer. Heh, it only saves 500g from the steel crank, though weight savings wasn't why I was doing it. The stock Schwinn front derraileur handles the triple and the chain line is perfect.
The stem shifters also were replaced with Suntour bar end units, while the Winemann brake levers left in favor of these. The broad resin frames are pretty comfy and are almost as convenient as the old suicide levers. Things look a lot tidier in the office now.
Mark
Mark
