Finally! Shimano recalls Dura Ace and Ultegra cranksets
Quoted: 3515 Post(s)
Liked 2,928 Times
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
Shimano does not make carbon fiber cranks, crank-arms, etc.
The problem is galvanic corrosion: steel spindle attached to aluminum arms. If some water gets in there, or worse ... sweat, or salt water, you have a battery, and the aluminum oxidizes and degrades. This, combined with the two piece bonded (glued) construction, leads to these failures.
Hambini had a rant about this awhile back:
Likes For Polaris OBark:
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Likes For Eric F:
Liked 2,928 Times
Habitual User
Liked 8,100 Times
I need to check the cranks on my gravel bike (6800). Meanwhile, I can continue to pedal with confidence on the Campy Record, SRAM XX1, and FSA cranks on my other bikes - all CF!!
Liked 3,445 Times
You probably won't see anything until it is too late. Have a look at the Hambini video. After the ranting, it gets informative.
It might be a good time to get a nice safe GRX crankset.
Ironically, if the CF crankarms were instead actual plastic, you would be safe from galvanic corrosion, since plastic is an insulator. Carbon Fiber, on the other hand, is a conductor, and has a redox potential. So you can still get galvanic corrosion with carbon fiber parts.
(Even if it was an insulator, I would still be afraid of CF crank-arms.)
Habitual User
Liked 8,100 Times
Likes For Eric F:
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Likes For bikingshearer:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Shimano cranks are the first things I replace on a new bike, selling them as new "take of" to some other sucker.
Aluminum is not a great material for high stress, cyclically loaded structures. Making cranks two-piece and hollow only increases the risk of failure.
Quoted: 7653 Post(s)
Liked 3,483 Times
That is an excellent example of how smart people get information and completely ignore it, picking and choosing tiny bits to cobble together something which fits their a priori narrative to support their own ridiculous and unrealistic theories.
Those cranks did not fail due to stress ... they failed because they were not properly glued together, so that moisture could create a corrosive chemical reaction between steel and aluminum parts. This corrosive chemical reaction hastened the breakdown of the adhesive bonding the aluminum parts together. The glue is what failed ..... This has been explained repeatedly, in posts way before the recall was announced. In fact, pictures like the one above were posted years ago on a website which collected stories o crank failure ... which site was referenced here in an earlier thread (search and find.)
At no point did the aluminum crank fail because the intact crank was aluminum, and could not stand up to the stresses of being aluminum and being a bike crank. (If aluminum was not suitable for bike cranks the 105 cranks would also have been recalled. (https://handsonbike.blogspot.com/201...imano-105.html)
The cranks failed because the glue bonding the two sections together failed, and the remaining two parts, seperatley, could not function as a bicycle crank.
The All-Aluminum, one-piece, 105 cranks have No record of failure and are Not included in the recall.
This is a classic example of a smart person being deliberately stupid to support and inaccurate and dishonest theory. This is the same sort of lack of thinking or dishonest, actually psychotic (using information invented to replace actual information form reality) that allows people to hate CF ("Every CF frame and fork is a deadly accident waiting to happen," they have been saying for several decades, while the rest of us wait .... )
This is the kind of thinking that allows people to claim the Earth is flat and that technology doesn't work while driving computerized cars along routes suggested by GPS satellites while engaged in video-telephone calls with people in other countries,.
This si the kind of ridiculously pitiful failed thinking which is actually killing the human race.
Bravo.
Likes For Maelochs:
Liked 2,928 Times
climber has-been
Liked 3,567 Times
Yeah ... except it wasn't stress that killed them.
Bravo.
Bravo.
Fatigue failure of solid aluminum cranks is a known phenomenon, and it has been happening since aluminum cranks were first made.
It does not take a leap of imagination to infer that a two part, hollow aluminum crank is even more susceptible to fatigue failure, whether or not this particular Shimano corporate announcement addressed a fatigue failure mode. There are many examples of Hollowtech cranks cracking, right around where stress concentration ought to be the highest.
Liked 3,483 Times
Yeah ... you hate aluminum cranks, so you hate aluminum cranks.
As I noted ONLY the bonded aluminum cranks have been experiencing failures. None of the other Shimano Aluminum cranks have been failing .... the 105 cranks from the same two series (5800, 7000) are not even included in the recall because there are no reported failures.
Show us the data. Show the long list of Aluminum crank failures. We will wait.
And then ... list the ones from the past two decades. Because to propel who actually include some fact in their thinking, Al cranks work just fine and the technology has been solid (or hollow, single-piece) for decades.
Post your countervailing information please.
Likes For Maelochs:
Liked 2,928 Times
climber has-been
Liked 3,567 Times
Funny, and it brings back a slightly amusing memory.
When I was growing up in my parents' bike shop, big, tall, and aggressive-riding Jobst Brandt was notorious for breaking his Campagnolo aluminum cranks. My dad stocked some steel Campy cranks just for Jobst, and that seemed to end his broken crank problem.
By the time I left for college, there was still an extra pair of steel Campy cranks in the shop's display case. I doubt they were ever sold to anyone else.
Habitual User
Liked 8,100 Times
Likes For Eric F:
climber has-been
Liked 3,567 Times
Fatigue failures are to be expected when you select a metal alloy with no fatigue limit, then subject it to cyclic stresses on every pedal revolution.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 979 Times
Likes For georges1:
Cantilever believer
Quoted: 537 Post(s)
Liked 1,846 Times
Likes For RCMoeur:
Cantilever believer
Quoted: 537 Post(s)
Liked 1,846 Times
Mix up some JB Weld and that'll be fine.
Likes For RCMoeur:
Habitual User
Liked 8,100 Times
Likes For Eric F:
Quoted: 3241 Post(s)
Liked 2,512 Times
Liked 3,483 Times
Aluminum cranks have been working wonderfully for decades .... if 25 years ado some cranks were not sufficiently well-made as to withstand unusual amounts of force .... whatever. In the past 25 years aluminum cranks have been normal and perfectly functional.
As evidence I put forth the fact that even someone trying to prove the opposite could not list a single major mass recall of aluminum cranks withing the past two decades.
Seems to me the tech is working.
I am not interested in Luddites ord conspiracy theorists ... refuting them is pointless. Let them ride their Flat Earth where there are no satellites (but GPS still works) and NASA faked the Moon landing and all their steel cranks ... i simply do not care.
