Brake handles on Australian bikes
Randomhead
Liked 3,700 Times
I feel like the U.S. is mostly by itself on having the front brake on the left. I never understood that preference anyway, it has never caused me any problems to have the front brake on the right.
Quoted: 626 Post(s)
Liked 401 Times
Quoted: 4420 Post(s)
Liked 4,873 Times
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
If you are left-handed you want the front brake on the right, so you can smoke while descending and still have good braking.
Likes For trailangel:
Quote:
Originally Posted by Paul_P
Because of my motorcyling years (long ago) I'm still never sure which lever does what, which can be a problem when I have to decide quickly.
Quote:
Originally Posted by rollagain
Yeah, you don't want to be grabbing the brake lever every time you want to shift gears.
What could possibly go wrong?
One example : If I have to brake while turning on pavement covered in sand, I'm not going to touch my front brake as I prefer a rear skid to falling flat on my face.
It often has to be quick reflex, and became one on a motorcycle, but ever since going back to cycling I can't help but hesitate the time to figure what I shouldn't do.
I seem to vaguely recall that I may have intially made my bicyle brakes conform to what I was used to, but that disappeared through the new bikes that followed.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,474 Times
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Do the other RHD countries do right front braking? I know we have some folks here from Japan
I always assumed it was to do with the fact that in the UK, Australia and NZ we drive on the left-hand side of the road, although I'm not entirely clear why that matters. It means that if you're indicating and turning right, across the oncoming traffic, you'd only have access to the rear brake. Personally, I've always felt it would be better to have access to the front brake, but I'm now so conditioned to having the front brake on the right I don't think I'd want to change.In any case, if I'm doing more than gentle braking I want to have both hands on the bars so it probably doesn't make a lot of difference.
Likes For jgwilliams:
When driving on the right, all signals are (supposed to be) with the left arm and if I'm only going to have access to one brake, I want it to be the rear.
I imagine that this is true also for those of you on the left side of the road.
Bikes: Specialized Allez Sprint Comp
Quoted: 32 Post(s)
Liked 410 Times
Your suggestion that the issue is related to hand signals makes a lot of sense to me.
Likes For David_Harris:
Bike signaling only with one arm has never made sense to me. When cars didn’t all come with indicator lights, the driver side arm doing the signaling only makes sense, because you can’t just reach across most vehicles and point your arm out the window, as you can with the window on the door next to you. But on a bike? I can just point with either arm which way I’m going to go, and so use the arm that is on the side of my intended direction.
As it happens, it isn't uncommon for me not to indicate that I'm turning left, or to leave it quite late, in order to avoid having drivers dive in front me.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Yes, totally agree. If I started using my right arm to indicate I was turning left I'd leave a trail of confused and angry drivers behind me. Since it's over 45 years since I took my driving test I don't even know if hand signals are still taught in the UK; it wouldn't surprise me if they aren't.
From
https://theorytest.org.uk/direction-signals-2/
https://www.gov.uk/guidance/the-high...her-road-users
.https://www.gov.uk/guidance/the-high...her-road-users
These are the other arm signals that drivers use to other drivers:
- Left turn= Right arm out and rotating forward
- Right turn = Right arm out and palm facing forward
- Slow down or stop = Right arm out, palm down and moving up and down
Reads to me like cyclists can also use (1).
Liked 4,873 Times
Damn, you made me check
From
From
Likes For PeteHski:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
Spent a year in Australia some years back and my wife bought a bike there. That was the point I noticed this difference.
But I had my US bike there, so my brakes were on the "wrong" side. I don't recall it making any difference to me, when signaling or otherwise. I suppose if I had had to do some sudden braking while signaling, it could have had an effect, but generally I would not be using my arm to signal if I though there was a chance that I needed a sudden stop.
Funny, I'm an Australian. I never rode a bike there (no longer live there) with the front brake on the right lever. And that's going back to the 70s. Perhaps it varies from state to state.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
In the UK, market standards and laws dictate that bikes sold must have the front brake operated by a lever on the right hand side of the bars and the rear brake by a lever on the left hand side of the bars. I have found this convention common in former commonwealth countries such as Australia.
https://www.ecfr.gov/current/title-1...er-C/part-1512
Once it's sold you can do anything with it you want or have the dealer do it.
Quoted: 626 Post(s)
Liked 401 Times
8) Hand lever location. The rear brake shall be actuated by a control located on the right handlebar and the front brake shall be actuated by a control located on the left handlebar. The left-hand/right-hand locations may be reversed in accordance with an individual customer order. If a single hand lever is used to actuate both front and rear brakes, it shall meet all applicable requirements for hand levers and shall be located on either the right or left handlebar in accordance with the customer's preference.
In the US by CPSC regulation bikes with hand brake(s) must have the rear brake on the right and front brake on the left when sold new retail: 16CFR Part 1512.5 B8
Quoted: 1821 Post(s)
Liked 1,697 Times
Back when there were exposed brake cables I tried out having my dominant hand using the front brake. It was great. my right hand had much better control when it came to modulating my front brake, up to being able to stop even with my rear wheel off the ground without going over the handlebars. The change for me came when aero brake levers came onto the scene. With brake cables under the bar tape, it became more difficult to have the same level of brake control with the extra friction of the very tight curvature of the cable coming out of the bar tape on the right side of the bar and having to get to the right side of the brake calliper. With external brake cables this was never an issue
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2588 Post(s)
Liked 5,649 Times
Grupetto Bob
Liked 5,649 Times
Rented a stick-shift car in S. Africa. Not only was it a challenge driving on the left (not to mention people and random animals on the highways) but the turn signals are also reversed with the window/windscreen wipers. Think I activated the wipers about a half dozen times.
And then there was walking and crouching in the bush 20 feet from a mother rhino and her baby. That got the adrenaline pumping.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For kommisar:
Liked 4,873 Times
Grupetto Bob
Liked 5,649 Times
I was thinking toilets, but you are probably on to something.
