Uneven crank arms
Uneven crank arms
Hello, I have installed an fsa vero square taper crankset on my bike, and torqued the arms to the same amount, but they seem to sit at different depths on the taper, and also the end of the arms are different distances from the frame. I realize there are asymmetrical spindles and perhaps this one, but I assumed the taper would be the same shape/length, just starting further out on one side. Is that assumption incorrect and these cranks are installed correctly? Or is this a symmetrical spindle installed incorrectly? See pictures below. Thanks!
(Also I know the crankset is not classic or vintage, but the bike is—a 1985 Trek 500—and I find the folks on this forum to be very knowledgeable).
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
Hmmm...do you know what the BB said on it before you installed it? Could it be a 70mm BB instead of a 68mm? That would set the correct protrusion on the drive side (with the chainrings) since the cup is fixed on that side (and thereby the sprindle length sticking out) which would leave any discrepancy in sizes to be noticed on the non-drive side. When I have undoubtedly installed 70mm BBs in 68mm shells, I usually see the threads of the NDS cup sticking out just a bit. Yours is not. If you remove the cranks, do the spindle ends stick out the same amount on each side? If so, the issue is likely with the cranks. But if they stick out different amounts (according to a measurement against the chain stays) then its probably not the cranks but the BB.
Hope that helps! Others will be along soon to explain much better!
EDIT: Also, we cannot properly help you without full, glorious pictures of your very nice Trek!
There were 135 Confentes, but only one...Huffente!
Quoted: 3814 Post(s)
Liked 3,345 Times
first step:
remove fixing bolts so you can examine how much freeboard you have between spindle end and floor of removal threads
it "should" be the same on both sides
first step:
Likes For juvela:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Eyeballing your installation, it appears that there is not much L/R discrepancy at all, given that the same reference is applied on both sides of the BB shell at the shell mating surface, not at the outer face of the fixed cup.
It really looks like the same ~7mm or so is (about equal) on both sides.
I can't see the taper flats and transition bevel on the right side photo, but as juvela just posted that can be checked from underneath the fixing bolts.
What torque have you applied? It is often the case in my experience that left-side cranks, if anything, tend to expand more and thus go on just slightly further than driveside cranks. This I believe is due to the additional metal surrounding the square hole on the right crankarm.
How is your chainline? There is typically supposed to be about 43mm from the center of the seat tube to the center of a single ring on a derailer bike or singlespeed conversion, and the two crankarms should equally clear their respective-side chainstay.
If that isn't a narrow-wide chainring you might find this setup prone to dropping the chain at the worst possible moment when the chain is maximally crossed, which can be very dangerous.
I've been enjoying tinkering with this one. Usually I keep things pretty vintage, but I decided to have some fun with more modern components, experimenting with a 1x10 setup. And it takes pretty big tires, which is nice.
Likes For drewfio:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
The Huffmeister
Liked 3,561 Times
Very nice retro build / restomod! I bet it rides like a honey.
Liked 3,345 Times
one variable not as yet mentioned is that of Q-factor
if you remove the NDS arm and remount 180 degrees from it present position you should be able to easily measure the Q-factor of the assembled chainset
this could be compared with posted value from a technical publication, which should be findable online
Is this as simple as the asymmetric spindle is installed backwards?
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
^^ That was my first thought.
Excuse the imprecision. I was just being lazy since I could feel/see in person it was off. But to confirm I just took out the caliper, and the NDS is about 2mm farther from the seat tube than the DS. Smaller difference than I thought.
Likes For drewfio:
Quoted: 3464 Post(s)
Liked 2,831 Times
While the crank arms show displacement.
The chainline is not reported.
there really is not enough info to work with here.
my first notion as Bad Lag mentioned- a flipped cartridge.
That crossed my mind. But it's a cartridge bottom bracket with the spindle and one threaded end connected to the unit, and I think the left hand threading would prevent me from installing backwards in the shell, correct?
The Huffmeister
Liked 3,561 Times
Is the threaded (drive side) cup removable? If so, it is very possible that it may have gotten reversed. But this would only be the case if one side of the spindle is longer to compensate for a certain crank side. If they are the same, it would matter. But, It might be easier to see when it's out. If you have the tools to pull it out and snap pictures, that would help a lot, but could be a bigger operation than planned. Some BB tools would make for great stocking stuffers, and then the whole process becomes more approachable.
Just measured the chainline and on the outside position the ring is nearly 50mm, and on the inside 43mm (it is a pretty thick ring). I feel like somewhere in the middle would get the best performance based on the actual setup I have now. Would need to change the crank or BB I think to get to that though.
Quoted: 4806 Post(s)
Liked 3,933 Times
My first thought - does it matter? I have probably owned a bike or two that has had cranks that sit evenly over my 50 years of using tapered spindles but I never either checked or noticed. When I have thought about it, it was in terms of getting the Q-factor down to what my knees like and that almost always means the left crank siting closer to the frame than the right.
I can guarantee you the bike doesn't care. Where the right crank sits matters in terms of chainline and derailleurs. Needs to not hit the chainstay (rarely an issue) and likewise clear the bottom bracket cup and bike's BB shell. Left needs to clear the chainstay. Those of who raced way back when raced bikes where there was perhaps half the clearance on the left to the chainstay as on the right. Some of us took pride in having left cranks that nearly scraped the paint.
And last - tapered bottom bracket spindles and the tapered aluminum cranks. Tolerances, both when made and as evolved over repeated mountings. Small errors in cross section size (these are machined parts) make considerably bigger difference in where those parts sit relative to each other simply because of the shallow taper. Say the taper is 10:1. (I just pulled that out of a hat.) A 0.1mm error in either spindle taper size or crank taper size would make a full 1mm difference in where the crank sits. Where cranks sit relative to the bike frame is one of the least precise measurements on the whole bike. And since it really doesn't matter, no one sweats it very much. You can pay twice as much for higher end parts and get a little better. (Better machining tolerances, perhaps harder steel/aluminum.) Plus, the variations of your torque, the grease or no on the spindle, perhaps the polish on the spindle and maybe whether it is Monday, Thursday or Saturday when you tighten the fixing bolt ...
Liked 2,831 Times
toss that aside and take a known straight edge with the chain off the ring and strike a line using the inside and outside surface of the ring toward the cog set.
Quoted: 4513 Post(s)
Liked 6,391 Times
Spindle penetration will tell a lot but none of this is life threatening absent cracking or "bottoming out" in the arm.
Check BB cartridge orientation when more convenient and correct if necessary.
Likes For merziac:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Speaking of thinking about it... If I knew something was off, I wouldn't be able to stop thinking about it. Fortunately I'm so old my eyesight would never notice what the OP did. And the older I get, the fewer scratches my bikes have.
