Handlebars feel too low but not sure...
Long story short: I had a trek mountain track 800 that I liked but had mechanical problems with it and decided to buy a comfort cruiser but found out that I did not like it. I unfortunately did not take measurements and ended up buying another mountain bike. I know the bike that I bought has a lower top tube. On the old bike I barely cleared it with my 30 inch inseam and on the new bike I have 2-3 inches of clearance when putting my legs over it. But with Covid and bikes being slim pickings, I went ahead and bought the bike. Anyways, I was wondering if it can be modified to give me a better fit. I feel like the handlebars are too low and I'm leaning too far over them. I have the handlebars at the maximum height and I was wondering if a quill raiser or a different shaped handlebars would help me. I'm 5'7" and the bike that I bought is a Trek Mountain Track 820 18" frame 45.5 cm. Any advice is appreciated, thanks.
Here is what I look like on the bike:
and a photo of the bike itself:
and my old bike:
and my old bike:
Quill stem raisers are a chromo tube reduced half way down, so bottom fits in the fork with its own wedge,
and then you put your stem in the top. top ID = bottom OD..
added height will require longer cables of course.. you can do the raising part , then see if you like it. no? hook the cables back up..
Quoted: 7650 Post(s)
Liked 3,472 Times
It looks like you might have stretched that stem as far as it goes. You can probably buy an extender (maybe google bicycle quill stem extender) but at some point you will be endangering yourself---too long a stem puts too much stress on the head tube when you ht bumps, and you could snap the stem (dangerous but replaceable if you survive) or ovalize the head tube (frame is then junk.)
I just grabbed the first few link .... you would do well to do your own research, but this does at least show that you can find the part you are looking for. So long as you aren't actually mountain biking, you should be fine.https://www.lightinthebox.com/en/p/a...470ebafddfeb3f
https://smile.amazon.com/Fouriers-Ex...ngshoppinga-20
https://www.ebay.com/itm/174352068160
https://www.walmart.com/ip/Bike-Fork...pter/348108343
Quoted: 1943 Post(s)
Liked 2,164 Times
The other solution are riser handlebars. You can get them fairly straight or with a little sweep.
John
John
Likes For 70sSanO:
Quoted: 2482 Post(s)
Liked 2,952 Times
Agree that the fit looks good. Have you ridden the bike? Ride at more than a walking pace or up a hill and you might find that your position is fine or even a bit too upright.
I'll ride it a bit more to see how it makes my back and shoulders feel. The bike previous to this one was a comfort cruiser with a just about upright riding position. My initial impression after riding it for like 15 minutes is that I'm sitting really high and the bars are way too low and I feel like a giant on the bike. With my seat at the current height I barely touch the ground with my big toe pointing downwards.
Likes For Flip Flop Rider:
To me, it looks like you've pretty much maxed out (and then some 😬 the modifications to make that bike frame fit your human frame. As mentioned in another reply, it appears the the quil is very close to not meeting its minimum insertion depth. The exposed length provides a fair amount of leverage that (as also mentioned) could result in component damage. Even with a quil extender, the leverage is still there and perhaps enhanced. Similar thinking might be an issue with the seat post, although I realize that newer frame geometry makes long seat posts commonplace.
Again to me (yes, some think otherwise), that frame is too small for you! You didn't mention what the "mechanical" issues were with your "old" bike. Nor did you mention if you still had it. Perhaps if you still had the old bike, (and the frame wasn't the source of its problems) you could piece together a "Frankenbike" using the best parts of each 🤔.
Likes For sovende:
I think the fit looks pretty good too, but maybe your saddle is a little high.It couldn't hurt to lower it a little and see how it feels.
Saddle height also depends on where/how you ride. For trail riding (which I don't do anymore), I preferred my saddle a little lower than my road bike. I felt it gave me better control.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
that bike looks VERY upright and the frame looks too small for you—the space from the saddle to the handlebar makes you look "scrunched" on it.
you have to use your core and your arms to balance yourself on a bicycle, but you need to start by getting yourself balanced by means of the saddle position. that saddle looks like it's tilted down, which could encourage your butt to slide forward on it while you're riding. as a result, you have to push yourself back with your arms to keep from sliding forward, which strains your arms and shoulders, leading to further neck and back pain.
it's a bicycle, not a tractor. if you want anything more upright, get a beach cruiser or a Dutch-style bike. Something like an Electra Townie would be better for that.
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
If it feels too low, it's too low. That said, as you ride more and your body gets stronger some discomfort will go away naturally.
Get your saddle height set first (that's a pretty standard setting based on your PBH * 0.883 or using Rivendell's approach) then go from there.
That said, you look pretty darn upright in the photos but everyone's comfort level is different. Try some swept-back bars as well, those will get your hands in a better position
Likes For davei1980:
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
n00b
Quoted: 428 Post(s)
Liked 466 Times
as I noted above, neck and shoulder pain are likely the result of a saddle that is tilted down.
edit: that's the right size bike. something else is going on.
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
Let us know how it works out.
Glenn
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,590 Times
Thread moved from General to Fitting.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 387 Post(s)
Liked 323 Times
It's my (unpopular) opinion that if you have to be nearly vertical on a bike to feel comfortable, chances are you've got some underlying health issues that are preventing you from bending over. Those issues are going to impact you on more than just your bike. It wasn't until I entered my mid 40s that I started to realize how incredibly inflexible I was and not only was it impacting my cycling, it was impacting all sorts of areas of my life. Lower back pain was just one of the signs of my lack of flexibility. As such, I've been stretching every morning and regularly doing "core exercise" get my body in a better state versus having to purchase taller and taller bicycle stems.
Likes For PoorInRichfield:
n00b
Quoted: 428 Post(s)
Liked 466 Times
^ Agree.
Quoted: 6191 Post(s)
Liked 4,807 Times
I have to agree that trying to make a particular bike type fit the rider that doesn't want that type of position it's designed for is asking a lot. You end up with a franken-bike looking thing.
A beach cruiser does allow for a more upright riding posture that is for leisurely riding. And maybe beach is a bad term to use for the bike. But frequently that type geometry bike has been only found on bikes the manufacturer describes as beach cruiser.
It puts the BB way more forward and actually makes a very upright position much more comfortable. Some manufacturers only offer them as fixed speed bikes. But I'm seeing more and more with gears now and liking the looks.
I've tried several times to get my wife on a bike but the type of bikes we found were more like the OP's and one we bought she had to have the stem ridiculously raised and angled back. But none had the bb forward or were anything like the bike she grew up on as a pre-teen and early teen.
This bike was suggested by another member in another thread and it caught my eye for what might be a good bike for my wife to try. Also might be good for the OP to consider.
https://electra.trekbikes.com/us/en_...mfort/c/EB900/
There are also some other good looking cruiser type bikes on Trek's site too. Some with gears, some without. But they have that BB forward design that should be good for very upright positions.
https://electra.trekbikes.com/us/en_...bikes/c/EB600/
It looks like the saddle on my purple trek is angled upwards. I'll make the seat flat and see how it goes. I'll also lower the saddle a little bit. I have it at the same height as my hip. Here is a video showing the height of my handlebars, should I move these down as well?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
But if you want a higher hand position, I think the easiest way would be get a riser bar. You might need longer brake/shifter cables if you raise the hand positions.
On the handlebar stem it says
insertion (arrow pointing upwards) and it has a whole bunch of lines marked above it. Should I move the stem down so those marks aren't visible?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Yes, that's the minimum insertion point. Lower it just enough obscure the marks with the headset top nut. I think a riser bar would let you lower the stem even more and help you find a more comfortable position.
Randomhead
Liked 3,694 Times
You might be happier with swept back bars. I agree that you should level the seat, at least a little. I expect that causes you to be pushed forward onto your hands.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Another vote for lowering the saddle and inch or so.
I tried to keep the seat at it's current position and make it level by loosening the bolt under it. However, after I made it level it began to tilt sightly downward when tightening the bolt. So for me to get the seat level, I had to move it back a little. I plan on riding a trail tomorrow and will give an update on how the bike feels.
