torque pressure for tightening quill expander bolt on top of stem
Whats a general ballpark figure for reasonable Nm pressure to be applied to the quill expander bolt on top of stem?
I have a cube hybrid/fitness bike and being a tinkerer i losened this at one point to see what i need to highten the stem.
Its now tightened with a simple allen key by hand, not too tight and erring on the side of caution and its been like this without issue for months, but ive gotten access to a torque wrench so just want to give it a touch with that to ensure its tight enough.
The cube website helpfully tells me to never touch this bolt and only let a specialist shop mess with this part of the bike (if we didnt mess, how would we learn anything?).
Quoted: 6193 Post(s)
Liked 4,808 Times
This sub-forum is Fitting Your Bike. Look at the intent in the description.
You probably want Bicycle Mechanics
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Owning a torque wrench is required in order for "how tight" to be communicated with an internationally recognized standard number..
Quoted: 283 Post(s)
Liked 262 Times
Alloy quill stem inside a steel steerer tube / steel fork OR threadless stem clamped to alloy steerer? Makes a big difference, bad accident if a quill stem gets loose.
