Ticking noise in front wheel
My bike is 3 years old, 6k miles, with these wheels: https://www.aclass-wheels.com/en/road_alx320COMP.html
For a long time, the front wheel has had a ticking or clicking noise when weight is on it. I finally took it to a respected LBS where the owner noted that the noise happens when the valve stem is at the 12 o'clock position. Lean on the handlebars and rock back and forth at that spot, and you get the tick/click. He believes the noise is coming from the rim (not the hub), and is convinced that the spokes are tight and nothing is broken. So far, he's tried:
1. Oiling the spoke nipples.
2. Replacing the plastic rim strip with Velox cloth rim tape. (idea: the rim strip was clicking somehow)
3. Slicing through the foil decal on the rim at the 6 o'clock position. (idea: the decal was crinkling)
Each time, the noise seemed to go away "at first", maybe even for several miles of riding. But it always comes back. And he's out of ideas, but he assures me that the wheel is in good condition. But the noise is very annoying and I'd like to find/fix it if possible. What else can/should I look at? All suggestions welcome.
Likes For LarryMelman:
Liked 6 Times
Could the valve stem be rattling against the rim at the hole in the rim? I've seen mechanics for professional riders tape the base of the valve stem with electrical tape against the rim to stop those kind of noise.
Likes For Jed19:
Bikes: 2010 S1, 2011 F75X
Is your valve steam threaded? If so, get a nut for it - or do the electrical tape thing described above.
I've had this problem with and without the valve stem nut. With different tubes and tires. But I will try some tape - can't hurt.
Liked 6 Times
Also, I was just thinking you could drop some light oil at the juncture where your spoke crosses. Sometimes, there is some wear there from the spokes rubbing together when you hit bumps etc, that, eventually, there is some looseness (just a tad) there that can result in the kinda click you described.
Likes For Jed19:
Went to another shop and the tech reproduced the noise by squeezing the rim at the seam line opposite the valve stem. It isn't welded, but it is supposed to be a joint of some kind. He thinks he can carefully close the small gap that's causing the click, without damaging the rim or etc.
Thanks.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Looks as if Larry "Bud" Melman hasn't posted on BF since 2013. But maybe he still looks at BF and will see your question.
Likes For JanMM:
Quoted: 6173 Post(s)
Liked 4,790 Times
What's exactly like your issue? A click? or did you try all things the OP of this long dead thread said they did as well as the couple other suggestions and you still have a click? Clicks, pings and other noises happen for many reasons. So we need some info to isolate what makes this exactly your issue.
The wheel is a new Easton EA70 SL - it took until the second ride to notice the click. From what the Easton website says, this is a welded rim so no plug to worry about.
Quoted: 836 Post(s)
Liked 1,058 Times
First I would contact Easton by email so that you have a record of it if needed for future problems. They may end up being very helpful and have a fix or be willing to inspect/exchange it for you. Worth a try.
Quoted: 2432 Post(s)
Liked 638 Times
9 times out of 10 when I I have a wheel tick at the same point every revolution it's a loose spoke. If it ticks when the valve stem is at the 6 oclock then it's usually a loose stem hitting the rim.
Likes For Lazyass:
Just an update - I finally got a chance on the weekend to investigate further. As it turns out, the ticking sound is related to the welded seam on the rim - the tire I am using (Compass Barlow Pass) doe not sit well at the seam due to the weld. I can recreate the tick sound just by squeezing the tire right near the seam. The way the tire's bead sits in the rim's bead is not good and applying pressure causes it to release/move and make a noise. There is damage on the tire's bead due to this constant action.
For some reason, the rear wheel does not exhibit this same issue - I still have to compare the rear and front wheel's welds. I suspect a little shaping of the front wheel's weld with sandpaper may resolve this issue.
Mechanic/Tourist
What about the rim joint that is underneath the foil decal? If it's a pinned rim that certainly could be the source of such a noise.
Front wheel ticking, exactly same issue as bmac.to
Hi there,
I know this is an old thread, but I have exactly the same issue as bmac.to on my front wheel.
i can even replicate the tick noise in the same way but applying pressure to the tyre at the rim joint opposite the valve hole.
Posting here to see if the issue was ever resolved.
Hello
Hi there,
