Simple Green et al: suspicions confirmed
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
Quoted: 7 Post(s)
For many years I've used diesel oil to clean my chains. In recent years I have been using one to the water based cleaner kits with orange oil?, but always being very careful to remove water from my chain with WD40 before lubing. I did try simple green once but didn't like it. I recently read in/on one of the magazines and/or websites ( velonews?) that simple green should not be used on your chain and it pits and ruins the finish on your chain, especially if you soak it. Simple green even advises not to use it on bikes as it can ruinpothe finsihes as well , they make another product for bikes whos name I cannot remember. The author of the article/ques response, ( Lenord Zin?) ses NEVER to soak with water based produscts especially Simple Green
my name is Jim
Yes in general soaking with regular Simple Green is bad for most metals. Simple Green makes a variety of cleaning solutions, including those safe for aluminum and with rust inhibitors. So they do make stuff that is safe to use to soak chains and aluminum bits but it isn't the basic stuff you can buy at Home Depot. You can use the basic stuff for quick cleaning but rinse with plain water afterward and don't soak things.
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
Quoted: 3375 Post(s)
Liked 5,513 Times
Quoted: 7 Post(s)
Thanks for adding the address!!!!!
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
This is old news. The chain in question was soaked in Simple Green for MONTHS - we were told when this story came out. This is not using Simple Green as a cleaner. This is using it as a storage media. The hydrogen embritlement is an issue but only with PROLONGED EXPOSURE. I have used Simple Green for 10+ years to clean chains with absolutely no ill effects. It is a fantastic cleaner but due to the nature of it, it must be rinsed completely to remove all residual cleaner. This is necessary with any cleaner on a chain as any residual cleaner would begin to "degrease" any new lube you apply. I rinse throughly and blow out water with compressed air. I apply new lube and voilà, chain works well and doesn't "explode"
I don't think much of what Zinn puts out in Velonews. His job is to promote what is advertized in his mag and he does do that.
Underdog
Bikes: Several.
I too have been using Simple Green to clean chains for the past few years. I'll toss the chain into a salsa jar with a diluted solution of SG and give it a good soak and tumble, and then blow it dry with a compressor.
Never had any issues.
Bikes: See Signature...
Quoted: 9 Post(s)
I prefer mineral spirits for chains. Let it settle over time in a glass jar and you can pour off the somewhat clean mineral spirits and use it over and over again It cleans and leaves the lightest protective film. Obviously you want to oil chain after, but it evaporates off, no drying needed
STFD
Bikes: '80 Windsor Carrera Sport, '02 Specialized Sirrus A1, '10 Giant Escape 2
I don't use Simple Green on my bike, but it's not because I have anything against it. I use the same jar of mineral spirits over and over, like nymtber does. I start a new jar every year or two, and the old jar goes to the recycler.
Quoted: 7348 Post(s)
Liked 2,464 Times
What about using it to clean bikes? Is there something better? I have noticed that it sometimes does bad things with the finish on some aluminum components.
Bikes: '08 Trek 7.3FX
Can we roll the inevitable WD40 thread into this one for the sake of convenience? Thanks.
Subjectively Insane
Bikes: '09 Rodriguez Adventurer Custom, '08 Trek 7.3Fx
Wait, storing steel in a water based cleaner is a bad idea?! Herp derp.
Bikaholic
Who'd a thunk it? Seriously, it's not rocket science. Clean the chain. Lube the chain and then store the chain but this idiot stored the chain for 5 months in a container of Simple Green and then complained that it did something to the chain. I wouldn't store the chain for that long in any cleaner.
We are rebuilding an old "dumpster" Raleigh Super Course and need to de-gunk the derailleurs, which are caked with grease and dirt. Would soaking them in a Simple Green/water dilution, and then cleaning them with a toothbrush, work OK? This thread has addressed soaking for weeks (bad) and spraying on and rinsing off (fine) but not a short soak. I'd rather not use fuel/chemical degreaser if at all possible -- we have a young kid and a cat around, besides which it's terrible for the environment.
Quoted: 2432 Post(s)
Liked 638 Times
I used Simple Green for years and years and years on my chain and cassette. Never had one single issue, you can't convince me it's bad to use. Just make sure you spray it off good and relube the chain obviously. Now I use Totally Awesome degreaser since a bottle is $1. Works just as well. I pour into my snap in chain cleaner thingy.
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 704 Times
I would use kerosene to dissolve the old sludge. Wash the chain and parts thoroughly, then re-lube. Allow the kerosene to sit for a while and the sludge/dirt will settle out. You can reuse the kerosene when it's clear.
My experience with the Simple Green soak & water rinse is that it allows water to penetrate into the chain. Applying oil to the chain never completely displaces the water, so you end up with rapid rusting and wear.
Jeff Wills
Jeff Wills
We are replacing the chain; it's just the derailleurs and some related parts that need to be cleaned/degreased. Not sure if that changes the strategy or not.
Quoted: 802 Post(s)
Liked 704 Times
It's a pretty good degreaser for old parts. Just don't let them soak, rinse thoroughly, and oil any pivot points afterwards.
Jeff Wills
Jeff Wills
Quoted: 9 Post(s)
The "environmentally correct" crowd has got it sooo wrong! Good luck.
