Gravel bike choices in the $1300 range
Before I buy, I'd like to get some advice. My budget is 1300.00 plus shipping and tax. I want a bike with a fairly nice groupset, light wheels and hydraulic brakes. I've narrowed it down to just one, the Canyon Grizl 6. It has DT Swiss LN wheels and hubs and a GRX400 2x10 groupset with GRX600 cranks. The GRX groupsets come standard with hydraulic brakes. I can live with the 2x as I will be doing some road biking also and all my gravel is pretty flat. I've done a lot of research and I can find no other bike that comes close to this. Most all of the other bikes I have looked in this price range come with mechanical brakes and something along the lines of a Claris, Altus, or Advent groupsets. I have no interest in those. They are two steps below the GRX400 groupsets and they don't have the option of hydraulic brakes. Well, I can't speak for the Advent X, I'm not sure where it stands in the groupset world, but I haven't seen, and I don't think there is an option for hydraulics. I may be missing something, but I have yet to find a better deal than the Canyon in this price range. I'm real close to pulling the trigger.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
That Grizl 6 looks hard to beat at that price point, IMO. I really like that fact that they have 7 different sizes, which is unusual these days.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
It sounds like you have done good research and found a bike that fits all of your parameters. Another option would be the used market, but it can kind of be a gamble, and/or you might have to wait a while to find what you're looking for.
Be sure to share some pics of your new Canyon when you get it.
Yea, I actually could not believe I found that bike with about everything I wanted, at the price I wanted. I see a lot of folks buying less expensive bikes and then upgrading wheels and changing out the mech. brakes for mech/pull hydraulic brakes and in the end, spending more than the Grizl 6, but with a lower level groupset. I test rode the entry level Specialized Diverge over the weekend and I was astounded at the low level of parts at a 1300.00 price point. The frame was really nice. Yes, the frame was really nice.
Habitual User
Liked 8,099 Times
I got lucky on the used market (Pinkbike), and found a good build (2x11 Ultegra mech/hydro, American Classic wheels) on a little-known brand, Taiwanese-built CF frame for $1200. I bought it without test-riding, and it's been great for me. As I said...I got lucky. I spent about a month searching many different used bike sources, including local. I was close to pulling the trigger on a lower-spec Giant for about the same money when I came across the one that I ended up buying.
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
edit -- you could check TPC too, but even their stock (at the moment) doesn't include anything around $1300.
$1300 range, w hydraulics? That's hard because the groupset itself is around that price, so you may end up completely compromising in other areas.
Maybe the Ribble CGR AL? https://www.ribblecycles.co.uk/ribbl...ku=BBCGRAOR010
--Just throwing in something (else) to think about....
*For what it's worth, my budget was more than $1300, but I scoured high and low regardless of budget for something to be a 1-bike, N+1 killer. I ended up with an Obed GVR (carbon, w GRX 810)
Habitual User
Liked 8,099 Times
Hydraulic brakes seem to be a pretty important part of the OP's choice.
Quoted: 1083 Post(s)
Liked 687 Times
I saw that, but perhaps he might consider that he could get a better overall bike by foregoing that one thing. Personally I'd much rather ride steel with mechanical brakes, than aluminum with hydraulics, wouldn't you?
Likes For Jeff Neese:
Habitual User
Liked 8,099 Times
For a gravel bike, definitely not. I would take the alum/hydro option, vs steel/mech. Probably on the road, too. I’m not particularly enamored with steel frames. (YMMV).
Hate to say it, but based on that description, the Grizl may not be the best option because its geometry is far more "drop bar mtn bike" than "asphalt plus crushed gravel" -- I spent an inordinate amount of time staring at bikes a year ago. The Grail AL is better suited for that description. $1700 w GRX400.
The Grail Al 6 and the grizl 6 seem to have the same geometry, almost exactly. I don't think I looked at it close enough the first time or maybe I was just got confused. I have looked at a lot of bikes on Bikeinsights.com. I may have to re-think this. It is on the aggressive side and I am 57, I like a little slack.
I like both. At the moment I am building up an old vintage steel frame into a gravel rider so I'd rather go AL for the new one. But I may have to bend a little and get mech brakes.
Sunshine
Quoted: 10965 Post(s)
Liked 7,493 Times
The Straggler comes with vastly inferior performing brakes, inferior wheels, inferior quality tires, and I think it also has an inferior drivetrain. Oh, and the Straggler maxes out at 42mm while the Grizl can handle 50mm tires.
The two bikes do come with the same saddle though, so the Straggler has that going for it, I guess.
Your schtick of assuming others think like you, while already knowing what you think is 'best' is a very uncommon position on this site, is beyond old. It grew old hundreds of posts ago.
I have no idea why anyone would prefer Avid BB7 cable brakes with QR and seat-stay postmounting vs Tiagra level hydraulic brakes with TA and flatmount. BB7 brakes are unimpressive and offer almost none of the benefit of a disc brake setup compared to some $12 vbrakes.
Also, the aluminum frame is not inherently bad, despite your ignorant views. The carbon fork is not inherently bad, despite your ignorant views. The steel frame and fork are not inherently better, despite your ignorant views. You have no idea the butting profile of the steel frame and it very well(almost certainly is) overbuilt and dead to the point of not taking advantage of the elusive magical steel feeling.
Liked 687 Times
Truer words were never spoken. If you know the products you're interested in, you can set up searches and alerts for SearchTempest (Craigslist), FB Marketplace, eBay (local), and others. Then just make it part of your daily routine to check what comes up new for sale each day, that match your criteria. Of course you have to be ready to jump on something that pops up.
Most of my bicycles came to me not because I was specifically looking for a new bike. I have them because I browse the listings every day and the law of averages dictates that once in a while something pops up that I just have to buy. A lot of my home audio equipment and home theater system is the same way. Also true with used cars. If you have the luxury of waiting and can be patient, that's when you the find the awesome deals. But you really need to be in the habit of looking every day, because the awesome deals don't last long.
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
For the OP, make sure you follow Canyon’s sizing recommendations, they size their bikes weird. I bought a new Canyon Grail a few years ago and it’s been a fine bike.
Likes For sarhog:
Liked 687 Times
Personally, I don't see any aluminum bike being worth $1300 no matter what they bolt onto it, but that's just me. Obviously a lot of people disagree and we should all be OK with that.
Sunshine
Liked 7,493 Times
To me, none of that suggests drop bar mtb, much less screams it.
The Ribble option you offered up is really cool. I genuinely didnt think there would be anything with hydraulic disc Tiagra level components for less.
Liked 687 Times
Downtube shifters are more suitable for road bikes and would be awkward on that type of bike. Besides, he probably wants indexed shifting so there's nothing that would work anyway. Rim brakes would be fine but those are almost non-existent in this space, so you're going to be forced into disc brakes whether you want them or not. It's the hydraulic part that is a big ask for this price point.
Sunshine
Liked 7,493 Times
What makes the Straggler a better overall bike? Inferior brakes, significantly higher cost, inferior tires and wheels, inferior tire clearance...is it really just that the Straggler has generic and unknown spec steel tubing while the Grizl has an aluminum frame and carbon fork? Thats seen as a feature to many, not a drawback.
Quoted: 1401 Post(s)
Liked 1,886 Times
But for me (and alluded to in prev post) - the steel would need to be high-end butted thin wall tubes etc - just about anything else will be on the heavy side and probably would not have the ‘lively’ feel. You gotta pay $ for high-end lightweight steel.
Liked 1,886 Times
mech disk brakes will disappoint - and will be costly to upgrade
( I’m currently in the process of rebuilding / upgrading a Topstone to hydraulic brakes etc )
Likes For t2p:
Liked 1,886 Times
unfortunately appears the Grizl is currently shipped with FSA crank and not a Shimano crank
and not too thrilled with the GRX 600 crank (compared to GRX 810 crank) - but would rather have a GRX 600 crank over the FSA crank
Quoted: 394 Post(s)
Liked 197 Times
not even the grizl with a <gasp> suspension fork? https://www.canyon.com/en-us/gravel-...rahmenfarbe=GN
From Canyon's website:
So yeah, there are a couple other minor differences that make one more the backwoods-bikepacker than the other: 45mm tires on the Grizl vs 40 on the Grail; the Grail has fewer mounting points for racks and stuff; the (minor) geometry tweaks. So, going off of one sentence (heck, just a portion of a sentence at that), I thought I'd poke the discussion
The short answer: Both are gravel bikes. The Grail is optimized for smoother off-road surfaces, while the Grizl is better suited to rougher terrain. The Grail is more efficient on-road, but slightly less capable than the Grizl off it. Along those lines, the Grizl is more comfortable on the rough stuff, but not as fast on the smooth.
