Accurate scale???
Quoted: 339 Post(s)
Liked 632 Times
Accurate scale???
I have been using a digital hanging scale to weigh bike frames and finished bikes.
The scale has become innacurate, giving different weights every time.
I have replaced tha batteries and it appears to be working . it is just wildly inacurate
Please please please, someone, tell me you have a scale that can accurately weigh light (under 1 lb ) and heavy (50 lbs) items.
Quoted: 1304 Post(s)
Liked 1,912 Times
The one I use is over $500 but vey accurate. How much you want to pay? Smiles, MH
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
I have a Park Tool one, and I noticed that a local coop's scale (same model) was a little optimistic in its weighing. Great for feeling good about a big bike weighing less than what I hoped, but ultimately not accurate. My PT unit has many fewer weighings on it, but curiously, it gives two different weights when you toggle between Bald Eagle Units and Metric (if you calculate the conversions). I go for the lower number.
A friend @Dfrost gave me a tiny hang scale years ago and I've used it to corroborate other scales' readings as it has matched them well, so now it can do so for my PT scale. This sounds like a bad response: "Why doncha just buy another hang scale and see how it does?"
How long have you had this scale? What brand and model?
Quoted: 4806 Post(s)
Liked 3,932 Times
Does anyone know where to get calibration weights of size, accuracy and cost appropriate for bikes? Say an ounce and a pound or metric items in that ballpark. Also where one could take say a 10 pound barbell weight and weigh it on a calibrated scale? (Of course, everybody is going to know you are buying or selling pot, so keep an eye out behind.)+
Likes For 79pmooney:
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times
I’ve never had good luck with hanging scales being or staying accurate. I use a kitchen scale for smaller items and a bathroom scale for larger. Just weigh yourself first, then weigh yourself holding larger item (e.g. bike), and take the difference.
Likes For panzerwagon:
Likes For oneclick:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
Of course that depends on the temperature of the water. I’ve got a cousin who weighs the water when he makes coffee because the volume isn’t anccurate enough for him in all conditions.
I use a cheap fish scale from some Taiwanese manufacturer. Is it accurate? I have no idea. It’s at least reasonably consistent.
My Bikes
My Bikes
Likes For Andy_K:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
IMHO, if you are wanting accuracy, you need two different scales to weigh items < 1 and > than 50.
Quoted: 1106 Post(s)
Liked 1,328 Times
About half a percent from 15 to 35 degrees, the former about a tenth of a percent lighter than at standard temp.
Weigh the bike with flat tyres; a smallish one will have a volume of around a sixth of a cubic foot, which weighs 0.0807 - five more of those gets you to 90lbs but weighs that much.
When E.T.s sold motor-bikes they'd get tested with the smallest madman they could find, and just enough fuel to do one run.
Quoted: 811 Post(s)
Liked 1,024 Times
Hookes law works. No batteries needed. In this case, I did check the scale by putting the green dumbell on a digital scale and finding that it weighed 12 lbs. This is good enough to weigh a complete bike.
The mechanics of measuring using a load cell are equally reliable, but the electronics can sometimes go bad. No lead solder, bad capacitors, components made at the lowest cost possible are the usual culprits.
Quoted: 3514 Post(s)
Liked 2,927 Times
Get some calibrating weights and go crazy.
Bikes: 57 ExpressWerke, 58 CinelliB, 62 CinelliB Altenberger, 70 Cinelli SC, 76 Masi, 77 Colin Laing, 78 Ritchey, 80 Jack Taylor, 82 Appel, 82 Davidson, 85 Ironman, 92? Andy Gilmour, 04 Peter Johnson, 91 Ed Litton, 11 Bianchi
Quoted: 96 Post(s)
Liked 451 Times
I use this for shipping and bikes. Just weight myself with and without the bike in hand, and do the math. Works for me!
Scale
Guy
Scale
Guy
Quoted: 1609 Post(s)
Liked 2,216 Times
A scale is most accurate in the middle of the range and worse at the extremes.
I use a Park and all I want is a ball Park number.
Likes For SJX426:
Liked 3,932 Times
But accuracy? Until you calibrate them, who knows? And all my water measuring devices are glass containers that get bigger as they go up, so the error in the judged contents goes up as you fill it. Measuring cups. Cooks don't seen to have our obsession.
Quoted: 1944 Post(s)
Liked 2,164 Times
I use a digital kitchen scale for lower weighted items. It works great and can accommodate anything you can get to balance on it; from pool cues to wheels to pedals.
I’ll use a digital hanging scale/luggage scale for heavier items.
John
John
Liked 3,932 Times
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,611 Times
During the pandemic I got these scales from a fishing equipment store. I had decided I wanted to see if I could build a fendered bike in my (large) size weighing no more than 10kgs with what I had in my parts bin.
What a 64cm bike weighing 10.00kg looks like:
I have no idea how accurate it really is, but I learned a lot (the French really know how to do light) and it kept me off the streets for weeks.
Likes For non-fixie:
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 955 Times
I have a scale built into my bike stand (from Performance) which I use for ball park weight, it seems reasonably accurate, but I don't care enough to even check the accuracy. The only time I'm really concerned is for shipping and I use a high-end bathroom scale.
Quoted: 3811 Post(s)
Liked 6,716 Times
My scales all tell me that my bikes are too heavy and that I've recently put on 5 pounds. That can't be right.
Likes For nlerner:
Quoted: 1829 Post(s)
Liked 3,380 Times
I've never needed to accurately measure weight, but if I did, I'd probably look into the stuff that McMaster Carr sells. It's probably not the cheapest, but at least they can give you an indication of the accuracy.
For under a pound, the kitchen scale will do pretty well.
For 50 pounds, this hanging scale says it is accurate to 0.1 kg. Only $140.
Steve in Peoria
Steve in Peoria
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
Answer, for yourself, what accuracy you need to have and whether that accuracy is meaningful or actionable. While I love a good engineering pursuit - for the fun of it - I probably couldn't tell the difference between an 8.0 kg bike and an 8.2 kg bike on the road.
