Airing up your house bikes
Quoted: 1609 Post(s)
Liked 2,216 Times
I keep my favorite bike of the moment in my home office. I also like to keep the tires inflated.
Here is how I do that without moving the bike out o the room.
PortableAir on Flickr
What do you do?
What do you do?
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,449 Times
Same idea. I use a battery-powered inflator that I have hooked up to a Bontrager canister for mounting tubeless tires. The canister also works as a Shrader to Presta valve adaptor/pressure buffer.
Quoted: 5224 Post(s)
Liked 3,585 Times
nice looking air chuck!
my pump is smaller than my bikes. I often move the pump to the bike
Likes For rumrunn6:
Liked 2,216 Times
My pump is 20 gal tank with pump mounted on top. Not something I can move easily. The yellow tank is quiet and fast with 110 psi max.
Quoted: 3464 Post(s)
Liked 2,831 Times
Watch for the lobbyists for Nitrogen inflation.
avoid the nitrogen narcosis though,
scuba divers know.
scuba divers know.
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
Just your generic floor pump used here.
Likes For USAZorro:
Quoted: 970 Post(s)
Liked 1,634 Times
Likes For zandoval:
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 377 Post(s)
Liked 1,090 Times
I work around the "problem". As the house bikes are too many to keep inflated I just keep them IN the air. It keeps the tires round even if they are empty, the bikes from falling over and one can use the vacuum cleaner without all the hassle of moving the bikes around.
Double as a workstand for small tinkering.
When air is needed the old Silca never fails
Likes For styggno1:
Liked 2,216 Times
Go two of those.
P1040744 on FlickrPXL_20221201_130323696 on Flickr
Have couple of bikes in the air too. Bike fall view
P1030684 on Flickr
P1030684 on Flickr
Likes For SJX426:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I use either this Joe Blow or my Milwaukee inflator
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3206 Post(s)
Liked 1,848 Times
Park tool floor pump that I’ve had for many years. It’s on its third or fourth chuck.
Likes For seedsbelize2:
Quoted: 4513 Post(s)
Liked 6,392 Times
This is my everyday go to, amazing and works great, goes in the car on all trips and saved my azz going to Eroica fighting with a leaky car tire.
There are a zillion of these out there now now but I am very happy with this one and it has been in service for almost 3 years now.
Silca in the basement for shop work and airing some of the house bikes.
Likes For merziac:
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
I just got a new Silca pump and I have to say I'm slightly disappointed. Glad the subject came up because I'd rather not post a Silca slander thread until I know if I'm doing it right.
My two complaints are that the Presta adaptor does not stay in place very well, and the pump is much harder to push down than most comparable sized pumps.
The instructions that came with it are pretty minimal, so what am I doing wrong?
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Does it have a name?
Rechargeable? Looks cool!
Likes For clubman:
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
I have a Zefal floor pump that I use before I ride any of the bikes. I just let the other tires gradually go flat between uses. Since most of my bikes hang from hooks, I don't see this as a problem.
Likes For John E:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Only six bikes, so if one is completely flat, I know it has a leak.
I have Pepe inflate them all from time to time after he tends to the pool and garden.
Likes For P!N20:
Quoted: 3515 Post(s)
Liked 2,929 Times
I use a Silca Pista Plus that is finished so well that it looks like it belongs in the house.
I mostly use my Silca Magnum Force.
Basically just a regular Silca Super Pista, but, with more, uh, girth. The physics of said extra girth make it physically impossible for me to air up anything to over 70psi or so. Which is fine since the most I air anything of our bikes to is 65psi
Likes For fliplap:
Liked 6,392 Times
Quoted: 3245 Post(s)
Liked 2,093 Times
Dunno, my Kobalt 17 gallon AC makes a hell of a racket when it’s adding air. I do not leave it powered up to replenish. Thus I really only use it to blast air into my bike tubeless tires. I did recently buy a nice Joe Blow digital unit as I run my mt bike front tires tires at 15 psi and cannot read that on analog pump heads. The Joe Blow is a nice and easy unit to use.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
We used to use those, but my wife got the magnetic baskets to mount on the side of the fridge (not that you have room for those)- I like the baskets because it's easier for me to find what I'm looking for.
Commence to jigglin’ huh?!?!
Liked 1,703 Times
I have 2 pumps- an SKS Rennkompressor and a Leszyne thing. I like the SKS better. I used to have a Planet Bike unit that I sent along with the little boy for his and his wife's bikes.
I'd like to get one of those fancy chucks... and maybe a larger dial since I'm dreaming about it.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 369 Post(s)
Liked 467 Times
How often do you need to recharge your tank? Hopefully your work utilizes air compressors.
I used a tank in this manner to run a brad nailer inside my house to install moldings.
Works fantastically. And very quiet. You only need to put a regulator in place of the chuck.
