Exercise routine help
Hello, I know there are threads about heart monitors and cadence sensors. I basicly want a affordable and easy to use real time heart rate and cadence feedback. I want to figure out a sprint and recover exercise routine. Once I know what it feels like I will probably ditch the heart moniter and maybe both of them. If I can do it with my phone or phone and another device that would be great. I don't care about my route, or my top speed. So far I've been standing and mashing and sitting and spinning, but I would like to know my heart rate and my cadance. I don't think my heart rate is high enough for what Im trying to do and I don't want to go back to running (sprint and recover). Any advice is greatly appreciated.
Ride On!
Bikes: Allez DSW SL Sprint | Fuji Cross
Quoted: 227 Post(s)
Well if you want accuracy down to interval and recovery periods, I’ve found that there is nothing more accurate than a chest strap. I use the Garmin premium and have nothing negative to say about it. I previously used a wrist monitor for years, and was constantly getting frustrated with drop outs and time it took to ‘stabilize’ or adjust to spikes.
I don't know if my phone does ant and I didn't see blue tooth on the Garmin premium.
Phones tend not to do ANT+.
I have a Polar H7 Bluetooth+ heart rate monitor. It can talk to many fitness apps on mobile phones. I use it for running and weight training. It is extremely accurate, to the point of medical equipment accurate - I also have my own portable ECG machine at home for comparison.
For cycling it's a little bit more tricky as you'll need a cycling computer with Bluetooth+ sensor capability if you want to use the same Bluetooth+ chest strap.
Specifically for cycling I use a Garmin Premium heart rate chest strap paired to my Garmin Edge 1000 cycle computer. I also have cadence and speed sensors on my bikes so the Garmin Edge 1000 reads data from all of them during a ride.
The Garmin Edge 1000 then uploads my cycling activity to Garmin Connect (website) at the end a ride and this data is then picked up by Endomodo so all my fitness activities end up in Endomondo fo analysis.
That's the mechanics of how my fitness metrics work.
If you can find a cycling app for a mobile phone AND cadence sensors that will talk Bluetooth+ to a fitness app AND the fitness app can read data from a heart rate chest strap then you'll be able to use your mobile. Bear in mind that it will zap your phone's battery very quickly so you'll probably need to keep your workouts at under an hour or so.
Dedicated cycling computers have a big battery-life advantage over mobile phones, plus you'll be able to see the screen all the time when you're riding. I've got my Edge 1000 to warn me visually and with a beep when my heart rate exceeds a given value which is great for HIIT training within safe heart-rate limits.
Thanks, there are so many different products. I may just try to start with the hart rate monitor till I can sort all the cycling fittness apps out.
Quoted: 2604 Post(s)
Liked 1,933 Times
From cheap to expensive:
1. Cateye Strada with cadence ($50) bike computer for cadence, $100 or so Polar HRM -- chest strap plus wrist unit you could mount on the bars. You'll have to keep track mentally of what it takes to get your pulse up.
2. Cateye Strada with cadence ($50) bike computer for cadence, Wahoo Bluetooth HRM strap ($60?), hooked to some app on your cell phone ($??), cell phone holder ($??) More trouble to put all the parts together, and again, your brain is the recording function.
3. GPS with matching (ANT+ or Bluetooth) HRM chest strap and cadence, Garmin 520-ish or Wahoo Figure it'll cost $300-400 to get it all. One time set up and pairing headache, but it should record all your data so you can look through it after the ride to figure out what your plan should be.
knoxtnhorn
Road Cycling
2
01-08-14 08:25 AM
peterbotwin
2
02-01-13 07:16 PM
