28h rear disc build, 3xDS/2xNDS
Old 07-16-21, 08:07 AM
50voltphantom
50voltphantom's Avatar
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times in 47 Posts
Looking to build a 2nd set of wheels for my CX bike. The first pair I built using the same brand of hub and rim, laced 32h 3x, resulted in 2mm of clearance between the NDS spokes and the rear disc caliper. This time the hub is 28h and I don't want to risk the NDS spokes rubbing the brake. Looking at lacing it 3x on the drive side and 2x on the non-drive side to ensure clearance. Thoughts?
50voltphantom is offline
Old 07-16-21, 08:35 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4212 Post(s)
Liked 3,883 Times in 2,318 Posts
I suspect the clearances differences will be rather small between 3x and 2x. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 07-16-21, 08:41 AM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times in 337 Posts
Your lacing pattern is fine. The NDS spoke tension will be about 50% of the drive side so reducing the crossing won't have any real affect on durability.
Nessism is offline
Likes For Nessism:
