I want to replace my front fork, need help.
genesis onyx 29'' cruiser. I want to replace the front folk with a springer style fork but I do not know what all the specs mean so I am having issues.
This fork says right on it that it will fit my bike with the conversion kit they sell for it, they even have a picture of it on my bike... but it is chrome and my bike is all bleck
https://www.bicycledesigner.com/bike...---chrome.html
this one is the color I want and seems to have the same stats? Would it work the same as the other one?
https://www.bicycledesigner.com/bike...k---black.html
Can I use that?
Here is my bike so far
Can I use that?
Quoted: 1944 Post(s)
Liked 2,164 Times
Your best bet is to contact them.
You might also want to post this question in the Beach Cruisers sub-forum.
John
John
Quoted: 5224 Post(s)
Liked 3,585 Times
nice bike. maybe just use bigger tires & run them with slightly lower pressure. save yourself the hassle & expense of swapping the fork
Rhapsodic Laviathan
Can I use that?
Can I use that?
Rhapsodic Laviathan
That's not proper replacement for a suspension fork, the tires have a max pressure of 65psi, anything under 50 is practically running flat. The widest tire it can probably run is a 3.125. Not much hassle swapping a fork on a cruiser, and people like those more for the look, than the ride they give. Because customizing and modding bikes- which it seems he's doing, looking at the 2speed kickback hub, laced to that wheel.
Likes For Jax Rhapsody:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Any chance you could just paint/powder coat it ? That may be the route if the other fork is a no go. If you choose powder coat make sure they properly plug all the holes or you will have trouble with bolts etc. not going through. Also it would have to be baked to harden the coat. May affect the spring. Otherwise a quality paint may set you up.
Cool bike.
Cool bike.
Rhapsodic Laviathan
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
I've added Springers to several different bikes.
Assuming that the head is the standard 1" issue and the headsets are comparable. The only Spec to worry about is the steer tube length. You will need a springer fork with a steer tube at least 1/2" longer than what you have (allowing for the thickness of the upper spring bolt adjusting plate). A bit longer yet, is even ok since the extra space can be taken up by spacers or a light bracket, etc.
A springer for a 26" wheel has A Lot of room above the tire (2.5"+) and it makes the bike stand up a little bit. Many times the spring adjuster bolt won't be long enough to get it to lay back down. Its a balance of weight distribution and rider weight/seating position.
Also... A springer for a 24" tire frame bike, using a 26" tire will put the tire about an inch from the fork head. Some people balance the look that way.
There are also different rakes of forks.
Looking at the bikes head angle and seat position, depending on the rake of fork, it may not spring very much.
Also, if it does spring well you will notice that active suspension bikes are harder to pedal since the springing action absorbs a lot of forward motion.
Springers are for what you are after though, they are just for looks.
Likes For macstuff:
