Clean tires matter?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 337 Post(s)
Liked 786 Times
Clean tires matter?
I clean my tires after each ride with a spray on tire cleaner just so they look good. I then started wondering if keeping the grime to a minimum helps maintain their RR rating, grip characteristics, etc….or makes a zip of difference?
And I’m referring to road tires, not a gravel tire carrying a pound of mud.
Should Be More Popular
Quoted: 22689 Post(s)
Liked 9,032 Times
Likes For datlas:
I am sure whatever you are cleaning your tires with, it is not improving their performance in any way. Whatever residual chemicals are left on the tire surface from the cleaning would probably reduce friction, not enhance it, but it would quickly wear off the contact patch anyway.
How is it that you are you getting your road tires so dirty that they need cleaning after each ride? I never clean my tires and they are clean enough to roll across the living room carpet. Even if I were to roll thru something dirty, like wet silt, the dirt wears off pretty quickly by just riding the bike.
Likes For mihlbach:
Liked 3,074 Times
If it's containing chemicals that prevent degradation & protects from UV, it might have a worthwhile impact.
if it's just for a shine, it might increase plopping on hard surfaces.
-Oh Hey!
-Oh Hey!
Liked 3,074 Times
30+ miles & it's usually poop.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 571 Post(s)
Liked 604 Times
I have too many bikes so use Aerospace 303 to clean my tires and prevent dry rot and can not detect any difference in performance with clean tires
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2651 Post(s)
Liked 5,823 Times
Excellent product. Have used it on my cars for years. Never thought about it for the bikes but might be worth considering to prevent dry rot.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
During bad weather I do wipe my tyres down with a damp cloth for a very simple reason. The damp cloth makes the rubber look blacker which means that any little flints embedded in the rubber stand out. I can then get them out before they work their way through and cause a puncture. This tends to be more of a problem in bad weather - I presume the flints get washed down onto the roads by the rain. In my experience it is the major cause of punctures around here so an ounce of prevention is worthwhile.
After every ride, I use a rag to wipe down the riding surface of my tires just to check for any gouges or metal/glass stuck in that might turn into a puncture on the next ride. I doubt anything like 303 would either harm or help the tires in any meaningful way, but since a lot of the high end tires claim miracle compounds, could be some impact.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 943 Times
I use a sponge with hot water and a spot of dish liquid to go over the tires with after a ride. This enables me to be certain that there is nothing that I need to know about. Paying attention to thin, racing tires is important, and this gives me the opportunity to assess every aspect of them. Once, I wiped the tires down and saw a patch of bubbles (slow leak). I generally use 700x23 tires at 200g of weight. If they get me home, safe-and-sound, I give them some T.L.C.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Liked 3,074 Times
I've found the products containing graphene reduced sidewall fraying... it's my findings, ymmv.
-Oh Hey!
-Oh Hey!
Quoted: 830 Post(s)
Liked 1,970 Times
Hmm. I clean the sidewalls with a cleaning wipe because my main bike has reflective strips and I sometimes ride in the early morning before dawn.
Quoted: 6313 Post(s)
Liked 4,904 Times
Other than cosmetic looks and perhaps the safety aspect that CAT7RDR mentioned, I doubt that much is being done for the short life the tires will have before the threads are showing or its get to what ever point of wear that you replace them. Perhaps if this is a seldom ridden bike that you take out once a year and the tires can last twenty years or more, perhaps it helps.
As always YMMV, particularly those that have unique conditions for both riding and where they store their bikes.
Quoted: 839 Post(s)
Liked 1,691 Times
Tire shine products are okay on automobile tire sidewalls. But, I've seen the effects of tire shine on motorcycle tires. Looks nice, until you lean into a turn and the bike goes out from under you.
Personally, I wouldn't use it on a bicycle tire, either. I can hear the EMT's now. "Wow, that was quite the crash you took on that twisty descent there. Don't worry, we'll get you to the ER in no time. By the way, your bike tires look really shiny!"
Quoted: 5234 Post(s)
Liked 3,608 Times
my car is always more zippy after a carwash
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
I'd be concerned about residual chemicals that might affect tire adhesion, like when leaned over into a curve
/markp
/markp
Likes For mpetry912:
Bikes: yes, i have one
Quoted: 1151 Post(s)
Liked 1,193 Times
never in my life have i even considered cleaning my tires. why would i? the moment i started riding they'd be dirty again. at least a frame can stay clean for a few rides.
Likes For spelger:
Likes For LarrySellerz:
Quoted: 4227 Post(s)
Liked 2,489 Times
Likes For soyabean:
Quoted: 4853 Post(s)
Liked 3,990 Times
My tires get accidentally rinsed off when I spray muck and dust off after rides. But if the bike looks OK (or the hose faucet is off for the freezing months) I don't bother. Never did this in my racing days or before I bought a house. So apparently I've experienced all the bad that happens with dirty tires. And stayed completely oblivious. (I wonder how many Tours I could have won if I had only cleaned my tires.)
Likes For 79pmooney:
Grupetto Bob
Liked 5,823 Times
I originally got the idea because I used Comet and a brush to clean white wall tires.
Quoted: 511 Post(s)
Liked 648 Times
Are you saying you clean your bike after a 30 mile ride because "it's usually poop"? I suggest you quit riding in cow/sheep/pig pastures. I clean my bike every 350 miles or so, and lots of times the only thing really needed is clean/lube the chain.
Likes For KerryIrons:
