Using 8 Speed Chain With A 10 Speed RD
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Not C&V but has anyone had experience using an SRAM PC850 6-7-8 speed chain or similar width chain with a new Campy Veloce 10 speed rear derailleur?
Campy Veloce RD11-VLBXS
Reason for this choice is vanity and aesthetics. I like the way this RD looks.
I have 8 speed parts that I'm putting on a new frame that will have all black components.
No need to go Spinal Tap here, 8 speed is just fine.
I'm using SRAM PC8x0 chains with Campy 9 speed derailleurs and Shimano 8 speed cassettes on several bikes without any problems.
My concern is the 10 speed cage may not be wide enough for smooth operation with an 8 speed chain.
Chain widths:
6 speed – 7.8 mm (5/16 in) (all brands)
7 speed – 7.3 mm (9/32 in) (Shimano HG), 7.1 mm (9/32 in) (SRAM, Shimano IG)
8 speed – 7.3 mm (9/32 in) (Shimano HG), 7.1 mm (9/32 in) (SRAM, Shimano IG)
9 speed – 6.6 to 6.8 mm (1/4 to 9/32 in) (all brands)
10 speed - 6.2 mm (1/4 in) (Shimano, Campy), 5.88 mm (7/32 in) (Campy, KMG)
Also I'm curious, it looks like some of these Campy Veloce RD11-VLBXS RDs are made in Romania rather than Italy? Any issues with that?
verktyg
Chain widths:
verktyg
Chas. ;-)
Chas. ;-)
verktyg
Liked 1,238 Times
Chain Rubbing On Derailleur Cage
Thanks, that's the kind of info I was looking for.
Campy used both a 6.2mm wide 10 speed chain and a narrower 5.88mm wide 10 speed chain.
Since this is a newer product it probably uses the narrower chain???
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
How about a 9-speed chain as a compromise? I know 9-speed runs just fine on 8-speed sprocket spacing. Never tried it in a 10-speed cage.
Likes For conspiratemus1:
Quoted: 297 Post(s)
Liked 245 Times
verktyg
verktyg
As for Romania, well I can tell you they produce great opera sopranos and tennis players (although Bianca Andreescu was born in Canada, 6 yr after her parents moved here.)
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,095 Times
Campy has been making a lot of stuff in Romania for several years now. I wouldn’t worry about that. Back when I had a couple of 9 speed Shimano equipped bikes, I would use 9 speed chains (SRAM I believe) on my Chorus 10 bike without problems.
Quoted: 378 Post(s)
Liked 1,409 Times
Chain widths:
verktyg
Chain widths:
verktyg
Quoted: 297 Post(s)
Liked 245 Times
OK, @verktyg, here's what I found.
Baseline (10-on-10):
10-sp chain on 10-speed cage (all Campag) -- baseline
10-sp chain on 10-speed cage -- baseline
___________________________________________________________________
Test: 9 on 10:
9-speed SRAM chain on 10-speed cage, View 1
9-speed SRAM chain on 10-speed cage, View 2
The 9-speed chain goes through the cage without rubbing and appears to shift normally on the stand. I didn't want to road test it because I was worried that the 9-speed chain might foul in the 10-speed sprockets where it would be under load instead of being slack as it goes through the cage. You can see that the clearances are closer but it does pass.
9-speed chains are cheaper than 10-speed and the quick links are easily removable; the 10-sp Power-Lok SRAM link is not removable by hand and is supposed to be non-reusable. But in practice it can be opened with the little pliers tool and is then in fact reusable.
Hope this helps.
Test: 9 on 10:
Hope this helps.
Quoted: 569 Post(s)
Liked 581 Times
Looking forward to hearing how it goes, as you have both and have no reason to give it a go.
verktyg
Liked 1,238 Times
I forgot top mention chainrings
Short changed?
What I should have mentioned in my first post is, I'm going to be using new or slightly used classic 5-6-7 speed chainrings and cranks.
Unless the teeth are well worn, narrow chains tend to hang and not shift smoothly on those wider teeth.
This Campy Veloce RD looks somewhat old school like a Suntour Superbe Pro RD.
Image is everything: 7 of 9
verktyg
verktyg
Chas. ;-)
Chas. ;-)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
verktyg
Liked 1,238 Times
Adding Washers
I played around with those washers when I was experimenting with upper pulleys on non indexing RDs to provide some side to side float. The problem that I ran into was pulley screws only have about 4 turns of thread into the inner cage plate.
When you add 1 mm spacing with washers there is only about 2 1/2 to 3 turns of thread engagement. Loctite helps but I found that reducing the width of the plastic upper pulley by 1 1/2mm to 2mm provided lots of side to side float.
I have some Campy NR/SR RDs that index reasonably well. No more two forward and one back trimming of the friction shift lever.
I'd have to buy one of these Campy RDs to experiment with. I have way too many functional, even NOS RDs and I was hoping to get some ideas before spending more money on another questionable experiment.
verktyg
Chas. ;-)
Chas. ;-)
