Gearing Change Serotta road bike
Newly acquired Serotta Road bike (not sure of the year) has Ultegra group set. It’s fitted with 52-42-30 in front and 12-27 nine speed in back. The RD cage is 76mm c to c. I need touring gearing for the hills so I decided change the cassette to 12-36 and install a longer cage derailleur. I have an Ultegra RD with an 82mm cage and I picked up from the LBS a pretty used XTR RD with an 86mm cage. I don’t know how to figure which derailleur will cover the spread without just trying it. What’s the best place to learn about this?
I’d like to use the medium caged Ultegra RD to keep the group set intact but I’m guessing that it won’t cover the spread.
While I’m at this I also have an 11-36 cassette so what difference will I notice between the 11 and 12 tooth smallest sprockets? What’s the advantage to one over the other?
Is it unusual on a triple to have a derailleur that won’t reach the extremes and just know not to try to shift there?
Sorry for the newbie questions. Thanks.
Quoted: 380 Post(s)
Liked 106 Times
I suspect you will have trouble with the mountain bike rear derailleur as the shift pull is different than road bike shifters on your bike. Use a long cage Road bike derailleur not mountain. Roger
Quoted: 1438 Post(s)
Liked 1,092 Times
Really Old Senior Member
Personally, I'd get a smaller triple. My bikes do because the 48T+ are far too much for a decrepit old guy that NEEDS his close spaced gearing for various medical issues.
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
Front FD is a different story
Friendship is Magic
Bikes: old ones
Quoted: 26383 Post(s)
Liked 10,364 Times
...with your current crank gearing, using an 11 tooth cog on the rear for hills makes no sense unless you plan on pedaling downhill a lot.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
The XTR derailleur you have may, or may not work, depending on if it's an older version or a newer model.
The 11 or 12 small cog shouldn't make much of a compatibility or performance difference.
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
Before 9-speed, Dura-Ace would only play with Dura-Ace. After 9-speed, Dyna-Sys only worked with Dyna-Sys. 9-speed was the Kum ba yah of index shifting systems.
Jeff Wills
Jeff Wills
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
9-speed (or newer) Shimano MTB rear derailleur (not dynasys) is what you need. MTB derailleurs don't have barrel adjusters though so if you have downtube shifters or otherwise don't have one somewhere, you'll need an in-line adjuster.
I should have a better photo of this.
I don't know what my MTBs have for the lowest gearing, but they are so low that I find them impractical to use anywhere I ride. In fact, I don't think I've ever used the small ring for anything other than testing, or when I accidentally go onto it. The lowest practical gear I've had on a road bike was a 34/34, and in San Francisco with the hills it was enough. I suppose if you want to climb trees on your bike you need lower. By the same token, my highest gear on my current bike is a 50/13, not high by anyone's standards, but I've never felt I needed more. When I rode up Mt Haleakala I did wish I had more than the 34/27 that the rental had. Even a 30 in the rear would have been great. I struggled.
That said, 9sp is pretty compatible across all. Dyna-sys is a different beast altogether.
Swap out the 30 for a 24 and put a 39 in the middle. On the back you can put a 30 to give you a 23 inch low gear or leave the 27 for a 25 inch gear. Harris cyclery has a cassette that is good for your use. https://www.harriscyclery.net/produc...ssette-702.htm
If your cassette is still good you can replace the 12 with a first position 13 and add a 30 to the back. They can be 9 speed cogs and will work fine.
Liked 20 Times
With regards to gearing: the 9sp 12-36 has much better ratios than the 11-36. The 11-36 has a 20% jump near the end (15-18) whereas the 12-36’s has a much more reasonable 16-18 jump there. Given your big ring is a 52 you probably won’t need an 11 anyways.
Using a 12-36 with a 30-42-52 will require a lot of capacity (46t), which most RDs won’t have. Shimano’s new M2000/M3000/M4000 RDs are your best option: 45t listed capacity and they officially support the 36t cassette.
mechanically sound
The OP, the way to figure out the spread is to calculate the total wrap capacity you need.(front spread +rear spread) which in your case happens to be 46. (52-30)+(36-12)=46. The wrap capacity should be stamped on the rear derailer or listed in the specs. Voila!
For "touring" gearing, maybe a 13 or 14T might be more appropriate to give you closer steps.
I'd buy either a 13 or 14-25 cassette and mix with a "mountain" cassette with the largest cog you want.
You can make your own.
mechanically sound
Quoted: 170 Post(s)
Liked 264 Times
You will need a RD-M591 SGS long cage Deore rear derailleur to fit an 11-36. This rear derailleur is compatible with your drivetrain and the 11-36 cassette. https://www.jensonusa.com/Shimano-De...CABEgIstvD_BwE
