148 rear post mount
148 rear post mount
I can't find any "official" dimensions for 148 post mount brakes. Does anyone know of any existing threads or external resources for that? I also can't find anything about SRAM's new universal derailleur hanger. I'm not sure if its best to include that topic in this same thread, or if it should be a different one. Thanks!
Quoted: 714 Post(s)
Liked 800 Times
Post mount brakes go in the same place regardless of the axle width. The standard is for a 160mm rotor, but there are specs available for larger rotors. I don't know of anyone making a UDH compatible dropout for framebuilders yet.
I did find a 2D side view with measurements (can't post images or URLs yet), which helps, but I don't know the distance from the left flange.
Quoted: 714 Post(s)
Liked 800 Times
Post mount brake specs can be found in this Shimano Frame fit specs document. I'm not sure why you'd need them unless you're trying to place the mounts without a fixture or making your own fixture.
https://drive.google.com/file/d/0B-G...ew?usp=sharing
I'm just teaching myself CAD, so I want to be precise in my model. I'm also going to see if Waltly will weld up my design in titanium, so I just want to have all my measurements correct.
