Anyone using the TRP "Spyke" brake caliper??
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Anyone with first-hand knowledge of these?
They come to me highly recommended. I see they're WAY cheaper than Paul Components Klamper calipers. Unlike the Klamper they 1. take tools to adjust and 2. actuate both pads
The brakes my bike came with are entry-level Tektros which are a nightmare to get adjusted correctly because the only way to move the outter pad is by loosening the entire caliper and sliding it left or right, then the inner one has a threaded adjuster. Stupid design IMO.
Thanks for your feedback. I am not totally opposed to going hydrolic either, I just don't know if the care and feeding of a hydro system is something I am in to right now. Thanks again
Likes For qclabrat:
You could get cable / hydro calipers. The Juin Tech M1 is one example.
Likes For katsup:
Likes For qclabrat:
I have the Juin Tech R1 (road version) on my Fog Cutter. They feel / stop better than the BB7 that were on my last bike. I've only been using them for about 600 miles, but they have given me no trouble. They don't stop as quickly as full hydro which I've had on mountain bikes.
Likes For katsup:
Quoted: 257 Post(s)
Liked 70 Times
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I used BB7 mtb calipers for years and if you know how to keep them adjusted, they work great, in my experience. Yes, those Tektro calipers kinda suck. My Surly Wednesday came with Tektro calipers, and I replaced them with a set of old BB7s, and it was an improvement. The BB7s let you adjust both pads with knobs at the caliper.
If my XTs give me any more grief this coming season, I may have a set of Spykes in my future.
BTW, don't pay much attention to reviews in road versions of this or other mechanical brakes. MTB mechanicals work better than road mechanical, due to the cable pull ratio. I have bb7 road calipers on my gravel bike and they are not nearly as good as the bb7s on my mountain bikes.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
My levers on my bike have two cable pull settings; one of these days I'll try the longer one to see if that gives me a better lever feel. The bike came set up on the shorter pull setting so I assumed that was correct for the calipers. Right now I am able to bottom both levers out against the grips which I have heard is a no no, even if not, I don't like it.. Then again, stopping has not been a problem in even the steepest of trails where I needed to stop to see how to proceed......Thinking I'll change out the calipers about the same time the pads wear out and try to sell the old ones to defray the cost
Interesting.
TRP Spyre = Road bike version, short pull
Avid used the same name (BB7) for mountain and road so it is more difficult to tell.
Bottoming out the levers is not the fault of the brakes, the cable needs to be tightened. Moving the cable to the long pull setting on your levers may be enough.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
... Or the pads being too far from the disc because they're a b**** to adjust
Advanced Slacker
Liked 2,537 Times
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I CAN modulate my braking and lockup the rear pretty much at-will so kinda just choosing to ignore as well until I can get some calipers which are easier for me to work on. Had it in to my LBS a few times too. He swore at it too. Got the front pretty good which does the lion's share of the stopping anyway.
Thanks so much for your feedback by the way!
