Dura Ace Slant Parallelogram?
Bianchi Goddess
Quoted: 2936 Post(s)
Liked 2,933 Times
When did Dura Ace steal the Slant Parallelogram design from Suntour? I think I missed out on a real deal for an early DA group but I want to have a slanted RD for the smoother shifting. This was on FB for only $200 depending on currency exchange
I looked over Velobase but I really can't tell when it acquires the slant design.
I was thinking this would look great, but kind of retro, on the "Speckled Trout" Bertoni
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 5888 Post(s)
Liked 3,471 Times
Likes For bikemig:
Quoted: 237 Post(s)
Liked 83 Times
Shimano slant parallelograms started with SIS, so 7400. RD-7300 was the weird AX thing. RD-7200 is merely a dual sprung dropped parallelogram that was an evolution of the Crane.
Likes For Kuromori:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The derailleur in your picture is pre-slant parallelogram. As @bikemig notes above, SunTour's patent on the design only lapsed in 1984, and the first Shimano slant-parallelogram derailleur, the Dura-Ace 7400, came out late that year with the first SIS indexed drivetrain:
Bianchi Goddess
Liked 2,933 Times
OK Thanks. That was what I thought, but even the 7400 doesn't look that slanted. I think I'll just keep looking for a VGC Superbe or Sprint or 1st Gen Chorus that won't break the bank
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Once the SunTour patent expired, almost everyone copied the design as quickly as possible, because it makes so much sense.
Bianchi Goddess
Liked 2,933 Times
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
They did. You don’t just happen to have a fully functioning indexed rear derailleur that will soon become the standard for an entire industry in the same year that a patent expires without having done metric crap-ton of R&D first.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I've got one of the old 600s that is ok but definitly not smooth.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Interested in either? I also have a black Cyclone which I believe is first generation.
Likes For L134:
Pedal to the medal
Quoted: 3464 Post(s)
Liked 2,831 Times
Shimano was keenly aware of the looming patent expiration. They had designed, tested and tooled up for the 7400 With SIS and were ready to deliver. Shimano was cunning, 6, 7, 8 cogs, then integrated brake/ shift, tipped the scales and got freehubs popular, which had been around since the EX series but resisted.
( note the planned obsolescence along the way- design stability was over )
Campagnolo by their patent applications was desperate to come up with a patentable alternative in the early 80’s. There was none, the closest that was employed was the extending diagonal rod in the Croce’ mech and the A, B variable geometry - I think used on Chorus.
they really struggled to avoid using the slant parallelogram- even after it was open source.
almost cost them the company.
eventually they got going. Dark days until they did. Must have been a terrible time there, they had been the developer of patents that gave them an edge- then were out developed. Not humble enough to accept outside concepts.
Likes For repechage:
tantum vehi
Liked 992 Times
FIFY
The graphic looked a lot like Campy Super Record (without the slant parallelogram) which in turn looked a lot like first gen Cyclone (the origin of the slant parallelogram). So the real winner here is clearly...
Photo from Disraeli Gears
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
I believe the only company that might have stolen the slant parallelogram was Rino. Everybody else waited until the patent ran out.
Quoted: 237 Post(s)
Liked 83 Times
After SIS was introduced, it became about trying to make a working index system, which was either done by copying Shimano that copied the slant from Suntour, or trying to come up with alternative designs and failing as with many of Campagnolo's Syncro designs. I'm having a hard time thinking of any slant designs other than Suntour and Rino that were meant only for friction, and Rino was making Suntour knockoffs before the patent expired. You can really tell the slant parallelogram derailers are Shimano RD-7400 derived when they have a sprung B-pivot.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
OP mentioned possible differing degree of slant. I have wondered about this, but find it hard to visually verify.
Campy did also have an Athena (and later Xenon) Synchro derailer with a slanted parallelogram, but with very little in the way of a drop-down knuckle (just merely an offset up top would be one way of looking at this). They apparently didn't want to appear "copycat", but soon relented as pressure mounted to achieve indexing perfection with the longer cables of integrated shifters. So this earlier slanted design never made it past when Ergolevers were fitted at these respective Athena and Xenon levels.
Slanted parallelograms have a problem though, which ultimately limits how much slant will still work with how much return-spring tension. Only a non-slanted parallelogram will eliminate any road impact vibration from trying to bounce the cage inward and outward (with only return-spring tension and the cable resisting this tendency). Note that traditional non-slanted derailers are not completely immune to bump forces tugging on the cable and resisting the return spring, but are very much better in this regard when using the smaller end of the freewheel where speeds tend to be highest.
I don't really see any difference between mtb and road derailers in terms of their slant angle, though there are obviously other changes to the cage, springs, etc which allow them to accomodate larger cogs. It's surprisingly subtle how the cage itself helps clear larger cogs on the mtb versions.
I believe it was Colnago dealers who had to strip Rino derailers off of bikes that had been shipped (to the US at least). I came across supplier of these previously-installed NOS derailers some years back, and who was helping to clear out old stuff from the bins at a big Colnago dealer in SoCal.
Quoted: 4722 Post(s)
Liked 3,039 Times
Likes For T-Mar:
Bianchi Goddess
Liked 2,933 Times
I like the 'white' one
MTB rear derailleurs for 2x/3x setups have usually been intended for large cogs of somewhere from 28 to 36 teeth, but with very long cages and a lot of the drivetrain's range coming from the chainrings.
Meanwhile, the rear derailleurs that are aimed at 1x setups with enormous cassettes usually don't need steep parallelograms because they use a large offset between the jockey wheel and the pivot to manage chain gap. This doesn't create any problems if you have no front shifting, and arguably has the benefit of making the rear derailleur "adjust" itself for different cassettes.
SRAM has even made modern 1x-specific rear derailleurs with old-school-Shimano-esque dropped parallelograms.
To add some recent shenanigans into the mix...
It's always been interesting that nearly all modern derailleurs use both a sprung b-pivot and a slanted parallelogram. If the parallelogram roughly matches the slant of the cluster, and if the jockey wheel is placed concentric with the a-pivot, the derailleur should enjoy good chain gap and be almost totally unaffected by front shifts. It will also be mechanically simpler and, since you're not worried about how the derailleur's tensions balance against the b-pivot, you potentially have more freedom in selecting the spring for the a-pivot (and any damping, like with clutched derailleurs). Or, put another way, "why not do an indexed interpretation of a SunTour GT derailleur?"
Anyway, I was putting together a new gravel build, and I chose Shimano's RD-RX810 for the rear derailleur. It uses Shimano's 11-speed road cable pull, it has a lot of wrap, it's intended to be tolerant to wide front differences, and it's clutched to keep things well-behaved on the rough stuff, and all these things seemed to make it a good match for what I was doing. As I took it out of the box and inspected it, I realized that it had no b-pivot spring, and that the jockey wheel was concentric with the cage pulley. It turns out that a number Shimano's non-1x "shadow"-geometry derailleurs are like this!
Quoted: 346 Post(s)
Liked 175 Times
Quoted: 237 Post(s)
Liked 83 Times
Quoted: 346 Post(s)
Liked 175 Times
Quoted: 346 Post(s)
Liked 175 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Dunno. I think the Huret Jubilee is #1 , followed by SunTour Cyclone first gen.
But looking at that Dura Ace, it's gotta be in the conversation.
