Most Slippery TT Positions and 40 K watts
Bikes: Orbea Orca Trek 5500 Trek Equinox
I'm just curious as to how many of you have broken the 1 hour mark for a 40K TT and what your watts were (if you know it). I know courses make a difference, so this isn't scientific, I'm just curious. Anyone broke 1 hour with less than 250 watts avg?
gmt
Quoted: 45 Post(s)
I have broken the half-hour on a 20km TT with 244 watts average. My position is pretty good but there are still a few improvements I could make.
Glimmers of form
Bikes: Cannondale SystemSix 3, Specialized Stumpjumper M4 Comp
I did 50:58 @282 watts on a ~37km loop. Based on that it would have been ~54:50 minutes for a full 40km.
Bikes: Serotta Nove
Quoted: 22 Post(s)
This made me feel a little better about my output.
The cycling blogger Alex Simmons has a great article on the current Masters Men (35-39) Hour Record holder Jayson Austin and his power output over his attempt at the Master’s record in 2009. Jayson’s average power output was 302 Watts over the hour he rode.
I know I suck, but not as badly as I thought before I saw this.
Richard
Richard
Glimmers of form
This thread got me thinking. Don't these numbers look really low?
Bradley Wiggins - Tour de France, stage 1
Time 1:42
Dist 30.95
Average power 213 watts. Boy, that sounds really low????
Time 1:42
Dist 30.95
Glimmers of form
Looks like that includes warmup and cool down.
Lanky G-Raf
Bikes: Giant TCR0 aluminum/carbon with ultegra components. Sintesi (Italian) lugged steel road bike, circa 1987.
I've broken the hour on the 40K. It's not all that difficult with the proper training. And by proper training, I mean going out and practicing time trialing. Not intervals, not going hard for a minute or two, but practicing holding your threshold for 30+ minutes. Work on seeing how low you can get in your position. I've found sort of a sweet spot in mine, where breathing wasn't affected too much.
As a general rule of thumb (and which I can confirm personally) the aerodynamic advantage almost always outweighs the power loss by a more aero posistion. I use the term "power" looseley. I'm a poor grad student that can't afford power meters. But I do have flat roads, a trainer, a HR, and a stopwatch. It's really all you need.
Adjust your position SLOWLY. Give your body time to adapt to new positions. You'll get faster by just spending more time in the TT position.
Another thing to practice is pacing. There was a very good article I read recently about the time advantage of holding back the first 3 miles or so. Also, be sure to practice your start. Practice coming into rhythm.
I personally find it hard to believe the determinism of Power. There are so many more factors than just a number to describe how fast you go.
Ninja don't wear flipflop
Bikes: Specialized S-Works Roubaix SL3, BMC TM01...if it every ships
I've done it a few times on rolling-hilly courses, but never under 300 watts. I think a flat course with no wind I could probably do it around 280-290 and I am 6-4. Someone that is really slick could do it under 250. I'm sure I would hate them, but they could do it.
starting pistol means war
Bikes: Cervelo R3
This thread is fascinating. It is amazing how much better a TT'ist can be through better position and aero equipment. Not a fan of aero trumping ability, but it's the way the sport has gone.
I have a teammate that does 53' on 330w and is sometimes neck and neck with another guy that put out ~ 410w for similar times. My teammate is obviously much more aero.
Bikes: Ridley Noah-Scott Addict-Orbea Ordu
You might try one of the cycling power calculators (such as this one). Since many TTs are on out and back courses you can (in theory) use little to no wind and an average slope of 0%. I don't believe these calculators take other things into consideration such as disc wheels, aero helmets, etc.
Regardless, given the above inputs you can ride a 40k TT in under an hour assuming you weigh less than 170lbs (at 250W). Using 0% grade and no wind, I came within a few % of my actual time, given my weight and power output, from my last 20k TT.
Resident Alien
Quoted: 349 Post(s)
Liked 10 Times
I'd say that's off the mark. The more aero positions tend to drop wattage from what you might produce in your "road bike" position. Some considerably, so you need to start from a position of strength.
It's a balancing act to find the right blend of power/aero, and it takes a lot of time and effort to be able to adapt to a really efficient position.
And a good aero position does nothing towards pacing, and the discipline to ride on the rivet without going over, or losing focus. TT's aren't won strictly on aerodynamics, just as road races aren't won strictly on wattage.
Race to train
Burning Matches.
Quoted: 4077 Post(s)
Liked 1,002 Times
My aero position gives me ~10% less power than my climbing position. It works for me.
I did ~56:30, I think, on a 40K. (Actual 57:xx on a 41k). 280 watts.
ElJamoquio didn't hate the world, per se; he was just constantly disappointed by humanity.
Interesting stuff. I have only done 1 40K TT, and that was such a hilly course ( 10% climbs) that I don't think I can use it as an indicator as to how I'll do on the Flat State TT course next weekend. But, I have done a couple 20K TT's (Horse Country TT) and managed 24.3 mph at a measly 203 watts avg. I'm hoping I can bump that up to 25+ mph to break the hour mark. I was curious what the lowest wattage someone broke the hour mark at.
Burning Matches.
Liked 1,002 Times
What category did you race?
Snail-paced new boy
Bikes: Colnago Extreme Power, Ribble Winter
Damn! I did a 26.12 minute club 10 miler a couple of weeks ago and average was 290w.
I need to get my ass down the wind tunnel!
Bikes: Ever changing..as of 2-24-09: 2003 Giant TCR Team Once, Sampson titanium, 1992 Paramount Series 3, 2003 Cervelo P3, 70s Raleigh Record fixed gear, 70s Fuji SL-12 commuter, mid 90s Klein MTB. Plus two or three frames lurking, plus 5 wife/kids rides
I did 1:01 on 250 watts average a couple of months ago, and I'm built like a tank. My power sucked but I guess the position's not bad.
