Question for Bianchi Oltre XR4 owners
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
I just ordered a Celeste gloss Oltre XR4 and plan to build it with Dura Ace 9150, Zipp 404 NSW's or Bora Ultra 50's. Someone on another forum pointed out the Oltre XR4 pairs best with two front-specific direct mount brakes. Can anyone confirm this? Thanks!
Bikes: Spooky Mulholland
Quoted: 52 Post(s)
Liked 17 Times
Are you saying pairs best or requires? if you are asking if it requires direct mount, then yes it does require direct mount brakes. There isnt a best one to choose from I have two buddies with them and they are running sram E-tap with then Dura ace 9000 direct mount brakes with no problems
Quoted: 20810 Post(s)
Liked 9,456 Times
I think that the OP meant for the emphasis to be on the front-specific part (for both the front and back, I assume), not the direct-mount (vs not) or brand aspect.
Quoted: 376 Post(s)
Liked 124 Times
Quoted: 52 Post(s)
Liked 17 Times
They are saying that they find it best to use two front brakes instead of being one front and one rear. Basically what they are saying is buy one front direct mount brake for the front and then buy another front direct mount brake to use in the rear. As for confirming that this is the way to go, I have not heard anyone doing it or reasoning behind it but maybe the pull is larger (better) stronger making the brake itself a better system.
Quoted: 376 Post(s)
Liked 124 Times
