Dumb move? Rode through deep water
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
Probably a dumb move I didn't think about until after I did it. I rode my 83 Trek 700 through water 6 inches deep very slowly for at least 50 yards. Couldn't pedal all the way through arc or wet feet. Did water get in my spoke nipples? Duh, what a dummy. Double wall wheels. Should I dismount my tires and take off spoke tape? I can envision water in the inner wall now waiting to corrode everything. Help.
Quoted: 18376 Post(s)
Liked 4,511 Times
You probably got water into the wheels.
If you were riding slowly, the bearings are probably fine.
Anyway, if you're worried, why not pop off the tires and rim tape and look inside... and then let dry overnight.
Quoted: 583 Post(s)
Liked 697 Times
Rode very slowly
Yep, rode very slowly. Bearings will be fine. Did a search, so will take tires off tomorrow. Just put them on. Oh well, live and learn. As an aside the Pasela Gravel King 32s rode nicely. Smooth, compliant, and quiet at just under 80psi.
Quoted: 2026 Post(s)
Liked 1,096 Times
There isn't a lot of unoccupied volume in any bike wheel, only the gap between the outer and inner wall on a double wall rim. If any water got in through the spoke holes or tire valve, it can get out the same way. Can't hurt to pull a tire off and see but I don't expect you will find much.
I assume it was fresh water, not salt water? Nearby is a river trail that runs to the beach. It drops down and crosses under the coast highway and during high Spring tides the ocean water floods the river channel and floods the bike path. I’ve seen people ride through this. Salt water, brass nipples, stainless steel spokes and aluminum rims makes for a bad combination. Fresh water, no biggie.
Quoted: 583 Post(s)
Liked 697 Times
Yep, fresh water
Fresh water from a flooded creek overflowing across a paved bike path. Thanks all for the replies. Doesn’t sound too problematic. Just as a learning exercise I will dismount tires to see what is inside the rims.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
Jon
Is your bike the Wicked Witch of the West? A little water and "I'm melting!" Your bike is going to be perfectly fine. I went into a pit of freshly poured concrete that was waist deep, the construction people got me out, hosed me and the bike down and the bike was none the worst for wear.
I did learn something, wet concrete is exactly the same color as dry concrete.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Likes For San Rensho:
Likes For xroadcharlie:
Quoted: 4560 Post(s)
Liked 2,802 Times
Some natural fresh water sources may contain high amounts of minerals, especially in areas with lots of limestone. Rinsing the rim and spokes in fresh water may be a good idea (although my old rural home's two water wells had more limestone content than the nearby lake, especially after fracking disturbed the entire area's limestone aquifer).
After removing the tires, tubes, rim strips, etc., dribble in a drop of Boeshield T9 or WD40 around the spoke nipples and holes. Either will displace water and resist corrosion. It'll also make it easier later to do spoke nipple adjustments for truing. Otherwise the entire spokes may twist along with the nipples.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
What country doesn't place barriers around potential hazards like wet concrete?
I was blatently going through a marked road construction site, the workers were waiving me away but of course I know better than everyone and thats how it happened. All my fault.
1988 Ducati 750 F1
1988 Ducati 750 F1
The dropped
Liked 1,014 Times
I shouldn't cast stones though, I drove between orange barrels the other day at an intersection because they had finished the left side of the road and were getting ready to repave the right side. Thankfully it was only 50 ft or so to the parking lot I was trying to get to, and construction had not begun.
I apologize, but I must be the old, crusty guy.
As kids on our Swingers, Mustangs, etc; those poor bikes saw a heck of a lot worse. We rode not only through water, but into water, we left them in the rain and other than some rust on the chrome, there were very few problems.
Today, with sealed bearings and water proof grease, people act like water is instant death for a bike (not just this thread).
The high pressure of the inner tubes will have blocked most water from entering.
All cables are pretty much stainless.
Periodic maintenance will take care of your bearings and such.
It's a bike, it's meant to be fun.
Have fun
Have fun
Likes For MarcusT:
Quoted: 583 Post(s)
Liked 697 Times
I did it too
Have fun
Have fun
This old Trek is perhaps a blessing, as it is a bit less than perfect so I can learn some things and not be too afraid to change things more to my liking.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Unless this was saltwater, your wheels should be fine. First, none of the materials (Al alloy, SS, brass, chrome plate, rubber) used in rims and wheels are water soluble. And none of them rust. Salt water and spray will corrode aluminum. But unless you finished your ride with the rims under water, you rode a bit AFTER you'd plowed through the puddle. The centrifugal force gets ride of water pretty well.
If you're concerned, rinse off the wheel rims with fresh water. Go for a ride on dry land. You'll be good.
Keep in mind, when safety bikes were first invented, there was a significant effort to make bikes for the military. They had to tolerate a few puddles! The basic design of bicycles is pretty much water-tolerant.
I used to live in Costa Mesa. Used to ride up the Santa Ana River Trail (that's the SART the guys were talking about). The Santa Ana River is pretty much a dry channel with dikes on both sides most of the time (IIRC) but it does get pretty full in the spring runoff from the mountains. Anyway, the tops of the dikes are paved and rideable, but they do go under a lot of roads (including the Pacific Coast Highway, or PCH). A bit up the coast you have the San Gabriel River Trail (SGRT).
When I lived in the area, Irvine was pretty much undeveloped. So there were bike paths all around the place. Visited last year - not any more!
water
Rode up to a tunnel that goes under a major road in my city. Had been raining alot and the tunnel was completely flooded. More than a meter (3ft) of water at its deepest. I thought it would be fun to ride through it. So i put the bike in the lowest gear and simply rode through it.
There is a difference between having components completely submerged in water (like i had) and just having a lot of water being sprayed on them. Upon submersion there is a hydrostatic water pressure trying to force water in to any available cavity. I would thoughly check any component that was completely submerged. If parts of your bike was submerged (BB area) you probably have to drain those too.
Quoted: 1034 Post(s)
Liked 1,290 Times
I honestly wonder how my touring bike has survived, with countless days of heavy rain, parked in the rain, ridden in the rain, crossing deep puddles, water covered sections of road, etc. Wow.
Likes For phughes:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
When my Brompton is so mudded that I fear it staining the hotel room, I put it under the shower and give it a solid soak. Over time I learned to cover the lights with nylon bags. I would look for more serious problems in life.
Likes For 2_i:
