Shifter cable pinch bolt making me crazy
All Ass No Gas
Location: Azusa, Ca "Everything from A to Z in the U.S.A."
Bikes: 1988 Peugeot St. Laurent, 1974 UO18 Peugeot, 1985 P16 Peugeot, Roadmaster Ground Assult Mtn. Sport, Schwinn Traveler, 1986 Iseran Peugeot, Junet Mixte
Quoted: 50 Post(s)
Im working on a front derailleur and can not figure out the routing of cable to pinch bolt. Its driving me crazy, 2 days of tinkering, and searching. I found part breakdown, install instruction from Shimano. But, does not show exactly how this cable is getting there. Shimano Nexave FD-T301bottom pull. Mainly its the combination of the little parts that has me puzzled. Anyone know or can help? See pics.
Do I go under the little plate thingy?
Do I go under the bolt? But whats all the other stuff for then?
The 1st little part is what throws me off. What does it do with the cable if anything?
Here is a pic without the little parts.
Quoted: 4221 Post(s)
Liked 3,906 Times
Chose door #1 . I use a pair of needle nose pliers to pull the cable tight while tightening the anchor bolt. Andy
AndrewRStewart
AndrewRStewart
Another clue is there is usually a groove on the underside of the fixing plate to hold the cable. Make sure you have the plate oriented per the diagram and then run the cable along the groove.
All Ass No Gas
Quoted: 50 Post(s)
Even that picture still isn't being clear about it...ahhhhh! It only goes under bolt....so then what's everything else for. Thank you to poster.
