Please Help a New Bike Commuter Choose Tires, Tubes, Etc.
Bikes: Surly Long Haul Trucker, Raleigh One Way, Gary Fisher Aquila
Quoted: 8 Post(s)
I'm planning on commuting to university about 3.5 miles away. I have a 1985 Schwinn World Sport road bike. The tires seem to be original and are very thin. I have tested out my route a few times and every time ended up with a flat back tire. Upon close examination I found glass and metal in my tires. My route consists of roads with wide bike lanes and a very nice bike trail. The road with the bike lanes often has broken glass and other rubbish unfriendly to bike tires.
What tires and tubes should I be using for a ride like this? Any other recommendation for a new bike commuter?
Any recommendations are greatly appreciated.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Schwalbe Marathon tires are quite good concerning flat protection. Heavy duty tubes can help ward off flats from thorns and such.
Quoted: 8 Post(s)
I went to my local bike shop and wasn't impressed with what I found for tires or tubes. They actually didn't have any tires for 27 x 1 1/4.
Any recommendations on tubes?
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
I like Schwalbe tubes and tires, but as you have discovered they only do a couple of 27" tires that are rarely if ever carried by LBS.
I like the Panaracer Pasala TG in 27" which are easier to find but still not common in LBS.
When all else fails, there's always Amazon. https://www.amazon.com/Panaracer-Pase.../dp/B001CK2DZM
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Continental Gatorskins are another option, although I don't think that they are the cheapest one out there. Specialized also offers the Armadillo tire as well.
Continental contact ii s are fairly robust and I know they come in 27. I only have 200 ish miles on mine, in wintery conditions, but I've pulled quite a few nasty glass pieces and other cruddy debris that would have flattened some other tires I've ridden
Quoted: 1364 Post(s)
Liked 1,676 Times
Tire liners (like Mr. Tuffy's) are very inexpensive and make any tires puncture resistant. Been using them for years.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Specialized tires.
Infinity Armadillo or Nimbus Armadillo. Whatever model you choose, it must be the "Armadillo" version. Use their "Airlock" tubes for ultimate protection.
-Kedosto
-Kedosto
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times
Either one of these tires will be an upgrade:
Vittoria Zaffiro 27 Inch Road Tire
https://www.biketiresdirect.com/prod...inch-road-tire
Panaracer Pasela Road Tire 27 Inch
https://www.biketiresdirect.com/prod...d-tire-27-inch
Alternately,
Order longer reach brake calipers and then run 700c wheels and tires. Lighter than old 27's for the most part and can change rear to cassette and space as needed. Tiagra hubs and Velocity Dyad, Sun CR18, Mavic Open Sport hoops are all of good quality and cost effective wheel upgrades. 700c tire choices and availability are greater...
Edit:
If you go the 700c route, recommend running new brake cables and going with modern affordable Tektro brake levers w/ hoods and better pull. Shifters of your choice and position on bike. Rewrap new bar setup, dial in drivetrain and brakes, adjust tension on spokes and hubs.
New to you bike !
Alternately,
Edit:
New to you bike !
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,417 Times
27" wheels are a near-obsolete standard. Tires can be found, but not in nearly the variety of prices and capabilities and styles that "700C" tires. Assuming you don't want to replace your wheels, you might be able to stop, or at least mostly reduce, flats with a liner like Mr Tuffy or similar from another brand.
Quoted: 8 Post(s)
Thank you all for your recommendations. I bought some nice 27" Schwalbe tires. I'll probably look into getting some tire liner too. Is it redundant to have puncture resistant tires and tire liners? I'm also considering changing out the drop bar handlebars but don't like what I've seen so far, especially at some of the high prices I've been seeing. I'll probably work on incremental upgrades.
