Brakes squeek
Bikes: Surly Long Haul Trucker, Raleigh One Way, Gary Fisher Aquila
Quoted: 8 Post(s)
Brakes squeek
I recently cleaned my bike. I wiped the rims with a clean wet rag and ever since the rear breaks squeek loudly.
Is this to be expected? Anything I can do to prevent the squeeking in the future when I clean the bike?
Quoted: 384 Post(s)
Liked 6 Times
I'd also rough up the face of the pads themselves. Sometimes they glaze, and exposing new material will stop the yelling.
It's funny, but sometimes refacing the rim's brake surface eliminates squeaks, sometimes it causes them. With Mathauser/KS salmon pads, it takes a day or two of riding to "bed in" the brake track and make the sqeaks stop.
Quoted: 4201 Post(s)
Liked 3,857 Times
Pick up some yard dirt and rub it into the pads. Andy
Steel is real
I had a loud noise coming from the front brakes, there was nothing i could do, tried everything, figured they hardened up over the years, so went to the parts bin and replaced them, problem sol-ved
Liked 3,857 Times
Agreed that changing parameters will change the results. Pad material, contact patch/contour, age meets this change. But it doesn't always eliminate the squeals. Andy
