1" headset spacers
Bikes: Kilo TT
1" headset spacers
Ugh I have the Mercier Kilo with a 1" threadless headtube and I want to replace the OEM spacers to white ones. I found black and carbon spacers, but no white ones after scouring the Internet. 1-1/8" are all over the place, but the elusive 1" is hard to find. Any suggestions before I just spray paint the ones I have? Thanks.
Annoying Member
As an owner of a bike that has a 1" threadless headset/fork- my advice is to suck it up, buy a 1 1/8 stem and a good shim.
perhaps this one - Thomson Shim for 1-1/8" Stem to 1" Steerer
Bikes: Kilo TT
oh yeah I know, I run a 1-1/8" stem with a Thomson shim actually. I am talking about the spacers that go underneath the stem. My stem isn't slammed so I have about 5" of space between the bottom of my stem and the headtube. I have OEM spacers now but want to switch to white ones. It is cosmetic, I know, but still, I know they are out there somewhere on the interwebs.
Successful alcoholic
Quoted: 21 Post(s)
Quoted: 18378 Post(s)
Liked 4,512 Times
Perhaps disassemble, clean, and paint????
I had the same issue locating titanium headset spacers. I ending up searching ebay and located a single source that had decent quality.
My suggestion would be to get a set of cheap 1" carbon spacers from Performance Bike and paint them. Forté Carbon Fiber Headset Spacer Kit
Aluminum spacers tend to be powder coated or anodized for color. Paint on aluminum would not hold up without some serious prep work.
Bikes: Kilo TT
Quoted: 21 Post(s)
Bikes: Kilo TT
Quoted: 21 Post(s)
I may have overestimated a tad. It is just how the Kilo came. Kilo TT Stripper - Pedal Room
That being said, if you Google 'white 1" headset spacers', a few options pop up, but searching within some results is required. White carbon is fairly easy to find.
Bikes: Kilo TT
So I actually slammed by stem but never cut it. I have been riding around a bit and while I love the increased responsiveness in turning, it is not very comfortable on my arms and back. My arms are pretty much locked at the elbows. So I got a Cinelli Ant 60mm stem in the hopes it will raise my posture a tad. If not, I am contempt riding with spacers as it is far more comfortable. I have also considered the Velo Orange Tall stack Stem as an alternative.
As for the Google search, I too did that but when you click on any of the links, it is only for 1-1/8". Google apparently cannot distinguish that the "1" in "1-1/8" is not what I am looking for. Ill check out white carbon though as I never heard of that. Last option is spray paint if the Cinelli Ant doesn't help out.
Quoted: 21 Post(s)
Took a bit of looking, but I'm sitting around at home sick today;
1 inch White Aluminum Threadless Headset Spacer Spacers 10mm Bag of 5 for $10
Bikes: Kilo TT
Also, I noticed you said my frame looks a little small. You think? I always thought it was big on me. My nuts just ever so delicately graze the top tube. I am 6'3" and my frame is 60cm! (57cm in Kilo TT c-c measuring)
Thanks again for the link and feel better man!
Quoted: 21 Post(s)
It was on about page 3 of a Google search for 'white 1" headset spacers'.
As for your frame, it's definitely not too big. With the way you have it set up, it may be just right. It's hard to tell without seeing you on it, though.
Bikes: Kilo TT
wow-dedication! Thanks again. Yeah, the frame "fits" me according to the conventional wisdom. I just hate the spacers. I want to slam the stem so bad. Purely for aesthetics, although I did like the improved handling too. I often wished it were a threaded head tube so i could just rock a sick quill and be done with it, but alas, the dreaded spacers look like they will be with me till the end. Unless that 60mm Cinelli Ant Stem does the trick. Then off to the chopping block for the steerer tube. Thanks again Krusty! Ill be updating Pedal Room shortly with the new components.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
They don't have white 1" spacers but Interloc Racing Designs sells various colored spacers in both 1in and 1 1/8in. If your local shop has an account with Merry Sales, you can order them through your local shop if not you can probably get them via the IRD website?
Mostly the note was for those looking for other colors in various sizes. I wasn't specifically looking for white.
