Bike Lights and replacement batteries cost
Fredly Fredster
I'm a frequent user of Niterider bike lights. These lights have served me well over the past 2 years on my pre-dawn rides. I recently had a Lumina 700 model headlight that wouldn't charge due to a dead battery and a Solas 100 tail light that did the same. The replacement batteries for the Niterider brand are over half the cost (with shipping) of a new light from Amazon. Why even bother with replacement batteries? Just buy a new damn light. It's a shame the batteries cost so much. If the batteries were $5 a piece, it could be justified.
New Lumina 900 boost from Amazon: $52.41
New Lumina replacement battery (without shipping): $24.99
WALSTIB
That's how they get you for sure. But if lights still alright still better just to buy batteries than waste resources.
If you buy the cells yourself, and are even somewhat competent mechanically (three screws and some kapton tape), high quality Panasonic cells can be had for under $10. Of course, Night Rider will actually test your light if it goes back to them, so weigh your abilities to diagnose other issues that may be battery related vs. electronic (charging circuitry, switches, etc...).
$25 is quite reasonable, given that, but as I said, the cells aren't even that expensive if you buy them your self.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Sounds pretty reasonable to me.
Fredly Fredster
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
The other option is to get a light that runs off of common, easily replaceable cells like 14500 or 18650 lithium or standard AA size NiMH. I had a NiteCore flashlight that worked great as a headlight for a few years that ran off of 18650s. If I ever needed to replace one, I just went to Fry's. The only reason I replaced it is because I wanted something smaller, with a USB port, that was ANT+ compatible, so I got a Garmin. Has torx screws on the front of it, my guess would be that there's a 18650 inside it as well.
Advanced Slacker
Liked 2,537 Times
There are basically two parts to a bike light set: the battery and the light. The battery is the more expensive part (if it is a good one, which NRs are). So why WOULDN’T it cost more than half the cost of a light set?
Fredly Fredster
OK then. You buy new batteries. I'll buy new lights.
Jedi Master
I will add this to the long list of reasons why the B&M Ixon IQ Premium is the best battery powered headlight.
Advanced Slacker
Liked 2,537 Times
Buy whatever you want, just don’t complain about the realities of what things reasonably cost.
If good batteries for that light only cost $5 then the light set would have been a whole lot less to start with.
If you think $5 is a reasonable cost, then go buy a $5 battery and see how that goes. You don’t have to use NR batteries, just get one with the right voltage.
Advanced Slacker
Liked 2,537 Times
It is your choice: spend $25 and have a working set of lights, or spend $50 and have a working set of lights plus an extra light that you can’t use.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
The NiteRider website doesn't have a lot of detail on the battery other than it is a Li-Ion unit (guaranteed for a year). You may be able to rebuild the battery pack with new individual cells, but that's a bit of work to save maybe $10.
I do a lot of riding in the dark hours and decided years ago to invest in a dyno hub and good lighting. Bright and reliable and takes away the worry about charging, battery replacement, etc.
This is the reason I never buy USB chargeable lights as they have you over a barrel but just get a decent quality torch that takes rechargeable batteries instead, the other advantage is take a spare battery with you and if the one in the torch runs out just swap it over and continue your ride
Quoted: 18420 Post(s)
Liked 15,564 Times
It's your money, but if you keep buying a new light instead of a new battery each time a battery will no longer charge just because you feel batteries are relatively overpriced you are going to come out behind.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I've gone to AA lights on my second bike, and bought a supply of rechargeables. I carry spare sets of fresh ones when I go out.
Quoted: 507 Post(s)
Liked 237 Times
Is Niterider in the business of developing and selling batteries or lights? Because I'm pretty sure they're just repackaging someone else's battery. Hardly any value they're adding in there. OP, I would suggest looking for another light, it's not like there's a lack of competition in that space.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
Go dynamo and don't worry about lights or charging or batteries : )
Advanced Slacker
Liked 2,537 Times
And yes, NR certainly gets thier batteries from someone else. But there is a big difference between the cheap Li-ion bike light batteries you get from Amazon for dirt cheap and ones that are made to work reliably for several years. A company can spec really cheap batteries or more expensive ones. I can tell you from too much experience with dirt cheap Li-ion batteries and ones that come in lights from reputable companies like NR, Cygolight, and Light & Motion that there is a big difference in how reliable they are
i am sorry, but you are not going to get the small size, light weight, burn time, AND longevity/reliability of the battery that comes in a NR Lumina for $5.
i can show you a pile of cheap Li-ion batteries for bike lights that crapped the bed in under a year of light use. I will use them on my mtb because I run 3 lights so I can afford to have one crap out (which they frequently do). But at $10-$15 a piece I just buy a bunch of them.
Quoted: 1034 Post(s)
Liked 1,290 Times
I have had a Lupine Piko 3 since 2011 and am still using the original battery. The system is pricy, but I have had to spend zero on it since buying it seven years ago.
Quoted: 507 Post(s)
Liked 237 Times
The battery in question IS a Li-ion battery.
Seriously, the tiny battery in my phone lasts more than 2 years and I charge/discharge it daily.
Advanced Slacker
Liked 2,537 Times
Yeah, but is it a fancy battery? Is it reliable? I don't think so, given OP's experience. Probably made in China like the rest of them, unless it's one of these or similar BT-70791CK, BB-2590/U 7.5 Ah Rechargeable Lithium-Ion Battery
The battery you linked to is $375
Likes For Kapusta:
Quoted: 18378 Post(s)
Liked 4,512 Times
If it was simply $25 to repair vs $50 to replace, then economics would dictate the $25 repair.
However, there are many headlights that cost in excess of $100... so a repair would be more favorable... presumably.
On the other hand, other parts wear. I've had nothing but grief from the Android charging plugs, and really hate that they've become standard on so many lights.
My current headlight will barely charge with the plug. So, if the battery was to go bad, the only reasonable choice would be to get a new light (or replace both the battery + charging plug). I think the mount may be wearing.
Anyway, there would be benefits of buying all new (and perhaps going with a different brand or model).
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
That's nice, I'm sure, but it means having a whole wheel built around that hub. That's got to cost more than a standalone light. Cost-over-time probably works in your favor, but it won't for everybody. And, just in case the hub dyno fails, you should be carrying some kind of backup for it anyway (Scout motto).
