eTap or GRX mechanical?
Old 04-24-23, 09:19 AM
daanbr78
Quoted: 9 Post(s)
Liked 9 Times in 6 Posts
Hi, looking for a new gravel bike.
In my price range I can get an eTap or GRX mechanical groups set. Both 1x
it is the
SRAM Rival XPLR eTap AXS, or the
Shimano GRX 810 mechanical (200 euro cheaper)
I ride Ultegra Di2 on my road bike. Never ridden SRAM before (which is not a principal issue for me).
Should I get the electrical or the mechanical? And why?
many thanks for the input!
daanbr78 is offline
Old 04-24-23, 11:41 AM
Koyote
Quoted: 6972 Post(s)
Liked 10,970 Times in 4,692 Posts
Your question may open a can of worms. But, having ridden Shimano mechanical (for a long time) and Di2, I would choose electronic over mechanical ten times out of ten. It's more consistent, more reliable, more trouble-free.
And note that anyone with concerns about dead batteries obviously has zero experience with electronic drivetrains - since, with any of them, it would require negligence to the point of sheer idiocy to actually run out of power in normal use.
Koyote is offline
Old 04-24-23, 11:50 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
Sheer idiocy like what's required to shift into a big-big combination? (Like I did this morning??)
pdlamb is offline
Old 04-24-23, 12:45 PM
phrantic09
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times in 979 Posts
it is the
Is GRX a 2x or 1x? That would be the deciding factor for me (I prefer 2x) If that’s not important to you, I’d go with Rival. I have a mix of Rival and Force on my Aspero and it’s absolutely perfect.
phrantic09 is offline
Old 04-24-23, 03:11 PM
Koyote
There's nothing wrong with shifting into big-big, as long as your chain isn't too short.
Koyote is offline
Old 04-24-23, 03:13 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2241 Post(s)
Liked 3,443 Times in 1,802 Posts
The SRAM electronic drivetrain should be just as good. It is their brakes that make me worry.
Polaris OBark is offline
Likes For Polaris OBark:
Old 04-24-23, 03:21 PM
Eric F
Habitual User
Eric F's Avatar
Quoted: 4957 Post(s)
Liked 8,099 Times in 3,833 Posts
A good friend of mine has been riding Di2 drivetrains for many years. It's shocking how often he ends up with a dead battery in the middle of a ride. He's a good rider, and a gifted woodworker, but really sucks at taking care of his bikes.
Eric F is offline
Old 04-24-23, 03:25 PM
Koyote
The battery not only lasts a long time, but the system practically grabs you by the collar and shouts at you long before the battery completely dies. It's impossible to miss.
Koyote is offline
Old 04-24-23, 03:34 PM
Eric F
Habitual User
Eric F's Avatar
My friend is very talented at forgetting to do things that he told himself to do before. It's truly baffling.
Eric F is offline
Old 04-25-23, 12:47 AM
daanbr78
Quoted: 9 Post(s)
Could you elaborate?
daanbr78 is offline
Old 04-25-23, 08:53 AM
phrantic09
Fat n slow
there’s nothing wrong with their brakes
Old 04-25-23, 09:00 AM
Polaris OBark
Turkeys attempt mating behavior when you apply the brakes.
DOT fluid.
They bought the technology from Avid.
Old 04-25-23, 10:14 AM
Eric F
Habitual User
Eric F's Avatar
DOT fluid.
I was riding with a group of about 10, and we got caught in the rain about halfway through our ride. As things got wet, disc brakes began to howl. It sounded like a zoo pen of angry chimpanzees every time our group stopped for a traffic light. While not all of the bikes with SRAM disc brakes were howling, all of the ones that were howling were SRAM. Just an observation.
Eric F is offline
Old 04-25-23, 12:30 PM
phrantic09
Fat n slow
That’s interesting. My GRX brakes always squealed when wet
Old 04-25-23, 12:48 PM
msu2001la
msu2001la's Avatar
Quoted: 1461 Post(s)
Liked 1,486 Times in 870 Posts
I'd prefer Shimano brakes over SRAM, but not sure this would be a deciding factor in the question being asked.
For the OP - I'd probably think about what kind of priorities you have for this build. There's more at play here than just "mechanical vs electronic". SRAM Rival AXS XPLR is 1x.GRX 810 is 2x. This is a much bigger difference than electronic vs mechanical.
I personally would go with the SRAM, but I like 1x setups and currently have a GRX 11sp mechanical 1x setup that works great for what I need. I know others disagree, so this is definitely the main consideration here.
msu2001la is offline
Likes For msu2001la:
Old 04-26-23, 05:13 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,441 Times in 2,764 Posts
The same bike available with either group?
shelbyfv is offline
Old 04-26-23, 05:31 AM
Fentuz
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 270 Post(s)
Liked 241 Times in 177 Posts
It depends of what you do with the bike.
If you go for long unsupported rides bag packing in nature, I go GRX simply because of the simplicity - no need to think about charging.
If you want it as a sports bike, I'd go etap rival which give the opportunity to add less expensive powermeter and if you do big steep offroad, you can swap rear derailleur and cassette and fit a eagle wide range without having to compromise.
Fentuz is offline
Old 04-27-23, 07:50 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
GRX brakes are incredible. SRAM brakes will get the job done...
dwmckee is offline
Old 04-27-23, 10:52 PM
Steve B.
Quoted: 3242 Post(s)
Liked 2,089 Times in 1,182 Posts
He might have an old battery needing replacing. Or he's too stupid and lazy to pay attention to his battery level. Perhaps electronic shifting is something he should have avoided, but its really not that hard.
Steve B. is offline
Old 04-28-23, 09:52 AM
Eric F
Habitual User
Eric F's Avatar
I understand. He gets lazy and distracted. "I need to remember to..." rarely gets remembered. He has the same issues with his bike computer, light, and other assorted rechargeable devices. It's come to the point of being comedic.
Eric F is offline
Old 04-28-23, 11:26 AM
Koyote
More likely he's just forgetful, but it could be undiagnosed ADHD.
Koyote is offline
Likes For Koyote:
Old 04-28-23, 01:50 PM
shelbyfv
Expired Member
shelbyfv's Avatar
I wish I'd saved a pic of the bike with a 12V on the rear rack.
shelbyfv is offline
Old 04-28-23, 02:19 PM
msu2001la
msu2001la's Avatar
The concern over charging and battery life vastly overblown, IMO.
SRAM eTap shifter batteries last a year or longer, and the rechargeable derailleur shifter batteries are good for 60+ hours of use on a single charge. There are little lights on the derailleurs that tell you the status - these illuminate each time you shift. If they're green, you've got at least 25% battery charge (roughly 15hrs or more). If they're solid red, it's between 15%-25% (roughly 9-15hrs of ride time). If they're flashing red, you've got less than 15%/9hrs. Also if you're on 2x eTap and one of the batteries dies, you can always swap the front and rear so you'd still have gears to get home.
Di2 has similar warnings for battery life, you just have to press a button to see the lights. Both systems can be sync'd with head units to display battery life and warnings. Both systems have apps that will also tell you the battery life and provide warnings when it's low.
I would love to know what kind of crazy rides people are doing where they have to have mechanical shifting because they're so far off the grid for so long that recharging is some kind of barrier.
