How deep do wheels need to be for aero bennies w/ gravel tires?
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
Isn't that Flo testing chart still showing more aero drag when 28mm tires are used? The chart seems to show a significant aero advantage on the 25mm tires with greater yaw angles.
It's only when they factor in the lower rolling resistance that the total numbers start to even out.
This also seems to confirm that a 29mm wide external rim with 28mm tire would be significantly faster.
Quoted: 432 Post(s)
Liked 461 Times
Try to find some 45-55mm deep wheels that weigh under 1600g and you'll be good. There's no good reason (other than budget) to get a 50mm wheelset that weighs 1900g in 2023.
Thread Killer
Liked 1,714 Times
Also, tacking on minimum widths of 24mm/30mm internal/external will be part of my decisionmaking, too.
Quoted: 1461 Post(s)
Liked 1,486 Times
In terms of durability, I have zero concerns smashing carbon wheels on rocks, roots, singletrack, etc. I feel that my carbon wheels are likely a lot stronger and better suited for this type of abuse than my alloy wheels are.
On the other hand, I don't think 1900g aero gravel wheels make any sense. You aren't getting any extra aero advantages compared to something like the 45mm Zipp 303S (which is roughly the same price and a whopping 400g lighter).
The more I read through Flo's marketing materials, the more I'm inclined to believe there aren't actually any aero gains with gravel tires. They show 7 watts of savings at 22mph with a 37c tire on their G700 wheel vs a Mavic Open Pro, but what they aren't telling you is how much of that comes from aero gains and how much is coming from improved rolling resistance due to the wider rim. A Mavic Open Pro has an internal width of just 14.5mm, so a 37mm gravel tire is going to be bulbed way out on that rim compared to something with a 25mm internal.
Thread Killer
Liked 1,714 Times
Liked 1,486 Times
Good points regarding Crr contribution, but wouldn’t a deeper rim always offer better sailing effect than a shallower one, though? Yeah, one can question how frequently those conditions present, but regardless of that, if sailing conditions are present, wouldn’t deeper always be better in those conditions?
Josh Poertner has discussed this on the Marginal Gains podcast in the past, and his conclusion seems pretty black-and-white: According to him, the external rim width must be wider than the tire to have any chance of recapturing airflow. 105% is optimal, but any ratio of "rim-slightly-wider-than-tire" will provide aero benefits. If the tire is wider than the rim, it's not possible to recapture the airflow and there are no real benefits to running deeper wheels.
Obviously real-world is different than a wind tunnel, so even a larger tire on a deep rim might still provide some benefits at certain yaw angles, but this is going to be very small compared to the aero gains that we typically associate with "aero wheels".
I think the marketing around carbon wheels is a bit misleading on this topic. It's not just Flo either. Zipp now sells this as "total system efficiency". They combine rolling resistance, vibrations and aero drag into one combined number to present watt savings, but are more vague on how much of that is actually aerodynamics. Many of Zipp's hookless wheels are not sized in a way that would allow 105% to work for most riders - the popular Zipp 303S for example has a 23mm internal/27mm external and they say it is "optimized" around a 28mm tire. I'm sure the rolling resistance is improved compared to narrower rims, but is that 45mm depth providing any measurable aero gains if the tire is wider than the rim? Maybe.
This is also why Zipp and Enve have gravel wheels that have no pretense of being aero. The XPLR 101 from Zipp is entirely focused on wider width, smoother ride, lower rolling resistance. Zipp knows that there's no chance of getting aero benefits when you've got a 40mm+ knobby tire on there.
Thread Killer
Liked 1,714 Times
I don't know for sure, but I think the answer to your question is "no". It's kind of an all-or-nothing situation.
So I guess at this point, I’ll just look for an as-close-to-optimized-for-aero as possible wheelset for my fast conditions 35mm tires, and not worry about the 42mm rubber, which I primarily run in the winter when I’m dressed in bulky/draggy gear and not out that long anyway because it’s freezing. I’ll go as deep and wide as I can without having to take a real hit on the weight penalty. Someone upthread suggested 1600g, and while that’s about 1/4lbs more than I’m pushing now, I think it’s worth the hope that at some point on a given ride I get some aero gains, like if not during a sprint, maybe when I’m trying stuff my hulking mass into another riders slipstream trying to get some recovery!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,473 Times
Thread Killer
Liked 1,714 Times
Likes For chaadster:
Thread Killer
Liked 1,714 Times
Wowzers…I was just poking around on the LightBicycle site and they’ve got a new wheelset with a rim called the WG44 that’s 30mm IW, 40mm EW, and 44mm deep that builds up to an estimated 1475g on the Bitex hubs for $962! That’s pretty impressive!
https://www.lightbicycle.com/700c-tu...isc-brake.html
Quoted: 432 Post(s)
Liked 461 Times
I only mentioned 1600g as a benchmark as I find that to be the point where a wheelset feels noticeably heavy. If you can afford to go lighter, absolutely do it! 👍
Likes For tFUnK:
Quoted: 314 Post(s)
Liked 683 Times
^ They look good! The closest I was able to find when looking around were some FarSports gravel wheels, deeper but not quite as wide (24mm IW, 30mm EW, 50mm deep @ 1330g).
https://www.wheelsfar.com/gravel-whe...hub-p0132.html
I bought a set of FarSports gravel wheels, but in a lightweight 30mm deep build. Dropped a lot of weight over stock wheels, but are obviously not aero.
Likes For tempocyclist:
Liked 18 Times
Good topic
You will get a lot of widely varying views/opinions on a topic like this. 'everybody' is an expert.
The aero crowd will say one thing while the 'steal is real' bike packers will say another.
Aero DOES have an affect at low ( 12 -16) mph speeds.
Adding any triangle shaped fairing behind a cylinder will improve the CDA. Basic principals.
When I do the 'tire pressure calc. on Silca's site, I get the same suggested pressures no matter what I put in???
Going through the 'should I run a second wheelset for road', just get a faster gravel tire? Or just swap tires on these wheels???
The Blunt SL has been a great wheel for me. Can seat the bead 'tubeless' with a micro pump on the trail.
Since I am fortunate enough to work with carbon, build bikes, and have a complete fab shop;
building some 'spats, or rim fairings' seems the best way to go.
That build was about 2009'. Started supplying rear wheel covers right from the start. You can take a strong/light
spoked wheel and add covers for a lot less cost, weight and stiffer than most disc rear wheels.
The 650 covers on that bike came to a 'hard "V" and actually created handling issues at speed. (lessons learned)
Now all the deep dish wheels are rounded to varying degrees. Bigger radius helps in cross winds.
Tight "NACA" profiles are faster in straight line winds with little 'yaw' angles.
So tempting to just hit 'buy' on some of these. Can do 2 depths and build as many as I want if I build molds?
Lastly; OP mentioned he is a 'big guy'. If you take the total bike/rider weight into account. A 'pound' is hardly anything.
Probably not at the outside of the wheel?
Would like to see more Gravel bikes with deeper wheels. They just look cool!
JM
JM
Likes For JohnnyMagic:
Sunshine
Quoted: 10970 Post(s)
Liked 7,495 Times
'Bennies'
Is this something that is said in the real world or just online?
Yes yes, this is me...
Liked 1,473 Times
Thread Killer
Liked 1,714 Times
Liked 1,486 Times
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 272 Post(s)
Liked 242 Times
As others mentioned, Aero benefits occur at roughy amator triathlon speed (18mph average) but it is also conditional of the tyre setup; the surface between tyre and rim needs to be almost "seamless". In the case of a gravel setup with 38 to 42mm wide tyres, you would need a deep section wheel with outer width of 38-40mm to get the aero benefit.
the alternative would be running wider road aero wheels that work with 32mm tyres and but cyclocross 33mm (like the pros did in Italy)
Quoted: 272 Post(s)
Liked 242 Times
