Tern D7i Questions
Bikes: 2000 Bianchi Veloce, 2016 REI Mazama hybrid, 2023 Tern D7i folding bike
Quoted: 27 Post(s)
Liked 39 Times
Tern D7i Questions
I just bought a Tern D7i, and my first impressions are very positive. It's comfortable and sturdy. Here are a couple of questions for those of you who are more experienced:
- How hard is it to remove the rear wheel to fix a flat?
- Does anybody mount a water bottle on the frame? There are holes for it, and living in the desert, I wouldn't dream of going anywhere without water.
Quoted: 980 Post(s)
Liked 584 Times
You have to first shift the hub into the gear with the least tension (Gear 1).
I remove the gear cable from the "cassette joint" a bit differently, which I find easier. Look at the video at 2:11. Instead of using pliers to remove the ferrule from the cassette joint, I just pull the cable housing forward to disengage the ferrule; the inner cable can then be passed through a slot in the cassette joint, and then it's easy to disconnect the cable from the hub. The way the video shows how to do it is completely fine as well.
Once the cable is disconnected, I usually disconnect the chain's master link to free the hub. I have heard that if you loosen the axle nuts and slide the wheel forward, it is possible to release the chain from the chainring. This would avoid disconnecting the chain, but I've never done it this way.
After the chain is off the hub, the wheel can be removed from the frame; remember to release the brake noodle to get adequate clearance for the tire. (If the tire is flat, this may not be necessary.)
Also remember to note the positions of the "non-turn washers" on the rear axle.
Re-installation of the wheel is the reverse of these steps. This may seem like a lot of work, but it's not. I've changes flats on the rear wheels of my Nexus-equipped bikes in as little as 20 minutes on the commute to my work. I've since changed my tires to Schwalbe "Marathon Plus" and haven't had a flat in years.
iti biking
Consider getting a sausage-style inner tube for the rear to replace the current one. That way you can remove and refit it without needing to remove the wheel.
Standard bottle cages fit fine in the top pair of bolts on the main tube. If you use 1l bottles you may need a side loading cage to clear the handlepost.
Wow, glad I saw this; thanks for posting. This makes dealing with my Sram i - motion 3 hub look like child's play. Glad I bought 4 spares. They're simple to replace, too.
A what?! Never heard of a sausage style tube, just looked on amazon, zero. Is it not a continuous circle, with a break, so can be pulled out without removing wheel? I've fixed rear flats without pulling wheel (hard to invert bike in field due to aero bars, and claw-mount rear derailleur hangs loose with wheel off), just half-dismount tire on non-drive size, pull out tube, but harder to find leak than if tube is completely separate. Do tell about what you said above, thanks.
iti biking
https://hollandbikeshop.com/en-gb/bi...inner-tire-pv/
Here you go. Inner tubes by Gaadi are like a sausage so you don’t need to bother about removing a wheel to extract them from within the tyre.
Jeff Bezos doesn’t need any more money but Holland Bike Shop probably does.
Likes For Reddleman:
